two stage clutch
/ two stage clutch #1
bigarry1
aiken sc
what is the proper way to adjust the two stage clutch properly. it slips sometime when load is applied? help. thia is a 2425 with 3 fingers.
/ two stage clutch #2
I want to know how to adjust a jenma 204. No luck so far.
/ two stage clutch #3
Not familiar with your equip. Usually a single disc (no Live PTO) is adjusted so that the pedal has to be depressed roughly 2" (measured at the farthest end of the pedal) before you feel the resistance of the clutch springs.
If no spac (if you feel pressure immediately) you have the springs constantly depressed, how much is anyone's guess and with that the backing plate pressure is somewhat released and the disc can spin.
Otherwise, you may just have a worn out disc/weak pressure plate springs, and cannot adjust it any more to get the needed pressure to hold against a load. Time for a new disc and PP.
Mark
/ two stage clutch #4
Mark
I may have misread the title. I haven't done it but have read about it in serv. manuals. Have also been told that you take it to your dealer and let them set it up for you and you get it right the first time. I know Ford dealers do that. The money you spend is well worth only one trip into the innerds to get it right.
Mark
2019 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59912)
2019 FREIGHTLINER...
17395SFL (A61568)
17395SFL (A61568)
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
Pair of Assist Wheels (A64119)
Pair of Assist...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
FORD GT95 RIDING LAWNMOWER (A64281)
FORD GT95 RIDING...
