Driveway grader question
/ Driveway grader question #1
DuckHunterJon
Hi all. I topped my 1100' driveway this week, and I want to build something to level and groom it periodically. My thought was to build a light duty landplane for the job. Will be pulling it with a JD3120. Its 5' wide with 8" tall channel sides (scrap on hand). My question is, I built it with a hinge point between the hitch and base, thinking it would be better to follow the contour of the drive. Chains run from the top link to the rear of three skids, so I can still lift it. Any opinons on whether this will work ok, or should it be solidly mounted?
Second question, how far below the skids should the grader blades be set. Again, only for grading #1 crush run gravel
Thanks for any advice. I'll try to post up some picgures tomorrow.
/ Driveway grader question #2
I picture would help in understanding what you have.
On my grader if I run a chain for a top link the big problem is when I hit anything solid, like a rock . The back of the grader kicks up violently because there is no Top Link to hold it down. It has never flipped over into the rear of the tractor but it is a concern. I only run the chain when I am sure the road surface is good and loose and there are no snags. Also if the surface is not realyl loose the rear of the grader tends to rotate up a little as the front blade cuts the hard surface so the back blade has little effect. I don't know if yours would act like that or not. But yes, it follows the contour better.
I set my blades down 3/4" below the skids. Road is packed crusher run.
/ Driveway grader question #3
Use a regular top link and put the chain on the grader, with a bar and a short chain for the floating ability without too much kick up.
Bruce
/ Driveway grader question #4
Bruce
Aahhh - That would be a better way to do it. I like your sketch.
I didn't see any replys by yesterday morning, so I went ahead and gave it a shot. I kept the articulating mount with the chains as I mentioned, and put the grader blades flush with the bottom. See picture below.
Problem 1 - the blades definitely need to be lower, I'm going take Gordon's advice and start at 0.75. I might even go ahead and spend the time to make this adjustable, haven't decided yet.
Problem 2 - the whole thing lifts up at the rear end as I start to pull it. I put 4 12" cinder blocks in the front rack, it helped, but it still lifted up at the rear. Looking at it, it's all about where the pull force is acting. The pins are 16" off the ground, and my 3pt at it's lowest is 12". I could probably lower it a bit, but I wanted to leave some room so the arms would never bottom out. I'm thinking the two solutions would be - weld another weight rack along the back to get the weight further back, or go ahead and mount rigid arms in place of the chains. Both pretty easy to try.
Any other idea's, comments are welcome. This is my first 3 pt attachment build. Still learning and remembering how to weld (it's been a long time since I did anything more than light wall tubing).
/ Driveway grader question #6
I think you would be better off making the whole thing stiff. If you did you would find that the top link adjustment has alot of control over how aggressive it cuts and the back end won't rotate up. It is even posible you would not have to lower the blades. If you wanted to follow the road contour you could put the flex in the top link.
But, if you add enough wt to the back, like you said, it will hold it down. To work good it should be pretty heavy anyway unless you are only working with loose pea stone.
Thanks Gordon. The more I think about it, i'm leaning towards doing the rigid mount. The drive way is pretty flat for the most part, and this will allow me to flatten any areas if need be better than the pivot mount would. I'll try that and see how it works before I cut out the tack welds and lower the blades. Will update when I get a chance to work on out next. Thanks again.
Jon
/ Driveway grader question #8
I think you would be far better off with an 8' york (landscape) rake. Most people don't get one wide enough. When swung out to 45 degrees, you can dig and comb gravel towards the center of the driveway on both sides. Then set it to zero degrees and run a level top lane. The high angle also fills in the ruts and wallows. Use a chain for the top link and two gauge wheels at the back of the rake, so its essentially independent of the tractor's movement.
In 10 minutes or less, you can have a perfectly graded driveway. When angled, the swath should be the width of your vehicle's tire track.
/ Driveway grader question #9
Here's mine I built this spring. It was pretty straight forward. When I use it in really hilly drives I just use a chain in place of the top link. I set my blades at 1/2 deep and that does me very well. I also have them set straight. I eventually will get a TnT kit, but for now works very well.
/ Driveway grader question #10
After reading this post I had to go and check my scraper and now I know part of the problem I'm having with it. The arms of my 3PTH only drop about an inch lower than the pins. That's hardly enough for floating as intended.:eek: I will have to raise the pins at least two, maybe three inches. I had just assumed the arms went lower than that and didn't check.:(:eek: I don't anticipate any problem with the rear lifting since mine is some seven feet long. When I'm done, I'll have provision for weighting it down for gravel work, but removable for when I'm using it to smooth out dirt prior to seeding grass, etc. I plan to position the weight more or less at the center. I'll go into more detail in my own thread in this category when I get back working on it.
Just an update to this post. I removed the chains, and put in ridgid angle bracing. I also lowered the cutting edges 1/2" below the skids. It works like a charm! OK, I don't know how the factory ones work, but this does a beautiful job. I lowered it down, and with in 3 passes, the driveway was looking great. I did find that it moves a ton of gravel if it's not packed yet, but most of the time I will be using it on a packed surface. I'm very happy so far with it. Here are a couple updated pictures. I still need to finish the welds, weld in some gussets, and get some paint on it. I have had a quart of JD green kicking around since I touched up my bucket hooks. Should look good when done. Thanks again for the advice!
/ Driveway grader question #12
I did find that it moves a ton of gravel if it's not packed yet...
One article I saw said you can control the amount of gravel it carries along by changing your speed. If it is picking up too much gravel, then drive faster.
My grader isn't built yet, so I can't test that comment.
Bruce
/ Driveway grader question #13
Glad to hear it is working out for you. :thumbsup:
It is always nice to see an update - thanks.
New gravel is tough because the skids don't float on top of the soft gravel. The blades pull them down in so it takes a deep bite. On mine if I lengthen the top link I can make it less aggressive. Yours may act different but you might try changing your TL length longer and shorter to see what it does.
/ Driveway grader question #14
I have a Befco grader and the blades are adjustable. It's a basic setup. The angled steel the blades bolt to is welded to a flat piece of steel that has slotted holes and the whole thing bolts to the side plates. They were adjustable from flush to sticking down about 1 1/2" but I modified it so they now go from about 3/4" higher to 3/4" lower. It wouldn't be hard at all to make yours adjustable too.
/ Driveway grader question #15
Crazyal, could you post some pictures of how this setup works on your grader? I looked at their website and it wasn't clear.
/ Driveway grader question #16
Each side has three bolts. The angled blade holders are welded to a rectangle piece of steel on each side with slots for the three bolts in them. To adjust the blade height you just put blocks under the side rails on flat ground and then loosen the bolts and the blades will drop down the thickness of the blocks. Or if you want the blades higher then put the blocks under the blades.
/ Driveway grader question #17
Slip a piece of pipe which is shorter than the chain over it. It will still float but if it kicks up, the pipe will act as a solid link.
/ Driveway grader question #18
Looks great so far:thumbsup:
Looking at the pics I think you might want to consider moving the blades forward a bit so that you have about eight inches or more skid trailing the blades. With the top link you can adjust the trim of the skids to cut aggressively (short) or lightly smooth over the surface (lengthen) even with the blades set at 0 depth. I use the landplanes primarily to smooth lawn areas and they work great for this.
Here's pics of a 48" and 96" landplanes I built.
INOP/NON-RUNNING 2000 Sterling L7500 Series Dump Truck, VIN # 2FZHAFBC2YAH48068 (A61165)
INOP/NON-RUNNING...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
2020 Kenworth T880 Truck, VIN # 1XKZD49X1LJ408190 (A61165)
2020 Kenworth T880...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2017 Ford F-250 Service Truck (A61568)
2017 Ford F-250...
