Lynch pins for CK35 Loader?
/ Lynch pins for CK35 Loader? #1
dustinfox
Gold Member
New Hampshire
Kioti CK35 HST
Anyone else having trouble finding lynch pins?
I seem to have lost a lynch pin from one of my loader arms. Thinking this was a common item, I headed to the local hardware store for a replacement. Two days later and eight different stores, I still can't find one. Are these like a Kioti proprietary size or something? :confused:
/ Lynch pins for CK35 Loader? #2
I have gotten a couple from my local auto supply store. Had several sizes in stock. Seems they are a fairly common item and lots of people that are not tractor owners use them. :)
Not here Mousefield. These are either 3/8 inch or 9mm there about. There is not a single store around or even on line that sells this size. I have checked everywhere. I don't think they make that size in the U.S. The Kioti dealer has them for $2.10 each! I can maybe use 5/16". It's loose but should work.
/ Lynch pins for CK35 Loader? #4
Try TSC or Harbor Freight. The last time I was at TSC they had a bag of lynch pins for $2.00. Harbour freight had a box of 50 assorted sizes for something like $4 or $5.
http://www.harborfreight.com/50-piece-lynch-pin-kit-67544.html
50 Piece Lynch Pin Kit
Thanks Luremaker. I called TSC and they don't carry that size. The link you posted does not include that size either. :confused2:
/ Lynch pins for CK35 Loader? #6
Contents:
(16) 3/16'' dia. x 1-7/16''L pins
(18) 1/4'' dia. x 1-3/4''L pins
(6) 5/16'' dia. x 1-3/4''L pins
(10) 7/16'' dia. x 1-3/4''L pins
Contents:
Oh... I meant that it does not include the size I need.
Thanks again
/ Lynch pins for CK35 Loader? #8
I kept losing them. Wired a few closed. Then I've since replaced with bolts and nylon lock nuts. No problems since.
/ Lynch pins for CK35 Loader? #12
Hmmmm, 11/32"
How about reboring the pin holes to 3/8? Might be easier than trying to get 11/32 lynch pins.
Hmmmm, 11/32"
That's a thought. Although 5/16 would probably be fine... Just a little sloppy.
2013 Ford F-650 Ext. Cab Chipper Truck (A64194)
2013 Ford F-650...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
VERMEER BC1000 XL BRUSH CHIPPER (A67147)
VERMEER BC1000 XL...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
