F215 Gearing for mowing
/ F215 Gearing for mowing #1
nevis
Member
England
Yanmar F215
Does anyone else find the F series gearing unsuited to mowing?
I have an F215 which generally I like a lot.
It has 3 ranges and 3 gears in each range. In 2nd range top, ie 6th gear, at PTO revs ground speed is only about 2.6 mph which is too slow. In 3dr range bottom, ie 7th, @ PTO revs speed is about 4.5mph which is too fast on my bumpy ground.
So to get a decent speed I end up using 2nd PTO gear and running at 1900 to 2000 rpm in 7th gear (ie about 3.5 mph).
It seems that the step between the 2nd and 3rd ranges is very big.
Are YM series Yanmars geared in the same way, ie would I be better off looking for a YM series, as I've not seen this issue mentioned.
/ F215 Gearing for mowing #2
I find 2nd range, 3rd gear good for my ym2002d running at 2000 to 2200rpm. Don't know whether this will help you or not but here is the speeds for a ym240, I believe the same as the ym2000.
Thanks for posting that attachement - interesting information.
It would seem that you mow quite a bit faster than I do.
/ F215 Gearing for mowing #4
i also slash at this speed and find it spot on.
/ F215 Gearing for mowing #5
Not sure I do mow faster. I don't know the ground speeds on my 2002. I have 4 range gears and 3 transmission gears. I do move pretty good with the finish mower. When shredding I sometimes reduce throttle some, all depends on what and where I am shredding.
I just found this ground speed chart in my 1802/2002 parts manual. I guess I must be flying. I am assuming I am actually running in #9 if I understand the chart right. I also notice the biggest jump is when you shift into high range.
/ F215 Gearing for mowing #6
I am still getting used to mowing with my YM2210. It has 5 gear ranges (includes a crawler gear) and 3 forward Powershift gears for each range, i.e., 15 forward gears. I'm slowly adjusting after being used to 8 forward gears on my YM1700. The manuals give speeds in km/hr, but we can divide by 1.6 to get miles/hr if wanted. Here are the speeds I typically use with my 5' finish mower:
YM1700 (at about 2500 rpm)
gears 6 or 7 which translate to 5.5 and 8.3 km/hr
YM2210 (at about 2200 rpm)
gears 13 or 14 which translate to 7.5 and 9.8 km/hr
I use the lower speeds when I'm mowing near something or turning and the higher speeds when I'm going straight.
Note that I'm not sure what engine speed corresponds to ground speeds that the manuals are quoting, but I suspect the actual speeds are a bit lower.
/ F215 Gearing for mowing #7
I try and mow in my 7th gear on my 2000. wi mow about 2000-2200rpm so it would be between 4.5-5mph. If its really bumpy or thick grass i drop to 6th gear and thats about 3mph. If its just bumpy and low grass i just reduce throttle in 7th.
But i was thinking that 5th gear is on the low side and 4th is on the high side? Meaning the top gear on the low side of a 2000 is faster than the lowest on the high range? getting my service manual
/ F215 Gearing for mowing #8
I was right your chart does not show it but the service manual does. 4ths gear is actually 1 on the gearshift but in the High range and 5th is actually 4th on the gear shift but on the high range. I will try and expalin better if this does not make sense but if you have lookedat the gear 3' son a 2000 it makes sense as they have the stick numbered funny for this reason.
/ F215 Gearing for mowing #9
I mowed today with the 5 ft finish mower. Some grass was knee high, used the transfer case in 2, and used all 3 gears of the powershift depending on the height of the grass. That translates to 4-6 gear. My manual says that that is between 1.28 - 2.64 mph at 2400 rpm. Seems faster than that. The 6th gear mowing seems to be fast enough for me, I mow over 5 acres of lawn, and it only takes me 2 hrs to do everything. But it is hilly and bumpy and I have to keep the tractor in 4wd all the time otherwise I will slide down the hills.
/ F215 Gearing for mowing #10
I will try and explain better
.. or described another way, the lowest gear in High Range is *lower* than the top gear in Low Range.
So if you really need to go up through the gears in sequence, then the next gear after Low 3rd is Hi 1st, followed by Low 4th.
No I don't know why they did it that way. Maybe they made 4th in each range far higher than 3rd, so the top gear would be a good high speed road gear. I can't think of any other reason to do it that way.
/ F215 Gearing for mowing #11
Thats a good way to put it. Thanks.
I think it was ernie that explained the point of it so that your in the low gear set you can have a "travel" gear so that you can get from point A to B with out haveing to stop put it in high and then back in Low. This would be for in Japan where they may only go 15 feet between fields or on a turn around or say from a shed right next to a field. Its not the case for us here in the US as we have more land usually. Plus i almost never do anything in Low anyway, but if i moved in Low 3 i would not use Low 4 to get to my areas from my farm house. Some of them are 150 yards away and some 300 yards, so if that was the case i would put it in high, i would save a few mins over that low speed 4!!
Interestingly I also have a 1961 Fordson Dexta which has 3 gears and 2 ranges. 4th gear is Low 3 and 3rd gear is High 1.
I find it strange and can't really think why they did it that way. When I mow I want to be in 3rd gear but high reverse is too fast so I keep having to change ranges every time I want to back up.
I've also checked the gearing on my F215 compared to the info in this thread on the YM tractors. It would seem that ranges 1 & 2 are lower ratio and therefore there is no gear to give a ground speed of about 3.3 to 3.5mph @ PTO revs which is the speed I mow at.
/ F215 Gearing for mowing #13
i did not pay close enough attention to the chart for your tractor (just the ym2000) and cant remember what you said, but is it possible to just reduce throttle a fe hundred rpms in the higher gear?
Yes that's what I do. I run the PTO in 2nd gear and the engine at about 1900 rpm which gives roughly 540 PTO rpm and 3.6mph groundspeed.
With a 5ft finish mower the engine doesn't labour but I'm always mindful of the advice that these tractors were designed to run at full PTO speed (2409 rpm for the F215) all day and that this is best for the engine.
2008 FORD F-350 UTILITY BODY (A66091)
2008 FORD F-350...
Front Tank Bracket (A64126)
Front Tank Bracket...
2010 Chevrolet Camaro Coupe (A66738)
2010 Chevrolet...
2018 Chevrolet Equinox SUV (A66738)
2018 Chevrolet...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
