Converting a lawn to a garden
   / Converting a lawn to a garden #1
kiotiken
Dunrobin, Ont
2012 Kioti DK45 HST Cab
I'm a first time gardener and need some advice for converting a lawn area to a garden.
My plan is to do a 50' X 30' garden. I have a walk behind tiller (rear tine) to play with as well as my tractor. The soil is heavier clay with no rocks. I have two thoughts on how to start and need to know which way to go.
1) Use the teeth on my box blade to tear up the area I want to garden. Then till the area a few times turning and breaking down the grass. Bring in manure and till that in to the soil.
2) Use the tractor to scrape off the top layer of soil. Till the area a few times and then mix in the manure.
For case 1 I'm worried about the amount of grass and weeds I'll have to deal with and for case 2 I'm worried about taking too much of the nice soil away.
   / Converting a lawn to a garden #2
Cut the sod along the edges of your proposed garden first to make straight edge lines, (sod will tear in weird directions), then use the front bucket to scrape off the sod. Just don't get too greedy and pay close attention to how deep you are going. Don't go any deeper than 2 inches. (5cm) Then till in the manure.
   / Converting a lawn to a garden #3
If you have really heavy clay, you may want to add some sand to the mix. Also, consider mulching where you haven't planted. It will help suppress weeds. Next spring, you can till it in too.
   / Converting a lawn to a garden #4
The problems occur when sand and clay are mixed in incorrect proportions. An ideal soil has 50% pore space (with the remainder consisting of minerals and organic matter). The pore spaces in a clay soil are all small, while those in a sandy soil are all large. When one mixes a sandy and a clay soil together, the large pore spaces of the sandy soil are filled with the smaller clay particles. This results in a heavier, denser soil with less total pore space than either the sandy or the clay soil alone. (A good analogy is the manufacture of concrete, which entails mixing sand with cement - a fine particle substance. The results are obvious.) A soil must consist of nearly 50% sand by total volume before it takes on the characteristics of a sandy soil. For most sites, it would be prohibitively expensive to remove half the existing soil and add an equal volume of sand and then till it to the necessary 18-24". Mineral amendments of large particle size, such as perlite, may provide some benefit but can also be costly depending on the size of the area.
Do you really have clay? Most people can't tell the difference between silt and clay. Google soil triangle test and do a test on your soil to find out where you are.
All you need is some soil, a gar and granular dishwasher soap. :)
   / Converting a lawn to a garden #5
Spray the area with Round Up or GLY wait two weeks and then till away. RU and Gly have no residual and will not effect your gardening but it will kill all the sod and make it so much easier to till. You can even use the teeth of your box blade to initially break up the ground as you will be able to till a lot faster with a walk behind on an initial ground break.
By all means till in that manure. Dont forget about checking the soil PH, you may very well need to add some Lime also.
   / Converting a lawn to a garden #6
How is the garden going?
Well, I should have listened and sprayed the grass to kill it, but I scraped the grass off with as little soil as possible, but still too much. I tilled in a little manure, but it was too fresh, so I went very easy one it.
The garden is planted and the pumpkin plants that I started in the house seem to be doing well. Nothing else has shown itself yet, so the jury's still out on if I can grow anything yet.
   / Converting a lawn to a garden #8
Isn't that an old 'manual recoil' rototiller? circa about 195?'s
I'm not sure, but it is old. It was my grandfathers and I remember changing the oil on it when I was around 16 or so, and it wasn't new then. I'm going to guess it's a minimum 30 yrs old, but not much older than that.
   / Converting a lawn to a garden #10
First year is always the toughest.I would replow in the fall and add leaves to add some organic matter.My father did this for years and had wonderfull gardens.
I hadn't thought of the leaves, that's a good idea. I also have a couple loads of manure sitting in a pile "aging" that I was going to till in this fall. I was thinking of bringing some compost, but like your idea.
   / Converting a lawn to a garden #12
I wouldn't have sprayed it, I don't use any herbicides around what the family eats. Ideal may have been to plow it last fall, then rototill from spring on. When I started my 4 gardens back up from grass (didn't have the time for a few years), I just put up with the grass on the one I didn't plow. The year after that there wasn't much grass and the year after that it was normal.
   / Converting a lawn to a garden #13
I went past a place in Scugog Twp on Friday that had some really good smelling (ripe) cow manure spread on his field.:D
IF you can find some two or three year old cow manure, it will be good and ripe but it will be real good for the garden in the fall. Just leave in on over the winter and turn it in, in the spring. If it is ripe enough it will clear out your sinuses:laughing::laughing::D
   / Converting a lawn to a garden #14
Don't forget to compost food waste from your home. (No meats of course) I have a regular garden similar to yours, and another just for potatoes and vine crops. I use old pallets to build compost piles - zero cost - and compost household wastes, grass clippings, leaves and some old hay. I throw in chicken manure from a neighbor farmer and wind up with excellent black dirt. I add ashes from my woodstove, and can grow most anything.
Like in so many things, there are many ways to build a great garden. Keep looking for tips. I'll never stop growing, looking and changing.
Thanks guys, all good tips, I am taking notes. I've been giving most of my food scraps to the city of Ottawa since they started the green bin program. I only started doing that because my compost bin was full and I wasn't doing anything with it. I'll keeping it for myself, mix in leaves, ash maybe some hay and some well aged manure. Eventually I'll get great soil, but for now, things are growing, just say a full row of cucumber was poking up :D and the pumpkins are growing like weeds.
   / Converting a lawn to a garden #17
I don't even bother to compost, I just dump the vegetable scraps onto the garden and it gets rototilled in the next time I rototill. That might be next spring if it happens to be winter. I don't bag grass clippings but do age the manure 2 years before adding it to the garden. I try to spread it out with the box scraper and then rototill it in.
   / Converting a lawn to a garden #18
Thats a nice sized garden, and it looks like you did a very good job with it. We have two gardens that equal about the same size as the one that you built. I plowed the ground, removed the grass, and then built the boxes. We then added manure soil, and manure that had been composting from our horses for almost 4 years, so it was pretty rich soil. I did buy a Burpee electronic soil tester at home depot that tests the acidity, the PH, and tells you weather the soil needs fertilizer. It works really well. I did have to add fertilizer to ours, since we also had a slow start, and our corn did not start on its own, so we had to replant more corn. The seeds we had were older, and I did not really want the genetically modified seed, just because I am unsure how healthy it is? Anyways, your garden looks very good, and you may want to test the soil, or add fertilizer if you haven't. My grandfather use to grow about an acre of food, and he would always make a tea, with manure, and water, to add to the plants. He always had huge quantities of vegetables. I hope that the garden turns out well! Keep us updated.
url
Electric Soil Tester-69344 at The Home Depot
   / Converting a lawn to a garden #19
I'm in the same boat you're in kiotiken. I put in my first garden this year and I had a friend with a tractor and a single leaf plow come in and plow very shallow and just turn over the grass so the roots would show and let it die. Then he came back a couple of weeks later and plowed real deep. Then we used a rear tine tiller on that to get it broke up real well. I then got a load of cold manure and spread it over the garden.
We came back and tilled it in and made our planting rows. Then we put down a light layer of 13-13-13 on just the planting rows and so far we've had bumper crops of everything.
This is a picture of Fred doing the deep plow.
I'm jealous, I didn't know anybody with a plow I could borrow. Good to hear you're getting good results. My soil is terrible and not much is growing, but I'll get what I get. I'll put back the soil I removed in the fall after the grass has broken down, mix in more manure and mulched leaves. I also have a huge pile of saw dust from doing about 20 cord of wood this year and I'm thinking of mixing that in to lighten the soil up, right now, it's like concrete.
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2019 GALYEAN...
3-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
3-Gang Reel Mower...
