wont start back
/ wont start back #1
heinz57
kentucky
international 500 e
i have a international 500 e dozer it was running fine today then i went up hill with it and it bogged down then i could not get it started back it tried to start but it would not i checked the relief valves the fuel filters the water catchers and the fuel pump it is a diesle but it acts like a vehicle when flooded out does any one know what could be wrong
/ wont start back #2
How much fuel is in the tank? If you are getting any exhaust smoke at all, what color is it?
/ wont start back #3
JCB 214, Perkins 4 cyl. stalled in remote area of farm.
Have check pump and have diesel at each cyl. Getting white puffs of smoke while cranking. I think this is water in fuel. plan to use a drying agent in fuel. Possible small amount of ether starting agent in air intake. Any comments.
/ wont start back #4
Sounds like water in the fuel tank. How steep was the hill and had you been up the hill previously. Possibly may be starved because of blockage in the intake tube. Rust, leaves, fungus etc....
/ wont start back #5
It could be as simple as if you were low on fuel and went up the hill the fuel in the tank flowed away from the intake ...so it stopped...try adding fuel first.
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
CASE 105C (A62177)
CASE 105C (A62177)
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
