Lawn Striping Attachment
/ Lawn Striping Attachment #41
Well I built this lawn striper like yours and was so excited to use it.
After mowing I can honestly say that my yard looks the same as it did before. I am wondering if I am mowing too low or if this is more effective with a mulcher. My grass is bermuda, does that make a difference?
Love the idea of having the yard striped.
/ Lawn Striping Attachment #42
After watching this subject, I decided to make one also. I made it to fit in the receiver hitch I made for the 3 pt. I also added limiting chains to set the height of the stripper when the mower is in the float position.
Hootie,
Did your striping attachment ever work out? Just curious... i've been "away" for awhile.
/ Lawn Striping Attachment #45
I know this is a very old thread but great into... i plan on making one that mounts to the rear of my rear mount mower.....
/ Lawn Striping Attachment #46
My guess is they get those exotic quilted affect with a fertilizer spreader and not just with a roller. I would think the "turn-around" at each end of the lawn would look silly with a roller unless you got off the tractor and lifted it off each time you turned around.
My mowing method is to top lawn off just before the dandelions go poof-whether it needs it or not.
/ Lawn Striping Attachment #47
Since this one got dredged up again, I'll throw in my two cents. Bear with me:
1)Given that a blade of grass has a "v" shaped cross section....and
2)Given that we've all seen what hapens to the grass around a parked mower with the blades going ( the suction bends the grass blades for about an inch outside the deck in towards the deck)...
The "Golf course/landscaper look" with alternating light/dark stripes is caused by the suction of the deck and the "aerodynamic" v- shape of the blades of grass. The light stripes you see are because as the mower continues down a row it bends all of the blades of grass over AND orients the V-shaped blades in one direction. The underside of the grass blades (like many tree leaves) is lighter that the tops, thus the light stripe.
Broom devices and even rotary sweepers may bend the grass but can't orient the "V" and won't create stripes nearly as dramatically as more suction....get high-vac blades if you want more distinct stripes!
Setting your mower 1/2 inch higher will emphasize it too!
/ Lawn Striping Attachment #48
There is a really good reference book for turf care and striping. The author is a master groundskeeper for Fennway park. He has actually turned the striping trend into an art.
I have always loved lawn stripes. This summer I finally got a decent mower, John Deere Z-track 737. I've been working on a striping kit. John Deere sells one fro my mower but is about $350. Basically is a small (2" or 3") roller mounted at the rear of the deck. From my reading and research the small roller work best on super smooth lawns. The kit I'm making mounts were the roller mounts but will be out of rubber flap. I must say my Z-track does stripe well with out a kit but you see a more defined stripe created by the tires. That's what I'm trying to get rid off.
One thing about striping is that after mowing a few times your will get a memory stripe which will make the stripe stick out more. Just be sure break up the mowing pattern (every other mow) so you don't create "tire rutts" due to the mowers weight.
Things that effect stripe quality:
-Grass type and quality
-Grass moisture content
-Mower deck design, ie. blades speed, deck depth (vacuum)
-clean under side of deck, more vaccum
-cut height
-deck pitch
/ Lawn Striping Attachment #49
I've been planning my own stripping roller for a while. I wanted something that will go on my quickhitch so I can lift it or lower it. Here's what I've come up with. It should be done next week. Total cost will be about $150.
The wheels are from a boat trailer. I got "blemished" ones for a steal.
I'm just using 5/8 steel rods for the axle and support, shaft collars to hold everything together and PVC pipe sections & washers to keep the wheels from rubbing against each other.
/ Lawn Striping Attachment #50
The mutiple wheels are a good idea, they assist when turning.
Some of the commercial systems I've seen are spring loaded to apply more pressure. They also use a lever so you can "turn off" striping, such as when you are repositioning, turning in the same spot, etc. etc.
If not too much trouble, do a stripe-job and show us how it works! ;)
A friend of mine mows with walk behinds, as a side business. He says it works best on taller grass (3+ inches) and especially a day after a good rain, he says the grass and ground is more pliable and tends to hold the "bend" better. He said you are not only rolling the blade of grass, but, if done continuously (Same pattern each time) it applies pressure to the soil on the Up-Roller side of the grass blade, making it always want to tend to bend that direction.
On the other-hand, my dad always taught me to mow in different directions each time, he said: 1. it was better for the turf, 2. you didn't drive in the same lanes all the time compacting the soil , and 3. it kept you from going insane.
Well, for me, 2 out of 3 ain't bad. :D
/ Lawn Striping Attachment #51
I too like stripes :D
Our mower has a built in striper. The mower deck chucks the clippings out in a windrow behind the mower.
There is then a collector that you can raise and lower separately that is mounted behind the tractor. It has a brush to sweep up the clippings, even when they are wet :) The sweeper also has a roller that gives you the stripes.
I always lift the collector when turning or reversing. Next time I mow I will get some pictures.
/ Lawn Striping Attachment #52
robertm said:
Has anybody made a striping attachment for their mower to make those pretty alternating "light-dark-light" stripes in their yard when they mow? I have a B7500 with the 60" MMM and am thinking about a new way to do it.
Kubota offers a striping kit for their ZD mowers, nothing for the mower like you have. But since it is just a roller design, it looks like a roller designed for 3 point hitch would work.
/ Lawn Striping Attachment #53
The only time I got stripes in the lawn was from too much fertilizer using the push drop spreader. All the runs up the hill were slower than the ones down the hill, leading to green and not so green strips permanently showing.
jb
/ Lawn Striping Attachment #54
Ok, The lawn striper project is complete!
I finished collecting the components and cut the PVC bushings to size.
I'll post some pictures after my grass comes in. I know...cart before the horse!
/ Lawn Striping Attachment #55
I just picked up a Ford 918L flail mower last week, Will the rear roller on it stripe the grass?
A friend of mine owns a race track I help him cut the grass there would be kinda neat to stripe it for special race occasions........
/ Lawn Striping Attachment #56
It should do but if the grass is long and you are not colecting it the stripes might get covered over by grass cuttings.
Anything that folds the grass over will leave a stripe, stripes are just when the grass reflects the light in a different way.
/ Lawn Striping Attachment #57
Well, Today was the first cut with the striping roller and I think it turned out OK. It is a little bit of a pain to have to lift it at the end of every row, but once I did it a few times it became second nature. If I were to build this project again, I would use something a little heavier than 16ga sheet metal for the plates - although it does make it quite easy to fix things if they get a little bent up.
/ Lawn Striping Attachment #59
Good plan. But, if you want real stripes, get a reel mower. A fairway mower is the way to really make your lawn look like a fairway. I use a Toro Reelmaster 5100D, (8' cut).
You could cut that lawn (above) in about 10 min.
/ Lawn Striping Attachment #60
Guy's check out the Ventac with Finnish mower , We sell to alot of colleges for sports fields . Ventrac.com
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 INTERNATIONAL...
2013 Nissan NV2500HD Cargo Van (A61573)
2013 Nissan...
429888 (A61165)
429888 (A61165)
JCB 510-56 TELESCOPIC FORKLIFT (A64279)
JCB 510-56...
(1) 23X8.50-14 TIRE W/ 6 LUG RIM (A64280)
(1) 23X8.50-14...
