Let's see your Kubota
/ Let's see your Kubota #161
Here is a picture of Elmo at 2 days old. Sadly had to leave for work on day 4 but looking forward to some action pics when I get home! L4740. Ductape, your material/trailer handler on the front is excellent, is it a one off or did you purchase somewhere?
/ Let's see your Kubota #165
L3400DT with dozer blade. Works well for snow plowing, spreading gravel and moving dirt. Woods 72" mower and a temporary make shift way of raising roof panels to replace hail damaged steel.
/ Let's see your Kubota #166
Where did you get the blade for your L3400? I never seen one before!
/ Let's see your Kubota #167
I found the dozer blade at the Kubota dealer where I bought the tractor. It was a traded in on something else and sat on the lot for a few years. The dozer blade has to be about 10 years old (or older) and it was never mounted or used. I did some research on it and as near as I could figure, it was made in Canada and, as far as I know, the company is no longer in business. It was a universal setup that just needed the mounting brackets to match the tractor. A large rectangular tube goes all the way back and is attached to the drawbar so that there is no stress on the front of the tractor, so to speak. All I had to do was modify the front brackets and make a "U" adaptor at the drawbar.This is a really well made unit so if you can find a used one, go for it. I did find one on "Fastline.com" a while back
/ Let's see your Kubota #168
Thanks for the pics! I would love to find one, it looks like a very well built unit.
/ Let's see your Kubota #171
Bleedsgreen Are those factory backhoe stabilizer pads? The pads I just picked up at the dealer has the rubber sections vertical in the pads? I would have thought they would be like yours in your photo but there not.
/ Let's see your Kubota #172
MX5100 Month old and just over 30 hrs and only have been able to use half the month due to rain.
/ Let's see your Kubota #173
/ Let's see your Kubota #174
Looks to me like you need to update your Tractor: info. With one as nice as that, I doubt you are shopping anymore. :thumbsup:
/ Let's see your Kubota #176
Here is mine I don't use it much but would not be without it.
/ Let's see your Kubota #177
'94 L4200 (2700 hrs)
Side-panels are off in the winter shot so the mice don't move in (old wive's tale that I'm going with...)
/ Let's see your Kubota #178
Here is my Kubota B7000 with homemade front weight, 3pt hitch and brush mower
/ Let's see your Kubota #179
Here's my new B2320 with a Piranha Tooth Bar from BXpanded. Just got done taking out some invasive honeysuckle bushes and some mostly dead evergreens from our landscaping.
TRUCK RAMP (A64556)
TRUCK RAMP (A64556)
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2006 Ford E-250 Cargo Van (A64556)
2006 Ford E-250...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
