Hydraulic oil dipstick missing
/ Hydraulic oil dipstick missing #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
:confused:
My 3510 Mahindra owner manual shows a tranny dipstick on the left rear axle.
I ain't got one! :mad: How do I check the hydraulic fluid??
There is a small tube that seems to be welded to the axle and is welded closed on the top. I bought it new and its never spent the night out of my shed.
ready to do a 500 hr service and noticed - NO DIPSTICK
Whats up with that?? :confused2:
:confused:
WHERE IS MY DIPSTICK :confused: :confused: :confused:
/ Hydraulic oil dipstick missing #3
my 2810 gear has a fill port and a sight glass.... not sure if the setup is different on a 3510 or not.
No sight glass that I can see, the welded rod is where the manual drawing shows a dipstick.
How would I check the fluid level with only the fill hole accessable?
/ Hydraulic oil dipstick missing #5
I can't imagine how this would have happened to your tractor, but that is exactly where every 3510/4110 dipsticks are located.
I wonder if the tube is where the dipstick goes in and it is a factory issue that was missed at quality contol inspections???
It seems to be solidily attached to the axle and welded closed at the top. I tied to turn it with channel locks until they slipped and I stopped so as not to damage it.
I am going down to the lake where she is tomorrow and get some good pics for you guys to see.
:ashamed:
I really feel stupid :confused2:
That little rod welded up is actually where the oil dipstick goes and the 'weld' is hard dried dirt!
I guess the dipstick has been missing a long time and I never noticed!
I have gone to a couple of Mahindra dealer sites that offer parts breakdown and can't find the dipstick. The rear axle housing shows where it should be but no dipstick. I found the hydraulic filler plug and the engine oil dipstick but not the hydraulic one.
Could the engine oil and hydraulic dipstick be the same?? The tubes look the same.
I could really use some help finding this part!!
Thanks Galen,
I need hydraulic filters also. Can you tell me which one fits my tractor?
How do I contact your parts dept to order?
:thumbsup:
Woodland Mills Sawmill (A65579)
Woodland Mills...
Hay Rake (A65640)
Hay Rake (A65640)
2022 EZ-GO ELITE...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A59914)
2001 WORKHORSE...
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
