Front Output Hydraulic Log Splitter
/ Front Output Hydraulic Log Splitter #1
TWD
Gold Member
Sierra Nevada Mountains - CA
Kubota M59
I plan to make a log splitter utilizing the front outputs on my Kubota M59 by utilizing this cylinder, and making an extension to the electronics on my joy stick to operate it.
I`m wondering if I need to add an aux. hydraulic tank for additional fluid or if my tractor has enough :confused: :confused:
Thanks!
/ Front Output Hydraulic Log Splitter #2
Once you mount the cyl and operate it a few times, replenish the tank fluid to correct level.
Great point. I guess the quick connects will "trap" the fluid in the lines and cyl :thumbsup:
/ Front Output Hydraulic Log Splitter #4
Capacity of that cyl is 2.04 gal.
Thanks for providing the info! Really appreciate it.
What size hydraulic hose would you suggest for that cylinder ?
And do you happen to have the part # for the quick connects handy ?
I believe I need a Parker part to connect to my M59 quick-connects, not sure which though.
Thanks again :D
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
New/Unused SD Lanch SDLD25 Mini Crawler Dump (A61166)
New/Unused SD...
2017 Ford Fusion Hybrid Sedan (A61569)
2017 Ford Fusion...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2002 Bobcat 863...
Pallet of Anchor Shackles (A61166)
Pallet of Anchor...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
