Did a little hay last week ...
   / Did a little hay last week ...
Thanks buddy:thumbsup: I have been watering some on a cple acres but the Bahia has jumped up but the coastal only about 6/7in.,cutting in 3weeks to see how many bales can get put up,then start buying some.If I get another cutting later just be a plus,maybe can get some carry over to next year. May have to put the hay meadow in pasture rotation again this year.
If it were easy everybody would be doing it...........
Isn't that the truth ... let me know if you need hay I've got some left and can cut a TBN'r a deal.
Hay is nice and dry...we are rolling today:
Blue, it's a 400AN Belarus.
Thats great ... the 400 AN is a strong stout tractor. I think its 57 hp and 51 at the pto
   / Did a little hay last week ... #183
Blue...i'm pulling my hair out. Now my Hesston gets a bale half way built...then the bale stops turning. Everything else still turns, belt, gears, chains, rollers....I can't figure it out! I spent all afternoon and only got through about 10 rolls....argggggHHhhHHH!
So ... everything is turning fine until about a half a bale and then its just the bale that stops?
Are you saying the bale is in the baler at a stand still and the belts are just going around and not turning the bale?
   / Did a little hay last week ... #185
M-7
Do you have a de-clutcher rod? It would probably be on the left side of the baler if you were behind the baler looking toward the tractor. Normally the rod length is controlled by the position of the nuts on the rod to size the bale.
You could have a nut missing, moved, or the shaft might be broken.
Ron
   / Did a little hay last week ... #186
Yep....weird ain't it? I had enough yesterday, so we went down the river today on Kayaks...it was 91 here today:cool2:.
Pacer, tomorrow AM I am going to go over the baler again and I look at that rod, and the bearings, and maybe some kinda offering to the used worn out baler Gods.
   / Did a little hay last week ... #187
When in doubt pull out the Owners Manual
....main cause can be the tailgate not latching. Hmmm, this is a possibility, so I need to double check that. It also says that a idler roller can be jammed, so I will take the tension off the belts and see if they all spin free.
Do you have a monitor? If so does it have an idicator light to show the gate closed?
I can turn my baler over by hand with a large cresent wrench and watch all the moving parts.
Keep us posted on what you find.
   / Did a little hay last week ... #189
I got some photos of the small hay meadow at the house (2.5gal jug for Ref.)
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
44029 (A51692)
44029 (A51692)
2020 CATERPILLAR 259D3 SKID STEER (A52707)
2020 CATERPILLAR...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
UNUSED JCT 96" PUSHER BLADE (A57193)
UNUSED JCT 96"...
