3pt hitch downward pressure?
/ 3pt hitch downward pressure? #1
2001 JD4110
Wheatland,NY
JD-4110
I'm kinda new to it all but is there any downward pressure on a 3pt implement or do we rely on the weight of said implement? I guess I'm thinking for "diggin deeper" I need to get something for a new lawn/construction for sis, the yd.has sat thru winter so it's well packed(good) but needs loosening for any leveling/filling in and raking. I was thinking of renting an old 6' disc harrow, then buying or renting a backblade or boxblade for moving? Then raking. What do you guys think of my plan? Thanks:thumbsup:
/ 3pt hitch downward pressure? #2
Just the weight of the implement. I use a box blade and tiller for what you mention. On compacted soil, you need a really heavy disk to accomplish much.
I believe Jenkisph has a lot of experience with this if he doesn't show up, you might contact him.
/ 3pt hitch downward pressure? #4
If the box blade has rippers then the weight of the implement is sufficient to drive the rippers into the soil - if at the right angle and the ground is a bit damp.
Multiple passes will get the ground chewed up enough to allow you to move the soil around to where you want. The box blade can be used for leveling if you get the angle just right.
Back dragging a FEL bucket can work well for leveling, too. Once again, it is the angle that makes the difference.
As you might infer, it takes experience to get things where you want them. The best thing to do is to go out and get the experience by doing.
/ 3pt hitch downward pressure? #5
Many recommend using an herbicide to kill the existing grass and cut down on the clumps you have to deal with, I usually just mow it down as low as I can get it then work the heck out of it. For final leveling dragging something like chain link fence, tires etc. will help. Of course a dedicated drag works best, but they are expensive.
As gwdixon says, it takes experience and the good thing is if you mess it up, you can start all over again; done it plenty of times. Don't get discouraged when it doesn't work quite right the first or even second time. If I can ever get it just right the first time I am going to throw a party.
/ 3pt hitch downward pressure? #6
Hot ****! We'll all attend cuz it'll be the only one we ever get! :laughing:
/ 3pt hitch downward pressure? #7
I would till it about four inches deep if the ground is fairly smooth or up to eight inches deep if I need to move lots of soil. I would then plane it smooth or use a blxblade to smooth. If I had to scrape deeply to get everything smooth I would then go back over everything with a tiller.
With the ground all tilled and smooth I would run either a spike tooth harrow, pine straw rake or chain link fence for a final finish. Broadcast the grass seed heavily and rake in preferably with a spike tooth harrow or pine needle rake. Make sure you go ver it enough to cover the majority of the seed. Last roll the surface with a water filled roller.
I generally water about 10 minutes every four hours for the first two weeks to get a good stand of seedlings. I will gradually increase the sprinkler run time while decreasing the watering frequency. After two months of growth I will water once every other day. After four months I water about once every four days for two hours sprinkler time. If you get a good rain you can delay the cycle.
I would also recommend starter fertilizer and Ironite be used when you plant. Get a soil analysis to determine what you really need to add.
I never heard an answer to the question as to whether this yard was covered with sand or not.
/ 3pt hitch downward pressure? #8
not just weight.. but the angle of attack will provide some 'vacume' to help ground engaging tools to bite.. etc.
down pressure on small/med/and small-large tractors is uncommon. counterproductive for the scut/cut's usually.. unweights the traction wheels.. :)
/ 3pt hitch downward pressure? #9
The easiest way to loosen the soil down to 7 or 8 inches is a rotatiller. They weigh 400 or 500 lbs. and provide their own "down pressure". After you loosen things up a plain old scraper blade will do the job.
Hey Thanks for all the replies! I'm not sure what the soil is like and I don't think my sis would have a clue?
/ 3pt hitch downward pressure? #11
talk to a local extension agent to find out soil types in your area..
I'm wondering if I might be able to get the job done with a 4' boxblade and a york rake? Using the bb instead of using a disc harrow(which I don't even own anyhow)?
/ 3pt hitch downward pressure? #13
I'm wondering if I might be able to get the job done with a 4" boxblade and a york rake? Using the bb instead of using a disc harrow(which I don't even own anyhow)?
First of all, a 4" (inch) box blade is awfully small. Something larger would make the job go much faster.:laughing:
The tines on a box blade will work fine for tearing up the ground. It will look like a mess until you level it out. Hard clods and old dried sod will be your enemy.
You will find that a york rake, if used for leveling, will pick up clumps of anything, sod, roots, leaves, etc. and fill up much like a box blade. The soil needs to be very fine for a rake. A rototiller can accomplish this. (Some people swear by a rake for leveling gravel but usually there is a pair of training wheel involved.:) )
You can forget about a disc if you don't have access to one. The tines will work well enough for the job you want to do.
Oh that sounds great! last time I did a yard was mine 20 yrs.ago!My neighbor disc n drag it and I used a 3' or 4' pull behind york rake on a Bolens 10hp I had..and killed lol! I did my 3 acres, what a chore! This should be alot less demanding, though I do worry about the unknown-Tree roots evidently this was previously a treed lot..:( I suspect we may have a bunch of roots to contend with. This should be a good challenge to get 'er done in 2 days..:confused2: It'll be a good experience for my son too!:thumbsup:
2020 FORD F-150 XL EXTENDED CAB TRUCK (A64276)
2020 FORD F-150 XL...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A61572)
2018 Roadtec...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
43018CFL (A59228)
43018CFL (A59228)
