X585 JD Hyd question
/ X585 JD Hyd question #1
Mtnlover64
Member
Walsenburg, Colorado
JD X585,Mitsubishi/sakoh Beaver,ford 195
Hello, new to the site but finding great info already. I recently bought an X585, great tractor. I am installing a Used Kwik way loader on the machine. I custom built brackets and have mounted the loader. I'm running into problems with the hydraulics though, I teed into the mainline going between the pump and the separator box( not sure of correct name) and then teed into the main return line between the oil cooler and rear end( reservoir). The loader works but I lose power steering unless I use one of the loader functions. I will have to move my wet line connection but not sure where to, I was thinking about the backside of the valve, any suggestions ? Also the loader went up fine but wouldn't go down until I removed the cap from behind the lever, then the valve would go far enough to lower the bucket, any ideas ?
/ X585 JD Hyd question #2
why didn't you use the 2scv that the tractor already has?
with quick connects?
Hi, I didn't use the quick connects because I didn't want to use the levers by steering wheel. The loader I bought already has levers on it. The John Deere levers control everything at the same time, the loader, three point and mid mount mower deck thus resulting in slower hydraulics and everything going to the ground at the same time. JD does make a isolation valve but then you have to open or close it every time you go from front loader work to box scraper work. It would be nice to be able to go back and forth with out having to get on and off the tractor every 30 seconds lol. I
Know there's a war to do it just haven't gotten her done yet.
/ X585 JD Hyd question #4
the valves have to be in series, you basically ran the valvs parallel. the way you have it plumbed, all the flow is going thru the loader valve back to the sump while in neutral. and when you operate one of the loader functions, there is enough resistance to force some of the oil to the PS.
Thank you, that makes sense... So if I found another place to run the return, that had back pressure, it would fix the power steering problem ?? Any ideas on the loader not going down, or would that fix that problem to by putting back pressure on the valve ??
/ X585 JD Hyd question #6
You are not supposed to have back pressure, back pressure is not good, will work against the flow and pressure. , .
All valves should be in series, and rated for high pressure.
You could go to your loader valve first after the pump and feed the JD valve from the new loader valve PB port..
Thank you, yea I don't suppose I meant back pressure but a constant pressure rather tha just a straight shot thru the loader valve and back into the reservoir. That's a great idea, straight from the pump to the loader valve then to the JD valve. I wouldn't have to mess with the pressure relief valve on the loader attachment either right ? Well would I go from the pump to the loader valve than to the hydraulic splitter or block then to the valve ? Instead of putting in the tee, it would be a straight line, so the power steering and all other functions would still work the way they should ?
/ X585 JD Hyd question #8
The first valve in the series flow path should set the relief for the hyd system.
Probably set then all the same.
Thank you for the info, I'll be heading home in the next hour or so. I will measure for some hoses and get them made tomorrow, I'll let you know how it goes
/ X585 JD Hyd question #10
You will have to figure out where JD comes out of the block for the flow into the loader valve, and return the flow from the new valve PB outlet to that point.
:thumbsup:Thank you for your replies.. The problem has been fixed. Loader is installed, received and installed my Ruegg manufacturing three point, have received my rear pto kit... Install will probably happen this weekend. Next project will be to install a new cylinder for the deck so the deck and three point will be operable seperately:laughing::D
/ X585 JD Hyd question #12
Wow - loving this thread!!! This is really close to what I want to do with my X728. I bought it used a few months back and since have bought a 45 loader for it. Now want to figure out how to control the FEL and 3pt separately.
Was thinking of putting lever near the 4wd/2wd lever on the fender deck. Looking at valves now. Would love to put in a joystick SCV from the new 1026, but at $600 for just the valve, not likey. That would be slick though, to have theFEL joystick control and then stock controls for the 3pt.
Would be really interested in some pictures of where you tied in the lines!
Hello, glad to hear the thread is helping you. With the help of some folks on here I was able to figure it out. I just removed the main hydraulic line that comes out of the rearend ( if you lay under the machine and look at the front of the rear axle housing, the main line will be on the left side of the driveshaft towards the top of the housing). My hose was blue, don't know if this applies to all models, the hose runs to a splitter and goes in towards the top. If the design is still the same it's kind of difficult to get the hose off, they use a metric Allan head to hold the hoses into the the splitter and there isn't a whole lot of room to get to it. Anyway I just cut the hase in half and had the local carquest put new ends on each half, ran the hose from the pump (rear axle housing) to the valve assembly on the loader, through the loader valve, then back to the front half of the hose ( splitter) . You have to use the pressure relief valve in the loader valve assembly to set the pressure for the rest of the system. Hope this helps
/ X585 JD Hyd question #14
OK, i know the hose you are speaking of. I was looking at that, but also noticed that all other systems are sending all fluid to steering valve first, then cut out to add another SCV, thereby giving first priority to the steering. Have you noticed any steering lose or anything else to cause you to re-consider?
Also, do you know the GPM flowrate of the system? I am seeing really interesting pricing of the joystick SCVs on the site posted above. WAY cheaper than the Deere price for the 1026R joystick - $300 vs $700! I may just give this a go when I tear the tractor appart in a few weeks to install the 3-point hitch and loader relief valve in the K92.
Thanks for the response!
Oh yeah - where did you get your rear PTO? I am interested in adding one, but having trouble with the $900 price tag! Alot for something I will not use that often. (3-Pt primarily for back blade).
No, I haven't noticed any problems with the steering, as of yet no regrets, the loader isn't quite as strong as I thought it would be but it's working good so far. I was also thinking about a joystick control for the loader but that's going to have to wait for a while, but I have found valves a lot cheaper than 700$, any hydraulic suppy should have them. I'm not sure what the flow is yet, I just adjusted the pressure setting until everything seemed to work right. I would think you could call your dealer or look online to find it. Unfortunately I couldn't find the pto anyplace but the dealer so I just bit the bullet, I haven't installed it yet but I wanted the options that it opens up... Post hole digger, bush hog, etc:laughing:
/ X585 JD Hyd question #16
Found out flow - 6.0 gym rated flow, 4.5 min flow @ 3200 rpm.
Will stop by the Parker store on Saturday to see what they have.
2021 Case SV280B (A62177)
2021 Case SV280B...
40 (A52708)
40 (A52708)
2007 Ford F-750 Terex Hi-Ranger 5TC-55 55ft. Bucket Truck (A60352)
2007 Ford F-750...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
40ft 6 Door Shipping Container (A60352)
40ft 6 Door...
New/Unused AGT Quick Attach Auger with Three Bits (A61166)
New/Unused AGT...
