3-Point Hitch cat. 1??
/ cat. 1?? #1
rasp21
Wenatchee Wa.
N.H. T1510 FWD
O.K.,, yesterday I looked at a Iseki landhope 177 SCUT.. 23 horse I think???Anyway, It has heavy lug ag. tires, 4 WD,, I was looking at the lower 3pt. arms, and it looks like with an attch. of any size, the lower arms would be into the lug tires.. Due to the arm spread to get on the hitch pins.. I want to run a KK 48" rear mower, but even with the pins moved to the inside, the arms look to be real close to the tire lugs,, not a good deal. I have heard of CAT. ! limited,, but is this something I can make work?? or should I just wait for a larger CUT??With a regular CAT.! 3pt. I have been using this mower on my Ford 1500,, no problems.. The Iseki has a 4 way snow blade on the front,, and a rear blade,, but the rear blade was modified down to just 24 inch tip to tip on the hitch pins,, so this tells me that someone else has had to work around this with a fix.. Any advise?? Thanks for any help,, by the way, this is the best help forum I have found, and a lot of real good advice from a lot of rreal good folks.. Thanks in advance.. rasp21
/ cat. 1?? #2
A cat. 1 setup on these smaller tractors is less than ideal. Do you know if the rear tires are positioned for the widest stance? That can help some if they can move out more. Otherwise all you can do is take up as much lateral movement with the adjusters once the implement has been attached and verify it's not hitting the tire lugs.
/ cat. 1?? #3
There are also pins that have extended shanks. You could replace the factory pins with longer ones pointed inward, and it should work fine. There are also lift arms with more offset available, too.
/ cat. 1?? #4
My implements are 33 inches tip to tip, and I have no problem. I also added the fast hitch attachments, and now I just back up, and raise the lift arms under the pins, and they lock in place. That way you don't have to pull the arms farther apart when you hook up an attachment. The only implement that I had to turn the pins in, and add longer than standar pins, was my dirt scoop, and that that was only an issue when it has about 700lbs of dirt or gravel in it. It was lightly touching the tires when it was loaded down, however now that I tightened the turnbuckles on either side of the lift arms, so they do not allow the arms to hit the tires. As a combination of these steps, I have not had a single issue using full size Cat 1 implements. The fast hitch attachments listed below, extend your arms out a bit, and that also seems to help. Hope that helps a bit..
[ame=http://www.amazon.com/Field-FTF-01FH-Change-System-Category/dp/B0042F5LBC/ref=sr_1_4?ie=UTF8&qid=1338002825&sr=8-4]Amazon.com: Field Tuff FTF-01FH Fast Change Hitch System Category 1 and 2, Black: Home Improvement[/ame]
This is my tractor with the fast hitch lift arm ends attached. The length of my draw bay is 32 inches.
/ cat. 1?? #5
I see that you have highly offset lower arms. I have noticed that there is quite a large variation in the imported machines with respect to the three point hitches. I have a Yanmar YM2000, a markedly larger machine than the Beaver. It cannot use normal category one I implements. In contrast, the much smaller YM1401D and my ST1440 (equivalent to the Beaver) will both easily fit standard category I implements. My YM240, the US market YM2000, will take them, too. Different wheel settings and lower arm designs makes all the difference.
There are multiple good ways to reach a successful conclusion, and the fast hitch additions seem to help, too.
/ cat. 1?? #6
Looks like the fast hitch ends is a good option. Thanks for pointing it out. I'm hoping to modify all my lateral support hardware to be on the inside of the lower lift arms instead of the outside to provide better stability and reduce bending on the lower arms connecting rod. Last time I had a trailer hooked up, lateral movement was clearly an issue with them on the outside. I'm not sure exactly how I'm going to accomplish this yet but I do know that w/o some sort of fast hitch, I'll be constantly tensioning and then loosening the take-ups every time I attach an implement. The fast hitch design, I think, will solve that problem. Thanks again for the tip.
/ cat. 1??
Thanks guys for all the replys,, will see what I can do.. thanks again,, as usuall,, good info,,, rasp21
/ cat. 1?? #9
Any thoughts on this style for quick-connect? Might be worth the extra $20 with shipping.
NorTrac Three-Point Quick Hitch Category 1 | 3-Point + PTO Hardware | Northern Tool + Equipment
That may actually be a very good value, and idea. I had thought about buying one myself when I bought the fast hitch, however I wanted the ability to move the arms in if I needed to, and I use my carry all almost every day, and I was not sure if that model would bang against the back of the frame on the carry all. It may not, and it does look very convenient, I may still get this style in the future, because it would be nice to just back up, and not have to get off of the tractor. For me, the fast hitch arms have worked great, and they were also the right, option at the time, because I have been considering a hydraulic toplink, to use with my dirt scoop in place of an FEL, that is very expensive.
/ cat. 1?? #10
I just wanted to re-visit this thread, and show you the full size dirt scoop on the back of my G154. I works great. I used it today, to dig down a hill side in the woods, and to shovel a huge pile of shavings. I usually also use this for gravel, and dirt.
/ cat. 1?? #11
Nice!! Mitch, don't those weights bend that front piece on your tractor? Mine is bent and I just assume it was from weights.
/ cat. 1?? #12
Thanks!! No, not at all, the front piece is actually very strong, and they originally came with weights, so I wonder if someone hit something with yours, or had it overloaded at one point, or used it to tow? That front It does bolt off, and there is someone selling a parted out G174 on eBay right now, and they may sell you that front piece for very cheap if you need to replace it. The weights only add about 190+/- lbs to the front, and then I also have the front tires filled. They have been filled since the dealer sold the tractor, so I am not concerned about issues with it. Between the two, it has helped immensely. I have actually seen quite a few with the suitcase weights installed, and I have seen several variations, and one with a small FEL attached to that bracket. see below:
The one with the rock is a bit scary:)
url
url
url
url
url
/ cat. 1?? #13
Sorry, I forgot to ask, did you ever get your lift arm ball joint fixed?
/ cat. 1?? #14
I lost the thread about the seat springs. But anyway, they were on there when I got it and they look like large valve springs to me. And, it looks like they were jb welded in place.
See attached pictures.
Also, I have not taken my alternator off yet. Battery seems to hold it fine. I have no lights now, or anything else, (except the oil pressure light) Is there any
type of battery drain after it starts?
Tires!!!!!!!!!!!! The only turf tires I can find are about 375 apiece! the 8 x 16 ag tires are about 140 apiece. BKT's.
I am slowing fixing things on the tractor, but down here in Texas it gets to hot for me after about noon and up until around 7 or so.
/ cat. 1?? #15
Thanks for the photos! I need to make a setup like that, and if I can find some matching springs, and I will. I have thought about cutting some automotive springs, however I have to look into that. I have also thought about using the kind that go unger a bicycle seat, but I have been worried that they will not work as well.
It is ridiculous how expensive tires are! I'd offer you the ones I took off, but they are original to the tractor, and 30 years old, and dry rotted. I wonder if you would be able to find truck tires that would be a matching size. I will have to see what I can find online that are reasonable for you. I think that it is just the rear tires that you need since you have the 2wd model, right? I would contact your local tire store, and see if they can match them to a truck tires size. Then you could even see if they have used tires in good condition, and you could probably outfit the tractor for $100, or so. I have seen track tires on these rims, but I had a hard time finding the truck conversion size. I am sure that they make a size that will fit. I'll keep looking, and see what I can find.
/ cat. 1?? #16
Mitch, let me know if you can find a conversion for the tires.
The valve springs will never wear out and they are just the right bounce. 200 pounds of driver.
/ cat. 1?? #17
Got the sway chains on the inside of the lower arms now. Much more rigid, stable connection. Like I said earlier though, you have to loosen the turnbuckles each time you change implements to get the lower arms to spread apart far enough to get the implement off. I did order a quick change setup like I linked to earlier to avoid that. It actually isn't too bad undoing the turnbuckles though and I would still rather do that than deal with the instability of sway chains on the outside of the lower arms.
For those that would like to do the mod, you'll need two "bushings" that are 1-1/4" O.D. x 11/16" I.D. and about 1" long. Mine were 1-3/8" long which gave more weld to hold, but cut me a bit short on getting a full nut's width on the 5/8" eye-bolt threads. It will have to do for now though.
/ cat. 1?? #18
Whats to keep the lower arms from sliding over? Also, what did you weld to the bushings? Hard to see. And what did you weld for the mid arm part?
I don't think I am that good of a welder to try that mod, and to pay a welder would cost more than a surgical procedure with my doctor!
(this is for Ilikeurtractor)
/ cat. 1?? #19
I have to make some spacers and put on both ends of the connecting shaft (and one in the middle of the shaft too) and I didn't get the material yet (schedule 10, 3/4" nominal pipe which isn't common, but should fit nicely on the 7/8" (22 mm) bar), but after the sway chains are tightened, there's really no place for the arms to go.
The bushings I described weld to the lower lift arms where the eye-bolts attach.
/ cat. 1?? #20
Welding just takes some practice and I make sure most of what I do is flat, no fancy overhead or vertical stuff. Also, the type of rod a person uses makes a big difference. I've only stick welded (SMAW) and have never done wire-feed or TIG but I've heard they are great. I've probably only ran a few dozen rods in my life and can get by with simple stuff. I wouldn't be intimidated by it. I use a 110V inverter welder I picked up from Wal*Mart.
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
2014 Ford F-450 (A61568)
2014 Ford F-450...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
