Let's see your Kubota
/ Let's see your Kubota #161
Here is a picture of Elmo at 2 days old. Sadly had to leave for work on day 4 but looking forward to some action pics when I get home! L4740. Ductape, your material/trailer handler on the front is excellent, is it a one off or did you purchase somewhere?
/ Let's see your Kubota #165
L3400DT with dozer blade. Works well for snow plowing, spreading gravel and moving dirt. Woods 72" mower and a temporary make shift way of raising roof panels to replace hail damaged steel.
/ Let's see your Kubota #166
Where did you get the blade for your L3400? I never seen one before!
/ Let's see your Kubota #167
I found the dozer blade at the Kubota dealer where I bought the tractor. It was a traded in on something else and sat on the lot for a few years. The dozer blade has to be about 10 years old (or older) and it was never mounted or used. I did some research on it and as near as I could figure, it was made in Canada and, as far as I know, the company is no longer in business. It was a universal setup that just needed the mounting brackets to match the tractor. A large rectangular tube goes all the way back and is attached to the drawbar so that there is no stress on the front of the tractor, so to speak. All I had to do was modify the front brackets and make a "U" adaptor at the drawbar.This is a really well made unit so if you can find a used one, go for it. I did find one on "Fastline.com" a while back
/ Let's see your Kubota #168
Thanks for the pics! I would love to find one, it looks like a very well built unit.
/ Let's see your Kubota #171
Bleedsgreen Are those factory backhoe stabilizer pads? The pads I just picked up at the dealer has the rubber sections vertical in the pads? I would have thought they would be like yours in your photo but there not.
/ Let's see your Kubota #172
MX5100 Month old and just over 30 hrs and only have been able to use half the month due to rain.
/ Let's see your Kubota #173
/ Let's see your Kubota #174
Looks to me like you need to update your Tractor: info. With one as nice as that, I doubt you are shopping anymore. :thumbsup:
/ Let's see your Kubota #176
Here is mine I don't use it much but would not be without it.
/ Let's see your Kubota #177
'94 L4200 (2700 hrs)
Side-panels are off in the winter shot so the mice don't move in (old wive's tale that I'm going with...)
/ Let's see your Kubota #178
Here is my Kubota B7000 with homemade front weight, 3pt hitch and brush mower
/ Let's see your Kubota #179
Here's my new B2320 with a Piranha Tooth Bar from BXpanded. Just got done taking out some invasive honeysuckle bushes and some mostly dead evergreens from our landscaping.
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
1999 Toro Groundsmaster 455-D 126in. Mower Commercial Riding Mower (A64194)
1999 Toro...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2014 Kia Sorento SUV (A64557)
2014 Kia Sorento...
