DK50SE Rear remote flow
/ DK50SE Rear remote flow #1
blucoondawg
Gold Member
Pelican Lake, WI
Kioti DK50SE w/ loader and Woods 90x backhoe, Allis Chalmers C with front snowplow
Can any of you guys tell me what the gpm is available at the rear remote of my DK50SE, I see in the book the hydraulic is at 13.8 gpm, is this what is available at the remote? I didn't think it would be that high, I am researching pricing on subframe backhoes and want to look at 9fters but I want to be sure the remote will run it decent otherwise I will need to go smaller or consider getting a pto pump.
/ DK50SE Rear remote flow #2
According to Tractor Data it's white cousin (CT450) has 9.5 GPM at the rear valves. It did not give a spec for the DK50SE.
/ DK50SE Rear remote flow #3
10 gpm is what I am lead to believe, but I have not tested mine yet. From what I understand 8 is good enough for most hoes. The less flow would just be a little slower with no effect on power. CJ
I was wrong on the 13.8, it's listed total pump flow is 16.8. And that is what the salesman told me, but I didn't think that was what was actually available at the rear remote.
/ DK50SE Rear remote flow #5
I believe the pwr steering takes up 6.8 gpm and the 10 gpm left over is for accessories....FEL, hoe, etc.? That's how I understand it to work. :)
/ DK50SE Rear remote flow #6
There is a kit for the DK series that allows the return line to flow directly into the fill fitting,(where the red vent plug usually is installed). A smaller different vent then is attached to the left rear housing of the tractor. This allows for running a hoe to perform at its best flow and cooler, due to not having to run through a smaller port if hooked up 'conventionally'. It is really easy to install IF one's tractor has the port in place for the newer vent fitting.
Check it with your selling dealer- I'd say most DK series since about '08 are capable of this upgrade.
BTW, Kioti's KB-2485 hoe is designed to dig to +/- 8', for reference.
/ DK50SE Rear remote flow #7
It is a 2 circuit pump the small circuit feeds powersteering, some small functions, and the HST charge pressure. The big section is for Hydraulics 10 GPM. CJ
Thanks guys I figured a good portion of that 16.8 had to be for the power steering, etc
Ya, I have that book, I wasn't wondering so much what the Kioti loader and hoe is rated for but what the tractor can produce at the rear remote, the Kioti specs don't separate the power steering from the rest of the hydraulics on the tractor they just say 16.8 total. These guys say it is 10 and that sounds about right
/ DK50SE Rear remote flow #11
I believe it says it is a tandem pump, so it must be that part of the pump is for the implements, and therefore all the valves should be able to handle the flow from the pump.
I was thinking part of the pump produces 6 gpm which is used for power steering etc, and the other part of the tandem pump produces the other 10 gpm which is used for implements, at least that is what people on here have told me. The implement hydraulic ports don't have the full 16.8gpm
/ DK50SE Rear remote flow #13
Your are correct. 6.8 GPM goes through steering system, oil cooler, back to mainfold to engage PTO & FWD clutches then is used for HST charge, on a SST it goes to tank. 10 GPM goes to loader, rear remotes, then 3 PT before going to tank.
/ DK50SE Rear remote flow #14
I've searched and can't find this kit. do you have any links or parts numbers?
/ DK50SE Rear remote flow #15
All it is a bunch of adapters that connect to the fill pipe to a quick connect output.
/ DK50SE Rear remote flow #16
Thank you. That answered so many questions
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2022 EZ-GO ELITE...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
John Deere 8345R (A64126)
John Deere 8345R...
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
