Lynch pins for CK35 Loader?
/ Lynch pins for CK35 Loader? #1
dustinfox
Gold Member
New Hampshire
Kioti CK35 HST
Anyone else having trouble finding lynch pins?
I seem to have lost a lynch pin from one of my loader arms. Thinking this was a common item, I headed to the local hardware store for a replacement. Two days later and eight different stores, I still can't find one. Are these like a Kioti proprietary size or something? :confused:
/ Lynch pins for CK35 Loader? #2
I have gotten a couple from my local auto supply store. Had several sizes in stock. Seems they are a fairly common item and lots of people that are not tractor owners use them. :)
Not here Mousefield. These are either 3/8 inch or 9mm there about. There is not a single store around or even on line that sells this size. I have checked everywhere. I don't think they make that size in the U.S. The Kioti dealer has them for $2.10 each! I can maybe use 5/16". It's loose but should work.
/ Lynch pins for CK35 Loader? #4
Try TSC or Harbor Freight. The last time I was at TSC they had a bag of lynch pins for $2.00. Harbour freight had a box of 50 assorted sizes for something like $4 or $5.
http://www.harborfreight.com/50-piece-lynch-pin-kit-67544.html
50 Piece Lynch Pin Kit
Thanks Luremaker. I called TSC and they don't carry that size. The link you posted does not include that size either. :confused2:
/ Lynch pins for CK35 Loader? #6
Contents:
(16) 3/16'' dia. x 1-7/16''L pins
(18) 1/4'' dia. x 1-3/4''L pins
(6) 5/16'' dia. x 1-3/4''L pins
(10) 7/16'' dia. x 1-3/4''L pins
Contents:
Oh... I meant that it does not include the size I need.
Thanks again
/ Lynch pins for CK35 Loader? #8
I kept losing them. Wired a few closed. Then I've since replaced with bolts and nylon lock nuts. No problems since.
/ Lynch pins for CK35 Loader? #12
Hmmmm, 11/32"
How about reboring the pin holes to 3/8? Might be easier than trying to get 11/32 lynch pins.
Hmmmm, 11/32"
That's a thought. Although 5/16 would probably be fine... Just a little sloppy.
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
46187SFL (A64557)
46187SFL (A64557)
2008 KOMATSU PC78MR-6 EXCAVATOR (A65053)
2008 KOMATSU...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
