looking at a new acquisition
   / looking at a new acquisition #11
Thats great, glad to hear it! I hope that you can get it! I also forgot to mention, on the G154, there is a small white panel below the radiator grate on the front. You can see this on my photos. Behind that plate is a second PTO, that you can use to run a belly mower, or a front pto pump, ect. See photo below. Anyways, let us know, and post some pics when you get it, My wife is the same about my "junk", and I have to ease her into each new implement, ect, I know the feeling.
Mitch
   / looking at a new acquisition #12
Does yours actually have a PTO shaft behind there, or simply a cutout in the panel from the factory? How does the pump, clutch, or whatever attach?
I did get the "we don't want to end up with a barn full of junk lecture" though so this might be the second and last tractor for a while...but implements don't count as junk right?...
I am the wrong guy to ask about that, having added another Yanmar 240 and a Ford 1700 to the "junk heap" since this picture was taken. And no, I'm not married. :laughing:
   / looking at a new acquisition #13
Wow, thats a great collection, being married cuts into that big time, trust me, I am very jealous of my brother at times who is sigle, and has many more "toys". The front PTO is interesting. There is a standard PTO shaft behind there, but it runs off of a belt that turns the fan/alternator. I have seen set ups where people use them for PTO hydraulic pumps for a loader. There was a unique looking gear box that attaches for a belly mower, and that may have a control built in? Otherwise it just runs when the engine is running. I'll have to take a picture of it. Its kind of a neat stock item.
Mitch
url
   / looking at a new acquisition #14
[snip]
That's a mighty fine "junk heap". Looks like all of them are in good to great condition. Nice. I've seen some real junk heaps that would make that look like a 2013 Mercedes showroom floor!
Also, I like the JD on the right. I have a Craftman LT1000 that I can't seem to replace yet due to some logistics with the tractors. I'm trying to get to the point of letting that one go, but I know I'll regret it for mowing. It's fast, smooth, and handles great. Unfortunately that's about all it can do well and I have other needs only the tractors can fill.
   / looking at a new acquisition #15
The only photo I have of the front of my ST1440 is this one, and unfortunately it isn't high resolution or at a good angle. It is beside my Yanmar 1401D, the equivalent machine. Both are 14 PTO hp, 2 range with 3 forward speeds, 3 cylinder engines with 3 PTO speeds.
The Satoh is slightly smaller, but the Yanmar is nearer the camera and has a loader, so the difference is not as large as it appears.
The S373D front axle looks like an identical design to your ST1440 as best as I can tell from the picture. It uses the spindle gear design.
   / looking at a new acquisition #16
Here are a couple shots of the front axle of my ST1440. As an aside, if you look in the picture above, you can see a groove under the radiator/grille. That is a pass-through for a crankshaft-driven PTO, but mine doesn't have anything other than a special crankshaft pulley to power anything. The pulley is drilled to accommodate a plate mounted to its face.
My John Deere mower is a very adequate mower. It is a 17 hp Briggs, with a 42" deck. I keep it because, as Ilikeyourtractor said, it does lawn mowing very well. It's sort of a one-trick pony, but it's a pretty handy trick. It's much more maneuverable than a tractor with a rear cutter, and much easier to get near or under trees on the grass.
The "junk heap" is relative, I know. Everything except the IH 284 is in excellent working condition, and that's honestly all that matters to me. I get regular offers from people who will "help me out" by hauling all of "those old junky tractors" off for me...:mad: I don't have for sale signs on them, and have no interest in somebody else hauling off my machines. They aren't pretty, but I like tinkering with them and goofing off in the yard; I enjoy it.
Poor Skyarkguy. I've gone WAY off topic. In that vein: Tell us about the Buick at the root of your name! :D
Hey thanks for asking...
When I was 17 I found this rundown old car. A 1968 Buick Skylark Convertible. Paid $400.00 for it if I recall correctly. Didn't have brakes when I got it etc. etc. It saw me through the remainder of high school, i learned basic, and not so basic mechanics with it. Put 2 engines in it over time, converted it to front disk brakes. Learned about paying attention after roasting an engine due to a failed 5 dollar radiator cap. It was a rust heap being from Illinois but looked good from a distance.
Because I have a hard time letting go I was still driving that car when I was 34, but had moved to Sacramento California. Renting an apartment on N street in a not great part of town. Thanksgiving weekend came and went and on the following Monday I went out to go to work and low and behold someone had lifted my car, vanished, without a trace...not even glass on the ground. I made the report and called daily to the Sacramento PD for a couple weeks. My car was gone for good it seemed.
Somewhere along the way I needed a moniker was thinking about it and came up with it. So began my on-line id. Some days I really miss the old thing, especially when the air cools after a hot day and I remember cruising along, wind in the hair, some cute girl in the passenger seat if i was lucky (so more often alone:laughing:)
I think old tractors kind of represent a similar idea. Something to fix and improve and get to know and put to good use. Similar but different. I've kicked the idea around about getting another one, but likely won't...can't rewrite that chapter.
So it goes..
   / looking at a new acquisition #18
So it goes..
Nice story, you tell it well and that last paragraph sounds true to me:thumbsup:
PH
   / looking at a new acquisition #19
[snip]
So it goes..
These older tractors have given me an excuse to buy and use tools I normally just don't have a use for. I just added a small stick welder and oxy-acetylene torch set. It's been at least a decade since the last time I've used these things and I really have been missing out and forgot how neat that stuff is. I'm looking at acquiring a small lathe soon and probably a vertical mill down the road. I've have grown out-of-touch with using these tools/machines and I see it as quite detrimental as I grow older. My dad was a welder and machinist his whole life and he could do all kinds of neat things with what he knew. I want to be able to show my sons those same things and give them an opportunity to at least get some experiences like my dad gave me. Having these tractors gives purpose to that concept. Certainly, one could pick a lot of things to pursue this with, the tractors seem to fit well for me though.
   / looking at a new acquisition #20
Amen. You're doing right by your sons, too. It's always really interesting to see how astonished the average person is when a young man is able to do things for themselves. Even if one hasn't done exactly the task at hand, a background experience in similar things can lend one the know-how and confidence to do it anyway.
Plus, it's FUN! Making things that work, are tangible, and so forth is satisfying in fundamental ways, and is a nice change from everyday, first-world life.
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2009 Ford F-250...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2013 Ford F-450 Utility Flatbed Truck (A55973)
2013 Ford F-450...
