polaris atv flooding out
   / polaris atv flooding out #1
AroniaFarmer
Sioux City IA
TYM T603 52' Ford 8N
Hey everyone.
I have a polaris magnum 425 4 stroke and just recently it developed this problem. When I drive it for more than 15-20 minutes it reeks of gas bad (even when it sits) and starts to run ruff and then it bogs down and dies. an hour later it starts on the second crank, runs perfect and I drove it into the barn. I DID shut the gas valve off just incase it was leaking somewhere that I couldn't see. About a year ago the fuel line was leaking and the local polaris dealer replaced it.:)
:confused3::confused3:
   / polaris atv flooding out #2
Hey everyone.
First guess is a stuck needle valve..Take the fuel line off of the carb and blow carb cleaner back there and see what happens..Could also be a slightly somewhat sunk float.
   / polaris atv flooding out #3
Seafoam it,,,pour some in tank and run it,,,cures some carb problems overnight..
   / polaris atv flooding out #4
Sometimes the vent in the gas cap gets plugged and won't vent. Next time it dies slowly loosen your gas cap and listen for air pressure releasing. If the tank is building pressure that can cause problems.
   / polaris atv flooding out #5
Second that
(3) GOODYEAR EAGLE 6S-2 TIRES (A57192)
(3) GOODYEAR EAGLE...
BUNDLE OF 22" X 60" EXPANDED METAL (A57192)
BUNDLE OF 22" X...
Portable Restroom (A54865)
Portable Restroom...
UNUSED (1) 3500# DROP AXLE W/ BRAKES (A57192)
UNUSED (1) 3500#...
2021 CATERPILLAR 259D3 SKID STEER (A52707)
2021 CATERPILLAR...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
