Hi all new to the cub cadet site
   / Hi all new to the cub cadet site #31
Hi There! Looking for a Z force or RZT with steering wheel myself. You mentioned you are really glad you didn't get the 54" or 60" - why is that? I have about 3 acres, but quite a few fences, pond, trees etc. so the 48" would be much more maneuverable I think, but would take a lot longer on the clear areas.
Hi yes it is just so much easyer getting around stuff with the smaller mower I may have to make a xtra pass or so to make up for the smaller deck but well worth it for the easy of mowing around thing and between tree or any other tight area's you may have in your yard. Also it fits nice on my small trailer and i dont have to get my big trailer out to haul mower. But everyone is dif. look around your yard and see what you will be mowing around and between also measure your trailer. Good luck Vince
   / Hi all new to the cub cadet site #33
48" is about perfect because it atleast covers the wheel-span of the ZTR.
This was not the case with my Z-Force 44" fab'd deck. The tires/wheels on the machine were wider than the deck. Perfect for narrow spots, loading onto trailers and whatnot, but not the best cut quality. For close trimming and better cut, you want something that extends out the sides of the machine.
Joel
That true my deck sticks out each side of my mower so i can mow right up next to thinngs makes it easy.
   / Hi all new to the cub cadet site #35
Duck,
How has the last couple of years been going with the Z Force, do you still love it? Have you found anything that has made you regret or at least like it less. Are you still happy with the 48" deck too?
Thanks
Chris
Galvanized Steel Fence 10ft x 7ft (A55758)
Galvanized Steel...
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2007 Amkus Rescue System (A55787)
2007 Amkus Rescue...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
2005 Mitsubishi Lancer ES Sedan (A55853)
2005 Mitsubishi...
