Oil & Fuel off road fuel
/ off road fuel #1
greenstang
eastern oh
bx1860
on a 2011 bx1860 any side effects of runing offroad fuel since it is for a church and can get it untaxed and can save 20 cents a gallon. 20c isn't much but every little bit helps.
/ off road fuel #2
Every one I have talked with stated the only difference today is the color of the die they put in it so the DMV man can tell if it has had the road tax paid on it. Most everone I know runs the red fuel.
/ off road fuel #3
Yes that is the only difference
/ off road fuel #5
That's too funny! I JUST switched also. I save .25 cents a gallon. You are so right, EVERY little bit helps!!
/ off road fuel #6
Tag for interest. How do I get set up for this?
/ off road fuel #7
in my area a few years ago, there was a difference in the sulfer amount. the on road was transisitioning to low sulfer but the off road was keeping its higher sulfer content. (15 ppm compared to 500ppm) since then the two types have met together and are now both ultra low sulfer. the only difference is the dye in the off road and the tax savings. i ran the off road back when it had the higher sulfer and i still run the off road now with the lower sulfer in my kubota engines= no trouble yet (over 900 and 500 hours). i do use the power service additive most of the time, especially winter. it has the slick diesel in it to help with lubricisity which the sulfer actually use to do. some older diesels might have issues with the ultra low sulfer with out an additive. i think your bx will be fine on off road. that is what i would use.
/ off road fuel
with newer engines that were built after ulsd came out do you still need to run an additive? in my 85 vw golf i use walmart 2cycle oil every time i fill up and every few month i will mix it with power service and my 6.0l f250 i just use the additive ford sells.
/ off road fuel #9
The pumps by me are labeled off road with 500ppm and the road diesel is ultra low under 15ppm. Does anyone have a high hour machine that was ran with the high sulfur? I do not know much about it as this is my first and only diesel. I would hate to wreck the engine in the long haul.
/ off road fuel
the place were i am going to get the offroad says high sulfer 500ppm. i thought that it was all 15ppm in 2010. looks like they never got around to removing the old sitckers yet.
/ off road fuel #11
I worked on engines all my life and the only problem caused by removing the sulphur was a few leaking seals on Cummins. There is a chart giving the lubricity test results for fuel and a bunch of additives 2% bio diesel was by far the best, it is on the Diesel Garage site but if you just Google diesel lubricity test it will come up. Adding 2 cycle oil is a myth.
In 40 years of working on engines in class eights, never did anyone ever admit they added anything.
Cat had the best advise "buy clean fuel and keep it clean"
I lost a lot of work when they took out the sulphur, valve jobs work dropped to near nothing from multiple jobs a week, a turbo a week.
Europe had ULSD for years before we did and they never had any problems using it.
/ off road fuel #12
run the 500 ppm max off road in my b7800 and rtv 900 for a few years. 900 hours on the b7800 and over 500 hours on the rtv 900 as of today. running the off road ulsd now for a bit and no problems. use the power service mainly for anti gelling in winter and to disperse water if it gets in fuel system. as for the slick diesel in power service to compensate for lack of sulfer lubrication, i just do it for reassurance. not sure if i need to, but the other 2 benefits i mentioned i like so i keep doing it. as far as wrecking the engine for the long haul, i am not an expert. there is hours and days of reading on this subject if you search and have the time. many different opinions too. my guess is you should be fine with the newer diesel engines and the ulsd fuel, on road or off road. as for the 80's /90's engines???
/ off road fuel #13
I have used off road in my john deere 310 backhoe for 19 years without any additives. I have not had any problems.
I agree with an earlier post keep your fuel clean.
/ off road fuel #15
Our off road diesel is higher sulfur content. Dealer told what I'd save in fuel cost was not worth the valve jobs I'd have to have done. If the off road had the low sulfer content, I'd use it, but since ours doesn't, I'm listening to my dealer.
/ off road fuel #16
/ off road fuel #17
Off road diesel here is ultra low sulfur. Just checked yesterday.
/ off road fuel #18
Page from my manual pertaining to fuel. Philip.
  • FUEL.pdf
/ off road fuel #19
When I first got my mahindra 2615 I ran on road diesel because the dealer said it would not make any difference. one day while working I started losing power and loaded up on the trailer and took to the dealer, he listened, came back out and dumped a quart of transmission fluid in the tank and almost immediately it started running fine. he told me to run off road and should not have any issues going forward, so I continue to use it.
/ off road fuel #20
Thanks DR86. I'm going to check in with my local feed and seed who sells off-road. They happen to be right at the corner from my lane and much closer than the gas station I usually go to. I've never looked at their pump b/c my dealer told me not to use the higher sulfur stuff and implied that's what they sold.
WESTENDORF 12' LANDSCAPER BOX GRADER (A63291)
WESTENDORF 12'...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
2018 Ford F-150 4x4 Single Cab Pickup Truck (A61573)
2018 Ford F-150...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
