Plowing with John Deer 3320
/ Plowing with John Deer 3320 #1
JMER817
Grass Lake, Michigan
John Deere 4120
Has anyone on here have experience moldboard plowing with their John Deere 3320 with Hydro. I realize that the type of ground will make a difference. What size do you use..one or two bottom? 12" 0r 16". Does the tractor seem to have enough power? How is the traction?
/ Plowing with John Deer 3320 #2
thats roughly the same size as my TC33.
I have a 2x16 dearborn plow i pull behind mine. 4wd with locked diff and R4, Its not an easy pull, but i getr done.
Plowing the garden - YouTube
Single bottom is much easyer to pull. a 12" would likely fair much better than my 2x16 as the 12" only goes 6" deep vs the 16" which goes 8"
I know there has to be more 3320 owners out there?
/ Plowing with John Deer 3320 #4
I noticed on the You Tube video that you can easily see the results of the two bottom plow. When i plowed with our 49' 2n Ford as a kid and I followed my dad with his three bottom you could not tell the difference between the two plows. I'd say that the video plow is off set to far left. With proper adjustment the plow should roll over to the same height as the last pass. I'm not critizing just pointing out an observation and with proper alignment it will be easier to pull the plow. Plowing in my opinion is an art form.
idaho2
/ Plowing with John Deer 3320 #5
idaho2: I think you are correct, but you're looking at the initial pass (tractor level) and the second pass (tractor in the furrow). The second/third blend together much nicer. I agree though - a properly set plow will not even leave distiguishable furrows. As you look acrosss the field it will all look the same.
Just did mine yesterday - Ferguson single bottom 16". I'll get pics up soon.
/ Plowing with John Deer 3320 #6
most likely yes, but setting up a bottom plow to roll over correctly from pass to pass is virtually impossible with wide R4 tires most CUT's come with today. If i had skinny R1's that actually fit in the furrow, then pass to pass roll over would line up better.
Just one of those things you ahve to accept when working with modern equipment that does much more than just pull a 2 bottom.
/ Plowing with John Deer 3320 #7
I have a 3520 hst with loaded R4 tires, and an old Ford 2 bottom, 12" plow. I have only used it to plow my home garden. The tractor handles the plow easily at the correct depth but I usually try to pull it as deep as I can to loosen my clay soil. At 10" to 12" deep, I run out of traction, but no problem with power.
/ Plowing with John Deer 3320 #8
Holy cow man! A 12" plow should be going 6" deep - maybe 8" at best!!
/ Plowing with John Deer 3320 #9
To answer the O.P.'s question, I plow with a little Kubota B2630. I have non-loaded R-4's, but leave my loader on. Your tractor is about 1,000 pounds heavier than mine - huge difference when plowing.
I pull a single bottom 16" extra deep Ferguson with ease. I don't have any clay, but I just plowed up thigh-high winter rye with a good root system and I didn't struggle at all. I'm plowing a good solid 10" deep. The plow is set up perfectly after a lot of little adjustments, so that really helps too.
The tractor handles it so well, I just bought a 2-14 Ford 101 that I thought I'd play around with. You should have no trouble pulling a 2-12 or 2-14.
/ Plowing with John Deer 3320 #10
I do understand the plow is designed for 6 to 8" depths, and the tractor handles that great even in my clay.
My garden has significant drainage issues, so I plow as deep as I can and also sub-soil it before final tilling.
That's a beautiful job you're doing with the Kubota and plow!
I should have mentioned that I also have a loader on my tractor, and my plow is a Ford 101.
/ Plowing with John Deer 3320 #11
I had a Dearborn 2x16 Plow. Nice plow! I pulled it pretty well in my sandy / loam soils. I would rather have 12" or 14" bottoms if I had clay or tough soil conditions.....but I handled the plow quite well with the 3320.
I also pulled this plow with my old 790...but it was a bit more of a struggle...and I stood on the diff lock and was always ready to lift the plow.
My 3320 has Industrial tires (loaded). After plowing a bit....I stopped as I was turning up poor sandy soil and burying my better soils. I just dont need a plow. I get along well with my tiller and disc. When I break new ground....I pull my disc thru it first and then go with the tiller. Works good.
I sold the plow. IF I ever bought another - it would have 12" or 14" bottoms.
You should have posted this over at the JD forum for better responses (?).
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
UNUSED IRLMC DELUXE MASSAGE CHAIR (A64281)
UNUSED IRLMC...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
213091 (A64276)
213091 (A64276)
Gehl RS5-19 (A62177)
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
