Toothbar and other accessories
/ Toothbar and other accessories #21
ok, a neighbor helped me grind off a bit from the toothbar with his 8" grinder and a torch. I probably could have done this with my 4" angle grinder, but it would have taken longer for sure. It now fits perfectly. I spent just a few minutes trying it out, and hope to do more soon. It appears to be very strong, and I'd recommend it, especially if they are willing to fabricate it 1/8" smaller for BX owners.
/ Toothbar and other accessories #22
I've posted this info before but will do so again. If you are considering a toothbar or similar device, Google "Ratchet Rake" and watch the video. I've used one for over two years and couldn't be happier with it. The cost for mine was about $300. I can install or remove it in a minute.
/ Toothbar and other accessories #23
As useful as a Ratchet Rake is, it is NOT a toothbar in the conventional sense. You are not going to be able to dig with a RR like a toothbar.
/ Toothbar and other accessories #24
Ditto. I've got two miles of dirt/gravel road to maintain with my B21, when I hit hard dirt that my BB won't scrape, instead of hopping off the tractor and putting the rippers down, which is a pain, I point the FEL down slightly (with toothbar) and rip the hard surface down a few inches that way. As I go forward, the BB catches the loose dirt and moves it to where I want it. Works like a charm. Sure, I hit rocks often and it stops the tractor in its tracks, but it could care less as long as I go slow and the tooth bar itself sure doesn't care.
/ Toothbar and other accessories #25
The Ratchet Rake may not be a toothbar "in the conventional sense" but I can assure you this, I have yet to find an application that it could not easily handle. The Rake has two rows of teeth that are secured to the leading edge of the bucket every bit as tight as if they were welded yet can be removed in a minute. I have lifted the front of my Kubota off the ground while grading and removing brush. From your comments I would suppose you have not used a RR.
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
JOHN DEERE 2040 TRACTOR (A63291)
JOHN DEERE 2040...
2007 International 8600 Parts Truck (A63689)
2007 International...
2012 Dodge Grand Caravan VAN (A61574)
2012 Dodge Grand...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
