I went to the local Kubota dealer tonite after work and went back and forth between a B3300SU and an
L3800.
I about 95% sure I've made up my mind - I'm going to get the
B3300. The
L3800 has increase capacity on the loader and the 3pt, but it's got some things that in my view are drawbacks compared to the B. If I stand behind the
B3300 and the
L3800 side by side (they had them actually sitting side by side out in the front of their lot) - I can see that the L is really not that much bigger than the B. But when I sit in the L vs when I sit in the B - the L does "feel" bigger. My property is pretty small - so to a point bigger is not going to be better. The more integrated backhoe on the
B3300 is a plus to me - over the L. One of the things I also noticed was that I can only really get off and on the L from the right hand side - mostly because of the FEL joystick. On the B I can exit from either side - because the joystick is right next to the driver seat. I like the hydro pedal setup on the B better than the L too.
From what I remember the pricing being - I will be able to get the B3300SU for probably a couple of grand less than the
L3800 - and I would put that $$ into getting a rock
grapple mounted on the FEL and adding some accessories. So - I'm pretty sure my decision is: B3300SU - with backhoe.
