Continental Z-145 Engine
/ Continental Z-145 Engine #1
MasseyWV
Elite Member
I have a Massey 135 tractor with the Continental Z-145 4 cylinder gasoline engine. I'm still waiting for the shop manual to arrive, but in the mean time, if anyone knows anything about servicing this engine, your input would be most appreciated.
My understanding is the the Continental Z-134 4 cylinder gasoline engine is nearly identical to the Continental Z-145, except for the stroke and bore, so information about servicing or rebuilding that engine may also be applicable.
Currently, I'm preparing to service the valves by adjusting the valve lash and replacing the valve seals.
/ Continental Z-145 Engine #2
Look on the data plate for the engine on the left side just below the cylinder heas/deck interface. Most of the Z block Continentals have the lash settings on that data plate. The recomendation in the manual will most likely recommend setting them while running. Why are you replacing the valve stem seals? Burning oil at idle?
You best wait til your manual shows up to replace the seals. I've never done them but you'll have to remove the spring on the intake valves and you'll need soemthing to keep from loosing the valve when you remove the spring. Either a special spark plug hole fitting to hold the valve with air pressure form a compressor or getting the piston near TDC so the valve doesn't drop down.
You're correct, I'm replacing the valve seals because it smokes (blue oil smoke) at startup and idle. The valves were noisy and I knew they needed adjusted so I figured I'd go ahead and replace the valve seals while I had the valve cover off.
Currently, I've got the sheetmetal and gas tank removed with the valve cover off to perform the needed work. Surprisingly, the inside of the engine, at least under the valve cover, is very clean and free of sludge, but my suspicions about the valve lash needing adjusted were correct
In fact, I've never seen valves so far out of adjustment. I looked at the data plate earlier and if memory serves, on the Continental Z-145 engine, the valve lash should be .015 cold or .013 hot, and currently the valve lash is closer to 1/8 of an inch on the valves I looked at, which tells me that the valve lash has probably never been adjusted. I'll have to turn the engine to check the rest of the valves but I have little doubt that they are the same.
When I replace the valve seals, I'm going to put each cylinder at TDC, then use compressed air to hold the valve in place before removing the spring. The valve spring keepers might be a challenge though, because they're the pin type and if memory serves, aren't the easiest to remove/replace. Having the piston at TDC will ensure that the valve doesn't drop into the cylinder if I should lose compressed air for whatever reason.
As suggested, I'm planning to wait until the shop manual arrives before doing anything more than inspection, because guesswork and engine repair usually results in disaster. I still need to purchase new valve seals so manual or not, I have to wait regardless.
/ Continental Z-145 Engine #4
I would recommend pulling the head right off. I just pulled the head off of my Z-134 engine from my 202 Workbull yesterday. Use a proper valve spring compressor. It will save you from trying to find either the pin or the locks or the spring if it takes off. It will cost you a head gasket but in the long range it will save you a lot of unnecessary words. Just my opinion. Also my book says that "Tappet clearance should be .013" when it is hot and .015" when it is cold. Valve should be set when "hot". Have the engine running (auxiliary fuel tank) at a slow idle at normal temperature." Hope this helps.
I've debated whether or not to remove the head, but I have a good valve spring compressor, and believe I can do it without removing the head. My only concern is the pin-type keepers which may make things a bit more complicated.
Despite the minor issues mentioned above, the engine has good compression (Dry: 155 PSI on all cylinders), runs great, and has plenty of power. However, I'm planning to eventually do a full restoration on the tractor and will also be completely overhauling the engine at that time, so I'm trying to keep the repairs as basic as possible for now.
Here are some pictures of my tractor's Continental Z-145 engine with the valve cover removed.
Note the last picture, which shows one of the spring retainers/washers at each end of the rocker arm assembly that are held in place by cotter pins. As it turns out, both cotter pins had failed, allowing the washers to come off the end of the shaft. The resting place of one of the washers is visible in the first picture, and the other one was found stuck to the valve cover.
Fortunately, there appears to have been no damage caused by the loose washers, and I'm not concerned about the missing cotter pins which are either laying at the bottom of the oil pan or were sucked into the oil filter long ago.
More pictures and information about my tractor can be found here: http://www.tractorbynet.com/forums/...rating/241531-my-1966-massey-135-tractor.html
I don't know what I was thinking when I said it had the pin-type valve spring keepers. After reading about the possibility that the Continental Z-145 engine may or may not have valve seals, I took a closer look and discovered that it has the traditional split-type valve spring keepers.
However, it appears that it does not have valve seals, which would explain many things. Granted, it's hard to tell for sure until I remove the valve springs, but if indeed it does not have valve seals, I plan to add them to help reduce the smoking at startup and idle. At least until I perform a full overhaul at a later date, when I will replace the valves and valve guides.
Many different types of valve seals are available, so I shouldn't have any difficulty locating the correct seals for this application if none are available specifically for this engine. If all else fails, simple o-rings also work very well.
/ Continental Z-145 Engine #8
If it is smoking at start up, that is a sign of worn valve guides, which if I were you I would have replaced while I was working on it, along with a valve job.
Good luck!
/ Continental Z-145 Engine #9
Another way to hold the valves in place is stuff the cylinder with a length of clothesline and then bring the cylinder up to TDC. Be sure to leave enough rope hanging outside the cylinder so it can be pulled out.. Method works on aircraft engines. Having air on the cylinder can cause the prop to turn and wack ya..:thumbsup:
Tom
/ Continental Z-145 Engine #10
If it doesn't have valve seals and is smoking at idle and low power then your valve guides maybe worn. many times even if it had valve seals, you won't find them on an older engine like this. they have long ago disintegrated.
It's worth a try to put seals on and see if that helps. You must have really been down on power if the valve lash was 0.125 inches! The valves were barely opening!
Good luck!
I agree that the valve guides could be worn, and I'm seriously considering removing the head to inspect/replace them (if necessary) and lap the valves. Removing the head would also enable me to inspect the cylinders and clean out any carbon that has built up on the piston/head over time from the oil consumption.
After speaking with a local Massey Ferguson parts guy who is familiar with the Continental Z-145 engine, I learned that it may have valve seals afterall. He told me that if it has valve seals, they would be located just under the valve spring cap, which means they would not be clearly visible when looking through the valve spring.
Fortunately, the shop and owners manuals I ordered are at the post office waiting for me to go pick them up, so I should know much more shortly.
I also wondered if the valve seals may have disintegrated, which would also explain why they appear to be absent. If it uses the o-ring type valve seals, this is entirely possible.
The valve lash gap was more than I had ever seen on an engine and I'm sure that proper adjustment should yeild a considerable power increase.
I finally got a chance to tear into it to replace the valve seals, which is easy enough to do. However, the valve guides are worn a bit more than I'm willing to live with, so I've decided to go ahead and pull the head to give it a full valve job, complete with new valves and guides.
Before I began, I shined a flashlight into each cylinder with the piston at the top of the bore, and there was fresh oil on top of all pistons. Despite the oil, I proceeded to remove the first valve spring, and verified that the valve guide was worn by lowering the piston just enough to allow the valve to move. I was able to move the piston and valve because I opted to use rope inserted into the cylinder, as opposed to compressed air, to prevent the valves from dropping into the cylinder.
After a quick glance online, it looks like a complete valve train overhaul kit will be about $200, plus the cost of a head gasket and other gaskets, as needed. I'll know more after I call my local MF dealer to price the parts tomorrow.
/ Continental Z-145 Engine #14
There 's nothing magic about rebuilding the head that requires you to go to a MF dealer. A good automotive machine shop can install the guides for you unless you have a press and the appropriate tools.They can also grind the valves and valve seats to match, check for flatness and grind if required. Get several bids before you decide where to take it. There is usually a wide range of prices for rebuilding a head.
I've rebuilt many engines and heads before, but don't have all the proper equipment like I used to, so I'm planning to press out the valve guides myself, then take the head to a local machine shop and have the new valve guides pressed in. I could press the new valve guides in myself, but don't want to risk damaging them. I'm also going to take the rocker arms with the new bushings and shaft to the machine shop to have the new bushings pressed into the rocker arms and reamed to fit the new shaft.
I may or may not have the valve seats ground/replaced by the machine shop, but won't know for sure until I finish removing the head to inspect them. Either way, I plan to lap the valves myself, just to be sure they are right. I'm picky.
As for which local machine shop to use, there is only one that I trust, which I've been using for many years. They are very good, and reasonably priced.
I was planning to wait until I overhauled the entire engine to do the head, but removing the head and doing it now will give me a chance to do many things which will be required for the eventual restoration. For example, I can sandblast and paint the intake/exhaust manifold with hi-temp paint and replace the gaskets which were leaking badly due to semi-loose bolts.
I removed and disassembled the rocker asembly. As expected, the rocker bushings and rocker shaft are heavily worn, probably because the valve lash was allowed to go without adjustment for too long.
Also, I removed the head and have begun soaking the valve ports in carb cleaner to remove the accumulated carbon deposits caused by burning excessive oil. After pouring the carb cleaner in the valve ports, I discovered that 3 valves are leaking, probably because the valve guides are worn beyond tolerances, causing the valve seats to wear unevenly.
Fortunately, the cylinder walls are in great shape, and only show minimal signs of wear, indlcated by a very slight ridge at the top of the cylinder. No noticable scratches or score marks are present.
Last night, I finally got around to removing the valve guides from the head, using a special tool I made for my air hammer.
The tool was made by tack welding a bolt, that was cut and ground to the proper size, to an old pointed chisel air hammer bit that I wasn't using. The valve guides were pressed out from the top to aviod being jammed by carbon deposits, and came out easily. Note that it was done without heating the head.
When the time comes to fit new valve guides, I will have the machine shop do it, because the valve seats must be precision-ground whenever the valve guides are changed.
I've read that the Continental Z-145 and Z-134 engines used the same cylinder head and head gasket, but wasn't sure until after I had removed, cleaned up, and disassembled my Continental Z-145 cylinder head to give it a full valve job.
While I can't be certain if the Continental Z-145 and Z-134 cylinder heads are identical, I do believe they use the same casting. Here is a picture of the number (Z134 A801) cast into the top/side of my cylinder head, above the intake/exhaust ports. The Z134 part of the number leaves little doubt, but I'm uncertain what the A801 part of the number means. Perhaps it's some sort of machining identification number.
The numbers were very faint, but the head gasket was identified with the number (Z134A 401).
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
Coats 1550 3D Wheel Balancer Machine (A61573)
Coats 1550 3D...
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
Caterpillar 740 Articulated Truck Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 740...
1993 WhiteGMC WG Tri-Axle Dump Truck (A61573)
1993 WhiteGMC WG...
