Bigger Turbo
/ Bigger Turbo #1
jacejackson14
Member
New Plymouth, Idaho
Kubota M135X, Kubota M120, John Deere 7920
Was wondering if I am able to get a bigger turbo on my Kubota M135X? Just want to know if I could get more power.
/ Bigger Turbo #2
You might be able to raise the boost pressure, on the present turbo unit, especially if it has a waste gate installed.. Most turbos are set low enough for good power, but not high enough to cause serious engine damage..Check out how it was designed...Some have a pressure switch installed in the manifold to cut the circuit..
/ Bigger Turbo
I'll check
/ Bigger Turbo #4
Been discussed before. The consensus was that it wasn't worth the risk to your entire driveline, etc.
/ Bigger Turbo #5
I'll bet it has a boost controlled waste gate which is easy to manipulate. Install a boost controller in the boost line to the waste gate. Before you do anything though it is best to install a boost gauge and I would not boost it more than 15% of the factory setting.:thumbsup:
Most of these wastegated turbos are capable of over boosting so be careful.
/ Bigger Turbo #6
you can put a bigger turbo on anything. You better be sure everything is dialed in right though. If you have a repuatble company or person that knows what they are doing than i dont see a problem. Is it worth the risk of expensive damage later and then having to go back to factory turbo when you couldve just upgraded to a bigger tractor.
/ Bigger Turbo #7
If you did would you have the weight there to take advantage of the extra HP? My wife's mechanic said he turn the 5140 with a 5.9L Cummins up to 200HP but the rest of the tractor wouldn't be able to handle it and it would be light for 200HP tractor. The IH 686 with an M&W aftermarket turbo is 66HP @ the PTO stock but with the turbo on it it's been dynoed at 106HP and it handles the extra power just fine. FIL used to pull a 2 row NH Silage/Forage Cutter with it and it handled it fine.
BTW: The new M135GX coming out soon looks nice, love the cab.
Pulling a disc
[ame=http://www.youtube.com/watch?v=apHH28sw0GI]Kubota M135GX with Loader & Tow-Behind Disc - YouTube[/ame]
Foreign video:
[ame=http://www.youtube.com/watch?v=sRBBUQUuvAc]Kubota s'attaque aux normes anti-pollution avec un tracteur de 135 ch - YouTube[/ame]
/ Bigger Turbo
Pulling a disc
Video Link: http://www.youtube.com/watch?v=apHH28sw0GI
Foreign video:
Video Link: http://www.youtube.com/watch?v=sRBBUQUuvAc
I have a turbo on my M135X is there any way I could turn it up?
/ Bigger Turbo #10
If you don't have some fueling upgrades a better turbo is not going to do a lot for you.
/ Bigger Turbo #11
I certainly would be interested in how much better the new sysytems are?? I know the new fuel pressures are very high....You have to remember the older engines were not getting all the power from their fuel, hence the smoking issues on acceleration..You could defiintely tell when you had a turbo going out, by lack of power and by the exhaust plume??
/ Bigger Turbo #12
That you would have to ask a competent diesel mechanic. If you look at some tractors you'll see them using the same block, same bore and stroke and it might vary from 120 to 200hp depending on which model you get. They have to be doing something different to each one to get should wide range of power out of the same block.
I'm curious as is others I feel like, what exactly are you trying to accomplish? More power for what application, tillage, big planters, etc. or something else?
/ Bigger Turbo #13
More power requires more air (your bigger turbo) AND more fuel. It is very likely that putting just the turbo on will not get you a performance benefit. I'm not aware of how your engine is set up relative to fuel limits. It may have a transient fuel limit as a function of boost. IF you provided more boost then you may get better transient performance (acceleration) but it is doubtful that your would get more peak performance without modification of the fuel system (higher flow injectors and pump settings).
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
