Used My MoJackEZ For The First Time
   / Used My MoJackEZ For The First Time #1
Bird
Rest in Peace
Corinth, Texas
We talked about Sears and prices of the MoJack in this thread and now I have the MoJackEZ and used it for the first time today, so thought I'd post a few pictures. Basically, I think it's great, probably a bit expensive for something that will only be used a few times each year, but it's solid and easy to use. I removed the blade, sharpened and balanced it, put it back on, and thoroughly washed the bottom side of the deck. Then I let the mower down, and of course did not use the MoJack while I changed the oil & filter.
   / Used My MoJackEZ For The First Time #2
Buying it at Amazon most certainly saved you some money. :thumbsup: Is the lifting mechanism hydraulic?
The lifting mechanism is just like a screw jack. In the first picture, the light colored vertical piece is the screw. The crank can be mounted in one of two positions, depending on how much leverage you want; i.e., how long that crank and handle are from the top of the screw. Or you can leave it off entirely and use a drill motor to run it up and down. I mounted the crank for the short distance (least amount of leverage) and it was quite easy to crank up and down.
   / Used My MoJackEZ For The First Time #4
Thanks for the info.
   / Used My MoJackEZ For The First Time #5
Thanks, I was wondering if that might be something worth looking in to...
   / Used My MoJackEZ For The First Time #7
I use a cherry picker (engine hoist) and a chain to lift the front of my zero turn, works well and does more than just lift a mower.
Yep, if I had something like that, or still had a tractor with a front end loader, I wouldn't have bought the MoJack.
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
2025 CATERPILLAR 265 SKID STEER (A51242)
2025 CATERPILLAR...
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2015 TRANSMASTER LOWBOY TRAILER (A51222)
2015 TRANSMASTER...
