hydrolic fluid level
/ hydrolic fluid level #1
jrisch
washington,in.
kobota L3400
I have a L3400 2008. There is no window to view the hydrolic fluid level on this tractor. Can someone tell me how to determine the correct fluid high.
/ hydrolic fluid level #2
As a matter of fact, if you look near the front of the left side floorboard at the side of the transmission/clutch housing, there is a sight glass. The tractor should be sitting as level as possible, if it's off much at all you won't get a true indication.
Level should be halfway up the glass, if you don't see a fluid line it's either too full or too low. Should be stopped to check the level, if you don't see anything try starting it and look again to see if anything appears. Loader and 3-point should be fully lowered when you check.
Sean
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
Volvo EC220EL (A60462)
2014 Mercedes Benz CLA 250 Sedan (A61574)
2014 Mercedes Benz...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
