torch guide advise
/ torch guide advise #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Well after trying to freehand a torch cut yesterday for some coupons. (read only perfect one was the one done with a grinder) I decided I need to make a guide for it. I have seen on weldingtipsandtricks clamping a piece of angle on, and running the side of the tip against it. I am wondering if I should pick a size, so I can run the nut on the torch along the top edge of the angle, and that will also keep the perfect distance from the work. Is that a good idea? Can it hurt my torch? Is it worth it?
/ torch guide advise #2
I've seen guys do that. Also seen guys use a hose clamp on the cutting tip, place the clamp where the screw is on one side or the other so it can run a long the top toe of the angle iron.
Make sure you sand the top toe of the angle iron with some real fine sanding paper / disc, and before each use rub some soap stone a long the toe also.
/ torch guide advise #3
Great pointers there, Thanks! :thumbsup:
/ torch guide advise #4
My instructor puts his left hand/arm under the torch as a guide/assist. It seems to work for him.
RC
/ torch guide advise #5
i have used angle iron on cuts that need to be right.
832737 (A61166)
832737 (A61166)
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A61165)
2004 MCI D4500...
2019 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A60352)
2019 GMC Sierra...
New/Unused Hydraulic Thumb for CFG Mini Skid Steer (A61166)
New/Unused...
1987 INGERSOLL RAND PT-125R PNEUMATIC ROLLER (A62129)
1987 INGERSOLL...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
