Thinking about adding a (?hydraulic?) thumb to my full size backhoe
   / Thinking about adding a (?hydraulic?) thumb to my full size backhoe #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
In my quest to make my backhoe more useful, I'm thinking about adding a thumb to it.
I added a grapple to my tractor and it was the best thing I've ever done! I can only imagine I'll get a similar feeling with the backhoe. The backhoe in question is an older John Deere 410B, not sure of the year, maybe a 1985, it has a bit over 4,000hrs on it and I'm sure it has a lot of life left in it, as long as I keep using it and don't let it sit and go unused! The more useful it is of course, the more I'll use it :thumbsup:
A quick little rundown on my idea. I work away from home and we have a lot of scrap steel where I work. I can pretty much build the thing with steel that we would otherwise throw away to the scrap bin, plus we have tools at work that I can use that aren't available to me at home. I've checked with my supervisor to make sure it's okay to do this, and he's given me the okay.
The problem is, I have to ship it home! I estimate it will weigh around 250 lbs by the time I'm done with it. So my plan is to design the thumb using Sketchup, then break it into individual pieces in the drawing, and cut/fit all the pieces, but not weld them. Once I get it home, I will weld it all together.
Not sure if this is going to work or not, but I'm gonna give it a shot (pending one more "okay" from work to use the scrap materials).
I've been looking online at pics and came up with a general sketch of what I'd like, as well as size. I'll post the Sketchup drawing once I get a little more 'finished' with it.
The more I mess with the Sketchup drawing, the more I think about making the thumb hydraulic. I'm curious if someone could give me a very quick and basic rundown on the differences of adding a selector valve to a closed center system, vs an open center system? I've become semi familiar with adding hydraulics to my tractor, (link in my sig) and I feel I could pretty easily do it to the backhoe to, if it isn't much different. I'm not sure about the cost yet though, that will have to be figured once I figure out what the heck I even need :laughing:
Here are a couple pics of the backhoe I will (hopefully) have a thumb for someday. This may be a long drawn out process, and in fact there is a good chance it won't happen at all, but I figure if I post up on here, I'll have more pressure to get it done :laughing:
   / Thinking about adding a (?hydraulic?) thumb to my full size backhoe #2
be careful on your measurements. with how everything is large then gets smaller towards the bucket. for the "frame" for the thumb.
see if your tractor has an option for "extend a hoe" if so, you might be able to just pickup up the foot peddle or lever or kit. and have everything ready to go. just be careful you may have some problems trying to tie into one of the lines. to run and another hyd valve.
open center system is what i have on 555c TLB. and hydruailc oil goes through all the levers, when the levers are in middle position (neutral). other words hyd oil is pumped through all levers all the time.
close center system. may need an actual lever to be "moved" for hyd oil to flow through the levers. (oil is only moved when it is needed)???
i may be completely off on above. been some times since i looked up info myself.
I am waiting for a measurement from my father as I do need the inside width of the dipperstick. For now, I am making the main mounting plate 5" wide, or at least that is what it is in my model. The top, is slightly wider at 6", only to accomodate the larger size of the crosstube on the hydraulic cylinder I would go with.
I am building it with all the specs for a hydraulic setup, then, I will modify it to be a manual thumb by simply adding one more bracket a bit lower on the mounting plate, plus of course some sort of stiff arm to hold the thumb at the proper angle. The reason for this is so if I decide to make it hydraulic, it will simply be a matter of buying a hydraulic cylinder and pinning it in...well, minus all that plumbing of course :laughing:
Here is what I have so far.
The cylinder I'm planning for is 3" bore with 1 3/4" rod diameter. Fully retracted it is 28" and extended of course is 48". This will give me a full range of motion through 135 degrees.
Here is one cylinder that I found that met my specs....
https://www.surpluscenter.com/item.asp?item=9-7712-20&catname=hydraulic
All steel is 3/4" thick.
Looking at the specs (http://www.deere.com/en_US/docs/construction/non_current_products/backhoes/410B.pdf) It looks like there was an option for the "extendahoe" however, I don't have that option.
I was hoping I may be able to add a selector valve to another circuit, possibly an outrigger or something.
As a side note, I probably should have put this in the 'build it yourself' section
   / Thinking about adding a (?hydraulic?) thumb to my full size backhoe #5
Can you verify that your BH is closed center hyd?
You should be able you tap into a closed center hyd circuit since all components are in parallel, just add another valve to the supply line/pressure hose and connect the tank line to any other tank line.
The pump flow will be divided between the valves in use.
You can use any open center valve with the closed center option that meets the pressure requirements.
Here is your thumb control. just order the valve with the closed center plug.
http://www.surpluscenter.com/item.asp?item=9-7861&catname=hydraulic
If you need a larger GPM valve this would be the one.
http://www.surpluscenter.com/item.asp?item=9-7974&catname=hydraulic
Closed center data:
http://www.engineersedge.com/hydraulic/fixed_displacment_closed_center_system.htm
Yes, According to the spec sheet I linked to, it is closed center hydraulics with 2500psi constant pressure and 30gpm variable flow.
Surplus Center - 1 SPOOL 8 GPM PRINCE MB11B5C1 DA VALVE
Surplus Center - 1 SPOOL 14 GPM PRINCE WVS11B5C1 DA VALVE
So just to make sure I understand this correctly, I can basically Tee into the supply and return lines?
So I would find my supply line, tee into that with a new supply line to my new valve, then I would simply tee into a return line with my new return line going from the new valve to the tee?
That seems too easy :laughing:
I suppose I would need a considerably larger valve but I get the idea, thanks for posting those links.
Thanks for the link to the closed center data.
   / Thinking about adding a (?hydraulic?) thumb to my full size backhoe #7
Your probably right, I guess there is no need to have the full 30gpm applied to the thumb. It's the pressure that creates the force right? So the only difference with decreased flow is that it wouldn't be able to be operated as fast?
Of course, with a thumb this wouldn't matter anyways.
What about an electric diverter valve? Could I use something like this
Surplus Center - SAE 8 15 GPM DOUBLE SELECTOR VALVE 12 VDC P15544-1
and tie into my outrigger valve?
You can see from this pic that my outrigger valve handles are in a convenient spot to operate when facing backwards using the backhoe (to the left of the operator seat when facing the backhoe.
I got the new measurements for the backhoe that I needed. The distance from the inside of the dipperstick, to the tip of the bucket teeth (with bucket at 90 degrees out) is 36".
The distance from the bottom of the dipperstick, to the top of the dipperstick, is 57 1/2". This is the face of the dipperstick that I will mount the thumb plate to.
The width of the inside of the dipperstick, is 5" at the bottom, and tapering out to 7" at the top.
I know these numbers don't seem to mean much now, but the will as the build gets going. I am mostly writing them down here so I don't lose/forget what they are later. :laughing:
   / Thinking about adding a (?hydraulic?) thumb to my full size backhoe #11
Your probably right, I guess there is no need to have the full 30gpm applied to the thumb. It's the pressure that creates the force right? So the only difference with decreased flow is that it wouldn't be able to be operated as fast? ...
From experience, I can tell you that a thumb which slams shut too fast will not be nearly as useful as one where you can close it with some finesse.
The thumb is used to pick stuff up, not to crush it.
   / Thinking about adding a (?hydraulic?) thumb to my full size backhoe #12
Here is a drawing of the final plan I'm using.
The back mounting plate (that I will weld to the dipperstick) is 3/4" thick, and 45" long. I chose 45" because I can cut it in half, and still fit it into the largest flat rate shipping box they offer, which is 24" long.
The thumb portion itself is now 37" long. This will also work well (geometrically) with the cylinder I will be using. It will allow a full range of motion through 135 degrees.
As far as the speed of the thumb, wouldn't I be able to feather it if I use the electric diverter valve?
I got started on the thumb the other night. I started off cutting the main side plates. I used 3/4" steel, and laid out the dimensions using my sketchup drawings and measurements. I'm by no means a pro at using cutting torches but I'm certainly getting better :laughing:
Sorry no pics yet.
Here is a drawing that I used to lay out my side plates. I was able to get both side plates cut, and the main pin hole cut out. I still need to cut out the two support pin holes, for the support pins I will be using solid 2" round steel, 13 1/2" long, this way the support pins will stick out about 3/4" on both sides of the side plates, allowing me to weld the pins to both the inside, and outside, surfaces of the side plates.
Last night, I 'procured' my 2" solid steel pins that will be used to support the side plates. These things are HEAVY! I'll really be getting the best of the postal service with the flat rate shipping boxes!
These pins are 13 1/2" long.
I cut out one of the two 'gussets' as I call them (don't know what they should be called but their in my first pic) I still need to cut out the larger gusset. (The one on the right in the first pic)
After that, I started on the brackets. I cut out the 2 brackets that will be used for the top mounting position of the hydraulic cylinder, as they seemed the easiest to make. Again, I used the sketchup drawings and dimensions to lay these out, and cut them with the torches. The only step left in these brackets is to drill out the hole for the 1" diameter pin that will be used to secure the cylinder.
This is where I stand as of now. Hopefully tonight I'll get some more work done if I'm not too tired. So far I have 3 hrs in the first night, and 2 and half last night.
   / Thinking about adding a (?hydraulic?) thumb to my full size backhoe #16
Yes, the lever that sends fluid to the selector valve should give you feather.
The selector/diverter valve provides two paths for the fluid to flow. Either outrigger or thumb.
The only way to get a solenoid valve to feather is using some of the newer valves called proportional solenoid valves. and you electrically dial in the flow rate.
They ain't cheap either.
I'm a little confused. Just to be clear, I wouldn't need the solenoid itself to have any sort of feather, I would just need the diverter/selector to select which way I want the fluid to flow, and that fluid would be controlled with my outrigger valve handle.
So with an electric solenoid, operating my diverter valve, I would choose either "thumb" or "outrigger" and then have the feathering ability for whichever I selected.
It seems rather simple to hook up, doesn't look like much more than wiring up a solenoid, a switch, plumbing in the hoses and hook up the cylinder.
Seems a lot easier than my last project!
Over the last few nights I got pretty much all the steel cut that I will need. I cut out the 2 3/4" inch holes for the main pivot pin with the torches, and tonight I will try to grind them down a bit to make the pin fit a little better, they're a little ugly right now from my lack of expertise in torch cutting!
For the main pin, I'm using a 2 3/4" OD piece of thick wall hardened steel pipe. I was able to scrounge up an old pin that was replaced in some heavy equipment, it measured 15" long and a little over 2" diameter, which was too large for the inside diameter of the steel pipe that it will be going through, so a friend of mine put it on the lathe last night and turned it down to fit with about 30 thousands of an inch of clearance, just enough for grease to squeeze through (the pin has a zerc fitting on the end and grease holes throughout)
It's one of the few pictures I managed to get on my phone so I'll post a pic of the pin, and then a pic of the pin inside the hardened steel pipe that will become it's home. :D
The only steel I have left to cut, is the main gusset that will fit between the two thumb sides, connecting them together to give them strength. Aside from that, the remainder of my work will be grinding everything to the right fit, and grinding some bevels on the ends of the steel so I can get good penetration in the welds.
   / Thinking about adding a (?hydraulic?) thumb to my full size backhoe #19
Nice info/details, your are going to love that thumb.
We recently made a mechanical & they love it for their backhoe, amazing how much more work the backhoe can do. Interested on your hydraulic setup, since we can adapt the Thumb to hydraulic.
Keep up the good work, here some motivation to get it done. Deere 310SE
Thanks for the pic, your right it does give some motivation!
As for my hydraulic setup, I think what I'll do is go with an electric diverter valve and tie it into my outrigger valve, so I'll have a toggle switch in the cab (in the factory location which should fit nicely) and when I have the toggle in one position, it will divert flow to the outrigger, the other position, will divert flow to the thumb. I figure this is a good circuit to use because it is not in use while actively using the backhoe itself, and vice versa, also, my setup has the two outrigger valves at a good easy height and just to the left of my main controls for the backhoe (when facing backwards)
As for the thumb, do you think the 3/4" mild steel for everything is sufficient? Assuming my welds are good of course. Do you think I'll bend the thumb or should it stand up to some hard abuse? The main pivot point bracket is 1" mild steel. I'm limited to what I can use because all I have to work with is the cutoffs from other projects around work, however, they're still pretty nice sizes. :D
Also, do you build ripper shanks for a backhoe of my size? If so, how much would it cost me?
A ripper tooth might be my next project if I'm happy with the way this came out. I was thinking of adding a small "V" section to the ripper tooth, like facing backwards, so it can be used to push over trees. I figure a ripper tooth to rip the roots, then the "V" to push the tree over, then the hydraulic thumb to handle the logs/brush, could be just about the ultimate backhoe setup for removing trees/stumps with minimal cost (relative to other options)
2015 Vermeer D9X13III Directional Boring Machine (A59228)
2015 Vermeer...
1454 (A57192)
1454 (A57192)
UNUSED FUTURE 72PRO-72" HYD MULCHER (A60432)
UNUSED FUTURE...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A59231)
2018 Regal 29OBX...
GIYI RB66-66" ROCK BUCKET (A60430)
GIYI RB66-66" ROCK...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
