Buying Advice Kubota bx25 vs mahindra max 25
/ Kubota bx25 vs mahindra max 25 #221
I have had several guys come in to my dealership to see the Max for themselves based on this thread. So, if someone wants to continue the debate, it sure does not hurt Mahindra, but it does get old.
A tractor is not a spreadsheet, nor does the nomenclature of SCUT or CUT really matter. They fit people and people's needs differently. People should first of all decide to buy good quality, that is a given, and there are a number of brands that are top quality. Then consider the tasks at hand and how fast they want to accomplish them to help them get the right size. Even a small tractor will do a big job (as long as the job can be broken down into small pieces) given some patience. That sets the basic parameters. From there, find a tractor you like from a good dealer and toss the stack of brochures once you do.
For me, I like the Max 25 or Max 28XL because I want a small tractor that can handle a large mower or tiller. I have great loamy soil and no rocks, and when I till up the garden, I don't mind using a decent size tiller. Now if I did mostly loader and backhoe work, and kept my mower and tiller to a reasonable size, I'd pick the Max 22. Other than HP, you get the same tractor as the Max 25 for less money. If I had heavy loader work for a small tractor, I'd pick the Max 28XL, it lifts as much as some of the competitors 35 HP tractors. But I would first define my needs. I would not just try to buy a tractor that tops out in every column, you end up buying more tractor than needed.
Sounds like excellent advice to me!:thumbsup:
/ Kubota bx25 vs mahindra max 25 #222
Are you Mahindra dealers also competing against the Kioti CK20S with the new Max lineup or is that a different market?
/ Kubota bx25 vs mahindra max 25 #223
The CK20S would probably be more comparable to the Max 28 in size and capacities, just short on HP, but probably heavier. We do not have much Kioti competition in our particular area so I have not studied up on it. Typical of Korean vs Japanese small tractor manufacturers, the Korean unit will be heavier per HP. Generally speaking the Kioti buyers seem like a real satisfied group, so I suspect the CK20S is a nice machine.
But to more directly answer your question, I think the Max 22/25 are more aimed at the BX Kubota, the GC Massey, and the small Deere.
/ Kubota bx25 vs mahindra max 25 #224
Thats the whole problem.:confused2: They are aming it at the BX, GC, and 10-series when it is clearly almost identical to the 20-series and B's:laughing:
But I know you dont mind me continuing to "beat this dead horse" because after all, you said
/ Kubota bx25 vs mahindra max 25 #225
Are there any other tractors in the size and price range as the 28XL that will lift 1400 lbs? This is pretty attractive in this size machine. Is there another? I'd like to know about them if there are. The Kioti CK20 is close, but falls short on both HP and lift. The TYM T273 is close in size and HP, but lifts less. Anything else?
/ Kubota bx25 vs mahindra max 25 #226
LD1,
You are a pretty friendly guy with which to debate anyway, and you aren't trying to make this into an international conspiracy, so we can chat some more on this. I don't see a problem, because this is more of an issue with TBN guys than actual shoppers. Of the last 5 Max 25's I sold in the last couple of days, only one guy knew a CUT from a SCUT from a RUT in the road. And he is TBN guy, so he enjoys the debates! Not to say the others do not know tractors, they just don't care about this trivia. They have a couple of acres and need a good but compact tractor. If they read this thread, they would think we have too much time on our hands.
But I'll bite, just to humor you a little. The CK20S is 2125 lbs bare. I'm not one to put a tractor into a particular box, but the Max is already a little heavier then the BX and GC, but the CK20S is about 25% heavier than the Max 22, for which it is most similar in HP (22 vs 22) and Cu. In., where the Max 22 has 68 vs 61 for the CK20s.
I'll let Kioti define the CK20S. It has it's place. It's a little heavy for it's HP, yet it would have good traction and stability I think. If Kioti was silly enough to define this as a full size farm tractor to work 250 acres, then the market will correct them.
Mahindra is going after the 1-10 acre land owner with the Max and Max XLs, and the tractors seem about perfect for that. If you need capabilites similar but a little better than most BX models, go with the Max 22. If you want to oversize the mower and tiller a little, go with the Max 25. If you need to lift a rediculous amount in the loader and want larger tires and more ground clearance, go with the Max 28XL.
/ Kubota bx25 vs mahindra max 25 #227
So a little off topic. Dave, What are the markets of 3016 and 3616 aimed at?
/ Kubota bx25 vs mahindra max 25 #228
The 3616HST is marketed directly at you Steve! :thumbsup:
More seriously, the 3016/3616 are what I might call a medium frame compact. It's my term, and I like to use it for 25-40 HP tractors that are under 3500# with a loader and are roughly 5' wide. Then there is what I call a heavy frame compact which would be more like the 35 series and 10 series and would be 35-50HP and roughly 6' wide and 4000-5500 lbs with a loader.
If you are going to push the limits of a certain size tractor, then buy the most powerful unit in it's series. LIke the Max22 and Max25 are basically sisters, but the 25 has a much larger engine. That doesn't matter for loading and backhoe work, but is handy for mowing tall stuff or lots of tilling. Same for the 3016/3616, they are basically twins, but you get 8 extra HP with the 36, which is great for heavy PTO work. And remember, the HST burns a little HP as they aren't quite as efficient as a gear/shuttle.
/ Kubota bx25 vs mahindra max 25 #229
You can see here that the Max is really in the same basic size category as the GC. Just a tiny bit larger. Do note the higher seat but lower ROPS on the GC. Not sure how a 6' tall guy would handle a roll over on a GC. If you draw a line from the top of the ROPS to the front of the hood, the guy's head would be taller than that line. Max has a folding ROPS in case you have a low shed.
Slightly taller tire on the Max. Metal hood vs non-metal. Steering cylinder tucked behind the front axle for the Max. Grill gaurd a little bigger. All minor differences, but I'd say still the same class.
When you put both up on a lift and take pictures of their undersides, that is where the difference really shows and an argument could be made that they are in an entirely different class.
If people are not bored with this subject, I can put these on a lift and snap pictures of the undersides.
/ Kubota bx25 vs mahindra max 25 #230
Can't imagine anyone would object to some pictures of the Max! Lift it!
/ Kubota bx25 vs mahindra max 25 #231
Any chance you can get some side x side pics of....say......a max, a B2620, and a BX???
/ Kubota bx25 vs mahindra max 25 #232
LD1,
I don't have a B2620 available, since I'm not a Kubota dealer. I have a BX here we are doing a service on. Perhaps we can snap a picture or two of it.
/ Kubota bx25 vs mahindra max 25 #233
GC on left, Max on right. Obviously neither are designed to be rock crawlers or timber harvesters, but a plastic fan and totally unshrouded driveline has no place under a tractor that is used off of lawns.
/ Kubota bx25 vs mahindra max 25 #234
LD1,
That would be nice to see:thumbsup:
/ Kubota bx25 vs mahindra max 25 #235
Not sure if the GC is as bad, but I really dont like where the hydraulic filter is on that MAX.:mad:
But I am sure us "armchair" engineers can find faults with about any make. Not singling out the max to try to make it look bad, just observing. I didn't like the unprotected location of the hydraulic filter on my L either. That is why I made a skid plate for it
/ Kubota bx25 vs mahindra max 25 #236
I'll probably get flamed for inserting this in the thread, but so be it.
The JD 1-series lacks a tranny/hydraulic fan if I'm not mistaken. And the hydro filter is tucked out of the way.
Ground clearance is pretty low on the MAX, but I guess this could be considered a benefit for lawn-mowing.
/ Kubota bx25 vs mahindra max 25 #237
I did not like the plastic fan on my BX. I felt it to be a genuine sore spot. I do like that Deere got rid of it on their new 1000 series. That's a must for me, should there be a diminutive tractor in my future. Glad to see the Max doesn't have it. I do question, however, the placement of that filter.
I also see that while the Max is shod with larger tires, there still isn't any ground clearance, to speak of, as stuff is hung below the axle negating any ground clearance gained by larger tires.
But then, ground clearance and super low COG are difficult to achieve.
Thanks for the shots, Dave. Great stuff.
/ Kubota bx25 vs mahindra max 25 #238
The filter is actually higher than it looks in the picture, certainly not a low point. And with a loader installed it gets a protective wrap. Also, the ground clearance is actually decent.
I often think the bottom of tractors could be shielded better. The loader rails do add some protection on the Max, even if they were not designed for that reason.
/ Kubota bx25 vs mahindra max 25 #239
That is a better perspective. You're right, Dave. It isn't much worse than most and better than some in filter protection.
/ Kubota bx25 vs mahindra max 25 #240
I assume the clearance issue with the Max is one low-hanging drawbar (5.7"), not indicative of the rest of the undercarriage? If I recall correctly, the Max has a better quality draw-bar than other diminutive tractors I've looked at.
JOHN BLUE TANK SUB FRAME (A63291)
JOHN BLUE TANK SUB...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
EXMARK ARS180KA21 WALK BEHIND AERATOR (A63291)
EXMARK ARS180KA21...
2016 VOLVO EC250EL EXCAVATOR (A64279)
2016 VOLVO EC250EL...
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
