Backhoe bucket woes
/ bucket woes #1
farmall 55a case
case ih farmall 55a
Hi I just bought a ford 420 backhoe. I need a smaller bucket for it! Dose it have to be for a 420 or will other brands work? Any info would be great! Im having a hard time finding information on this machine! Thanks again!
/ bucket woes #3
Most of the Newer and older Ford Buckets would inter change. Im curious to why you want a smaller bucket. I have made a few overthe years form mine and freinds. SOmetimes they can be found at salvage yards.
/ bucket woes
I would like one for digging a trench for pipeline and for digging up tree roots! I don't know if it would help on the tree part or not tho? Would it help or not? I've got a area with a bunch if trees bout six inches round and there all about two feet apart!
/ bucket woes #5
I know what you mean but with the price of scrap steel they cost so much even for bad buckets. One guy got a 18" bucket for digging in rocks for his Ford backhoe that weights 3x of my 24" bucket that had never been used used for only $150 but those are the odds of winning a lottery.
Some say when you are digging in heavy clay soils you have to beat the dirt out of narrow buckets but i only have a 24" hoe bucket. Now that I have the thumb I like the width but a 12" would require less break out force I would think when cutting roots.
/ bucket woes #6
Check with the folks at Wengers of Myerstown, PA they should be able to help you quickly.
/ bucket woes
Yeah im really new to backhoes! I found a few im craigslist around me for sale for a reasonable price but there all for case backhoes didn't know if they would work or not!
/ bucket woes
I have another question why is there to different places to pin the top of the bucket where the bucket curl cylinder attaches? There only about four inches apart!?
/ bucket woes #9
Don't give up on finding buckets... Keep checking Craigslist, and check surrounding cities, as far as you're willing to travel to get one. Even a search on Ebay, within a certain mileage radius. Some may actually find you... A buddy of mine asked me last summer if I'd be interested in a 12" and 24" for my Case. Nothing wrong with the 12", and the 24" needs a new bottom. I asked how much, and he said $50.00... I asked each..?? He said for both, or he was going to scrap them... He has a Ford hoe, so no use to him. I gave him $60.00, and we were both happy...
As for the two holes. The lower hole will allow the bucket to rotate back far enough, if you want to like sheer straight down a wall, straight behind you, without extending the boom & stick all the way. The other will let you curl up closer to the boom, probably for looser material, and clinch things against the stick, if needed.
/ bucket woes
Thanks! I was guessing that was why but I wasn't sure!
/ bucket woes #11
Please refer to it as the bucket retracting/digging/crowding cylinder.
The reasons have to do with the following
1.the type of earth encountered
2. how sloppy it is
3. the desired stroke length of the bucket crowding function
4. the desired final trench or excavation depth
5. how much extra reach is desired(which is big NONO when digging in compacted earth as it is a good way to tear out a crowding cylinder on a bucket.
/ bucket woes
Its mostly loose dirt just alot of trees I have to clear! My grandfather farmed this area in the late 70's. As far as the slop in the machine it is very tight and smooth! Once I get it cleared and the barn built im going to run the tile from the gutters out to a a field tile so the deepest I should be digging is around five feet! Just have to go a little over a hundred yards!
/ bucket woes #13
Where are you located, I might know of one a friend has. Case used a more rounded bucket than Ford did. Ford used a long Banna backed bucket and Case had a short deep round one. I had a Case bucket on my FOrd one time I bought at a sale and it had Ford ears. It didnt dig right to me I adapted it back to a freinds Case.
/ bucket woes
I am in southern Indiana. Yeah the one on it is kinda shaped like a banana lol!
/ bucket woes
Its a 24 in bucket would like to find a 18in bucket!
/ bucket woes
Or even a 12 in bucket!
/ bucket woes
Dose anyone know any web sites I can go to for ford backhoe information? And a site for ford buckets! I google them both and nothing really came up!? Thanks!
2012 Mazda 3 Sedan (A61569)
2012 Mazda 3 Sedan...
2006 Ford E-350 Enclosed Service Van (A61568)
2006 Ford E-350...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2002 John Deere 4510 Tractor (A64047)
2002 John Deere...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
2015 Ford Transit 350 4x4 Sewer Viewer Van (A61568)
2015 Ford Transit...
