torch guide advise
/ torch guide advise #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Well after trying to freehand a torch cut yesterday for some coupons. (read only perfect one was the one done with a grinder) I decided I need to make a guide for it. I have seen on weldingtipsandtricks clamping a piece of angle on, and running the side of the tip against it. I am wondering if I should pick a size, so I can run the nut on the torch along the top edge of the angle, and that will also keep the perfect distance from the work. Is that a good idea? Can it hurt my torch? Is it worth it?
/ torch guide advise #2
I've seen guys do that. Also seen guys use a hose clamp on the cutting tip, place the clamp where the screw is on one side or the other so it can run a long the top toe of the angle iron.
Make sure you sand the top toe of the angle iron with some real fine sanding paper / disc, and before each use rub some soap stone a long the toe also.
/ torch guide advise #3
Great pointers there, Thanks! :thumbsup:
/ torch guide advise #4
My instructor puts his left hand/arm under the torch as a guide/assist. It seems to work for him.
RC
/ torch guide advise #5
i have used angle iron on cuts that need to be right.
Kubota M4900 Utility Special (A60462)
Kubota M4900...
Spreader Attachment (A56859)
Spreader...
2021 New Holland Powerstar 110 (A60462)
2021 New Holland...
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
LMC 6' SOIL CONDITIONER (A59823)
LMC 6' SOIL...
