Effect of un-level trailer
   / Effect of un-level trailer #11
joshuabardwell said:
I was under the impression that you couldn't do this, because the spring perches are either on the top or the bottom of the axle, and if you were to flip it around, it would reverse the camber of the wheels.
All you need are perches from your local farm or trailer store and weld them on. You can leave your old ones in place in case you want to go back. They are about $5 each. I have done this to two trailers. You are correct though, can't just flip them like the old day with the straight axles.
Hmm... well, I don't have a welder, nor know how to use one, so I think I'll pass on that for the time being, but I'll keep the suggestion in mind. Even if I was to pay somebody else to do the welding for me, it'd come out cheaper in cash than a new shank, but a lot more expensive in terms of hassle and PITA moving the axle over. I think a new shank is going to be the way I go.
   / Effect of un-level trailer #13
I would only "flip" the axle if you have dragging issues as I did. As far as cost, the welding would be done for about $20 at a local shop. There is only about a two inch bead of weld on each one. The new shank is definitely the easiest proper fix. You should be able to sell your old one on CL
   / Effect of un-level trailer #14
There are lots of negatives to flipping axles to also think of. Ramp angle being the biggest issue but also brake over angle at the top of the ramps, load height, stability, wind resistance, ect.
Chris
   / Effect of un-level trailer #15
Don't think of it as a few degrees off, think of it as 5" off. Depending on the truck, it may squat down a good bit when loaded but not 5" so you need to buy the proper shank.
Try to always tow with a level trailer. Obviously it is more important to have a level trailer when it is loaded vs. unloaded so being a little nose high with the empty trailer is going to happen.
I recently set up my new 8000 lb RV trailer to be towed by my F350. When putting the tongue on the ball the ball dropped 3". After snapping up the WDH spring bars it was only a 2" drop.
I had the opposite problem though, my new trailer coupler was really really tall. I had to buy the 100$ drop shank and make it a rise shank and it still barely worked.
So yes, buy the right shank. You and I will both have an extra standard shank in the barn.
   / Effect of un-level trailer #16
I check both front and rear wheel well distances empty, then try to get equal drops front and back. Your post makes it sound as if you at only checking the rear wheels. The rear shouldn't return to the preload distance. That would be over tension condition.
Yep, I only check the back. The levellers are tensioned to parallel with the trailer tongue and the rest is made up with the air bags.:thumbsup:
Didn't state things properly originally.:eek:
Indeed. I'm with you.
With the WD system set up properly, it shouldn't squat much, should it? Etrailer.com videos say maybe 1" in the back.
My current running theory is that if the trailer weight is less than a single axle's GAWR, then it probably doesn't matter too much.
Be careful on that. I have been shopping for shanks lately, and some of them seem to be indicated as drop ONLY. I don't know what's different about them, and don't see why you couldn't flip them upside down, but I assume the manufacturer has a good reason for marking them this way.
   / Effect of un-level trailer #18
Depends entirely on the truck. 1000 lbs of tongue weight has a profoundly different impact on an F350 than it does on a VW pickup. My 8000 lb trailer will put 800-900 lbs of tongue weight onto my ball and gave 3" drop without WDH and 2" with WDH. I provide these data points as reference so that you can see what you should be aiming for and what to expect.
The shank I bought was from an RV store. I don't even know if it has a brand name or rating stamp on it butneither did the original and like the original, the new drop shank is indeed a solid heavy shank. Not much choice for me with this but I will keep an eye on it.
Can't imgaine why it would matter which way you flip the "grave digger" drop shank. Actually, on edit, yes I can. In my setup the ball is farther from the centerline of the receiver than it would be if the shank was flipped. So yes, the grave digger is weaker when set up as I have it vs. the down way.
I guess I see the point. The WD hitch will even out the drop between the front and back, but the absolute amount of drop depends on the truck's suspension and the trailer weight. The point is that the front and back should squat more or less evenly with WD (back a little more than front, IIRC).
I got my information from shopping around on etrailer.com. In their filter options, they had some shanks that were rated for drop only, and explicitly said that they couldn't be used in the "raise" position--at least, that's how I interpreted it.
I'm not a fabricator, but I can see how the stress on the joint would be different in the raise position than the drop position. In the raise position, the joint is trying to "open" and is "pulling" on the welds holding the reinforcement brace in. In the drop position, the joint is trying to "close" and is "pushing" on the welds. Or maybe that's just totally off-base. Like I said, I'm not a fabricator. I just do what the instructions on the box say. (Most of the time.)
   / Effect of un-level trailer #20
Sometimes things are rated one way and not another simply because they were not tested both ways.
Bruce
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
SKID STEER ATTACHMENT PACKER (A58214)
SKID STEER...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
