Fall protection harness
/ Fall protection harness #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
Some of the jobs sites I go on are requiring a fall protection harness if I climb over 6'. The harnesses we have are a PITA. They are bulky and heavy. I am trying to find a good lightweight harness that you can actually be comfortable and work in and still be safe. It also needs to be easy to put on and take off. If anyone could make a recommendation from personal experience I would appreciate their opinions
Bill
/ Fall protection harness #2
I wish I could help but I am afraid that anything you find wont fit all of those criteria. If its comfortable it wont typically be quick and easy and visa versa. good luck, if you find something that works well for you please let us know. I assume you are referring to a harness with a D ring between your shoulder blades. I know from when I was doing arborist work a harness that is just waist and legs is fine but when you start getting shoulder straps they get messy and bulky.
/ Fall protection harness #3
what type of work are you doing?
/ Fall protection harness #4
Subscribed. I'm pretty sure that ALL harnesses are a PITA, at least the cheap company supplied ones I've worn are. Maybe there are some premium ones out there that are comfortable?
/ Fall protection harness #5
We used to even wear them to lunch because they were such a PITA to put on and off. Add the waist D rings and belt for a waist tie off, then a tool belt attachment and then you will really cry.
I saw one at the Home Depot tool rental shack that looked a lot simpler and lighter. I have the old PITA one so had no reason to open the bag but you might check that one out.
Ron
/ Fall protection harness #6
The problem with the harneses used on construction sites is that one size has to fit all. I hate them. Fortunatelly I don't have to use them too offten.
I was thinking about mountain climbing equipment might work.
/ Fall protection harness #7
To meet OSHA for construction work they have to have the ANSI certification sewen on them) for construction use.
Ron
/ Fall protection harness #8
They make some pretty comfortable harnesses, complete with retracting trauma straps that you can "stand on" to relieve the pressure from the "family jewels" in the event you fall and are swinging for 30-60 minutes until rescue is made.
Rose Safety presented a safety day for my previous company. They demonstrated a 6' fall and the violent stop from that short of a distance (straight lanyard) - all I can say is OUCH!! No more kids after that!
They repeated the fall with a shock arresting system - HUGE difference. Of course OSHA mandates a shock arresting system now - either lanyard style or the other types.
Bottom line I took away from the demonstration, if you fall, most likely you will be suspended for quite some time. After two minutes, both legs will start to go to sleep from lack of circulation - plus the twins won't be comfortable. Serious trauma damage can occur to your legs and jewels.
Exofit makes some very good harness, easy on and off. You can get them in many different styles, with tool bags, etc. Trauma straps can be added. Depending on the model - $250-350 each. Lanyards extra. Some specialized models are $500 plus - crazy high.
http://m.pksafety.com/exha.html
Find a industrial safety supply - they will have all sorts of options. Every large city has several of these companies that specialize in safety gear.
Hope this helps.
/ Fall protection harness #9
I use the Petzl Falcon from Rock-N-Rescue. It has a detachable upper arrest harness. It's not much heavier than the sport harnesses.
I never have the upper section on as I use mine in conjunction with the Black I'D for hands-free work positioning as opposed to fall arrest. Current job is 33' to 48' up and I'm mostly hanging over the edge to work.
/ Fall protection harness #10
Miller duraflex is what you want.. I spend everyday 8-12 hour days wearing one, structural Ironworker connector.. there lightweight easy to put on and don't have all that extra garbage hanging off them like some of the others. those body lifts are nice to stand up in but your gonna be in a panic state of mind and it will be the last thing your thinking about..
I was walking the dog (not tied off) my lanyard got caught up in the cope of a beam connecting into the one I was walking on and sent me into the hole...Luckily that pelican hook was too big to go through and caught me.. and my lanyard stopped me from an otherwise 80' fall.. that miller duraflex saved my life (even if it's what put me in the hole to begin with).. I was sore for a week and permanately damaged my arm in panic pulling myself back up on the Iron from the bottom flange..
It happens so fast that you won't have time to even think!!
/ Fall protection harness #11
Bill
Check out
Fall Protection Safety Equipment
If you see one you like PM me the style and part#, I will get pricing for it. Normally we are very competitive as we ship these all over the US
/ Fall protection harness #12
Rock climbing is a dangerous sport and everyone engaged realizes the risk. Construction is a vocation you may want to continue for your living and family support.
That's why they make the ones with waist D rings for the posistioning strap. Where is your safety manager when you are using the harness w/o the upper half and not tied off to an inmovable point? Are rock climbing harnesses ANSI labeled? At least when you fall that far you probably will not know anything after you land except when you tear off all your skin on the wall, pole, or whatever you are working next to; on the way down. Listen to power linemen from the old days talk about "skinning the pole". They now use bucket trucks; including full fall restraint harness.
Ron
/ Fall protection harness #13
Self employed roofer. I've used many harnesses. Since I only use positioning, I skip the arrest. The rope would have to part for a fall. There was one time though that a shake popped out and, in harness, I hit the deck so hard I broke my arm. Go figure. And another time, while taking my safety goggles off, the elastic strap popped loose and popped me in the eye. Go figure.
/ Fall protection harness #14
I forgot to mention, I don't rock climb. Scared of heights to be honest.
/ Fall protection harness #15
I every now and then rock climb(indoor)and have a black diamond harness. I use the harness for archery also i use the Metolius Personal Anchor System to clip into my stand.
If you are looking for a sport harness look at moosejaw.com the reviews on the gear there are beliveable.
If you are looking for a more industrial harness check out ebay, there were some new in box ones that were listed, or check out forestry ones also.
Sorry I took so long to respond but things have been busy. I am a mechanic for a redi mix plant but also do the plant repairs and maintenance. We also 3 telebelts on the job that have to be maintained. Working on the plant isn't to bad but the telebelts are a pain to climb around on with a harness on. Try lying down on your stomach or back with a harness on.Here is a pic of the telebelt.
/ Fall protection harness #17
Pricey but comfortable. One of the guys I worked with had one. He was in his and out the door before I could figure out where my leg went in my old style DBI/SALA.
McMaster-Carr
/ Fall protection harness #18
Exofit is the way to go. Very comfortable and they offer click in connections. We wear them everyday while offshore and have never found one to be better.
Company pays for them so price is not object!
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
FORD F750 BUCKET TRUCK (A65054)
FORD F750 BUCKET...
