SSQA boom pole
/ SSQA boom pole #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
I needed a boom pole to load 300+ pound rolls of aluminum seamless gutter coil onto the machine located in an enclosed trailer.
At first the simple 3 point model from TSC worked OK. But I had to back up and be just about touching the side of the trailer. So I welded a bracket onto the bucket so that I could put it into the bucket and pin the top link to the top of the bucket. That was OK too, but I can't see through the bucket and it was hard to load coil alone.
Then I decided to load a second roll of coil onto an extra cradle on the gutter machine. This required coming in at a severe angle to get the coil through the side door of the trailer and onto the machine.
Solution: I bought a SSQA plate and had it welded to the rear of the boom pole. Now I simply pick it up with the loader arms. Much more maneuverability and better line of sight.
/ SSQA boom pole
Nice job!
Unfortunately I can't take any credit, other than for the idea. I've only got a 120 volt wire feed welder that's good for up to 1/4" thick steel. I didn't think it would get the penetration needed. That and I'm certainly not an all star welder. :laughing:
Had to farm this one out to a pro welder after I bought the SSQA plate from Skid Steer Express. Reasonable price and a heavy built unit.
/ SSQA boom pole #4
Nice simple solution for the boom pole. If I had use for one I would do the same thing.
Don't discredit yourself for the welding, designers get paid a whole lot more than welder :laughing: I have done the same thing. Use the 120V wire feed to tack everything in place then run it down to weld shop a let them weld it all up so it won't fall apart.
/ SSQA boom pole #6
Good idea. I keep telling myself to get my boom pole put together, and I keep holding off. Now I have a roof to do, and the boom pole would be perfect. I even have the QA plate, and all the steel.:(
/ SSQA boom pole #7
I like the idea, but that boom pole is rated for 500lbs. I think I'll copy the idea, but use some heavier material to make the boom.
/ SSQA boom pole #8
/ SSQA boom pole
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2008 CAT 305C (A53317)
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
