Buying Advice Kubota bx25 vs mahindra max 25
/ Kubota bx25 vs mahindra max 25 #162
I needed a post hole digger for the bx 24 and a full size cat 1 will not fit on the bx24
I will give you that, a Cat 1 PHD will not fit a BX, but Kubota is marketing a cat 1 hitch - NOT a Cat 1 limited hitch. Deceptive advertising. We should alert prospective buyers.
/ Kubota bx25 vs mahindra max 25 #163
And as I said in the other thread, Kubota classifies their BX series as a Cat 1 full 3PH. This leaves that Kubota is playing the same 'deceptive advertising' campaign either by not saying it's a limited, or by not classifying it as a CUT.
Full as in width(at one time Kubota had a narrower hitch that wouldn't accept full cat 1 implements)........not lifting height.
Theres the difference
The videos at everything attachments will explain this further if you are still unsure.
/ Kubota bx25 vs mahindra max 25 #165
Maybe your confused. Kubota never uses the term limited in any of their literature. Therefore they either a) have a Cat 1 hitch, and are now considered a CUT or b) are using a deceptive advertising scheme that shows their product has full cat 1 versatility while they do not. Which is it?
/ Kubota bx25 vs mahindra max 25 #166
I am also going to speak up about Massey and Kubota adding their power steering pump output to the main hydraulic pump out put to make there GPM output look better. Seems kind of deceptive to me.
/ Kubota bx25 vs mahindra max 25 #167
read posts more carefully......me thinks you may have missed something.:)
/ Kubota bx25 vs mahindra max 25 #168
As I stated in another thread, the clearest defining line between the subcut, and the cut, is the lifting height of the 3pt. hitch.
A subcut, generally takes specially made implements to deal with the low lifting height of the 3pt hitch.
The Max series with tires that are 3 inches higher(4 in the case of ags), will allow the use or full cat 1 implenents. Making the Max series a Cut, not a subcut.
So the FTTB that gets suckered into buying a Max by evil conspiracy propagated on the public by Mahindra is also going to have to deal with the problem of using standard implements? When will this terror end?
More seriously Don, you mentioned that your property or needs required a SCUT as you define it. In what manner for your particular use would the Max 25 not work? Is it a dimensional issue? Would it be too heavy? This is a serious question and I'm hoping you answer absent regurgitating your mantra about Mahindra not making a SCUT.
/ Kubota bx25 vs mahindra max 25 #169
That is not the discussion at hand, we are discussing the Mahindra max, and the classification of it as a subcut, when the specs show it as a cut. And the fact that it is unfair to compare to the BX25, which is a subcut.
Nothing more, nothing less.
And you, as a dealer, have access to the specs. and should be investigating the facts of the machines in question.............before running your head in an open forum.
/ Kubota bx25 vs mahindra max 25 #170
This is a picture from Kubota's website. Unless I'm blind, I don't see limited.
/ Kubota bx25 vs mahindra max 25 #171
And the title of the topic is kubota vs mahindra max..
/ Kubota bx25 vs mahindra max 25 #174
still not reading posts correcly i see..........
/ Kubota bx25 vs mahindra max 25 #175
Here is what I see:
Versatile Category 1 3-Point Hitch
Put your BX-Series to work with its Category 1 Three Point Hitch. This sturdy, hydraulically controlled unit allows you to attach a wide array of rear implements.
Can you show me where they claim a Cat 1 limited?
/ Kubota bx25 vs mahindra max 25 #176
It's in here, right? Oops. Kubota deceptive advertising campaign claims a false statement, again? Maybe they are CUTs and Mahindra is fairly comparing!
/ Kubota bx25 vs mahindra max 25 #177
I'm e-mailing you some glasses so you can read post #163 a little better.:laughing::laughing:
And after reading that.........head on over to everythingattachments.com and do a little research.
/ Kubota bx25 vs mahindra max 25 #178
Done. Last I checked EA was not related to Kubota, though. So they further prove that Kubota is deceptively advertising their product in a way that will mislead buyers.
/ Kubota bx25 vs mahindra max 25 #179
This is my interpretation of the classifications
Limited cat 1 hitch= sub cut
Cat 1 hitch= cut
Cat 2 hitch or lager = Ag.
/ Kubota bx25 vs mahindra max 25 #180
Done. Last I checked EA was not related to Kubota, though. So they further prove that Kubota is deceptively advertising their product in a way that will mislead buyer.s
Please don't allow facts to muddy the waters, Don is already having enough difficulty maintaining his composure and credibility Martian. He was actually trying to sell waterfront property in Nevada last night.:confused2:
New/Unused 3 Point Ball/Flat Hitch (A61166)
New/Unused 3 Point...
2016 Chevrolet Tahoe (MPV), VIN # 1GNSCBKC8GR280685 (A61165)
2016 Chevrolet...
2026 Steel Pines Cargo 8.5x20 Enclosed Trailer, VIN#7FWBE2021T1037982 (A61166)
2026 Steel Pines...
New/Unused Solid Backing Plate (A61166)
New/Unused Solid...
2021 John Deere 6110M Tractor (A63109)
2021 John Deere...
208315 (A58376)
208315 (A58376)
