Front-End Loader tooth or stump bkt
/ tooth or stump bkt #1
lastborn
Member
Clemson sc
Kubota B3200
This is what I have.
Kubota B3200 hst 4x4 with R4 tires {loaded} with LA-504 loader
Here is what I want to do.
I have 3 acres of pasture that Bradford pear trees { 2" to 4" dia. at base} are taking over.They have very large thorns, therefore I do not want someone to come in with a brush shredder and scatter the thorns all over the pasture for me to get a lot of flat tires while bush hogging afterward. They are tough to just pull up with a chain, I can do it but it will take a long time. { I don't have }
QUESTION: would a toothed bar make this any easier/quicker?
Would one of those stump buckets be better suited for the task?
We are talking 300 to 400 trees here and I have 3 kids that are into everything, baseball,softball,cheer leading etc...... and I also have to haul the tractor back and forth to the site every day. How would you approach this? EVERYONE is invited to express there ideas, experience and expertise.
thanks
/ tooth or stump bkt #2
Are you able to push them over by putting your loader against them & pushing? I'm not familiar with that kind of tree. (Edit: Some trees are rigid & therefore push over popping the root ball up, whereas others are too soft & just bend over. Which are yours?)
I have removed many trees this way, root ball & all.
I don't think 300-400 trees is gonna be quick, though, no matter how you do it.
/ tooth or stump bkt #3
Well I can tell you a tooth bar certainly helps with digging, but probably not for your purpose though. I have a stump bucket on a larger tractor which narrows down your digging width vs. your loader bucket which would provide more pressure. As far as that goes, you'll just have to try it. I would cut the trees so that you leave about 4 to 5 feet of the stump above ground. That way, if a stump bucket doesn't work on the bigger ones, you then have leverage with a chain to pull on them.
HP
/ tooth or stump bkt #4
Yep....300-400 trees isnt going to be quick without an excavator or dozer.
I agree to try to push them over. A little leverage goes a long way when uprooting a tree:thumbsup:
As to the stump bucket vs toothbar/teeth.....
I think I would try the toothbar or bolt on teeth first. They are cheaper and can be used SOO much more after the trees are gone.
While I have no personal experience with a stump bucket...my take is that they probabally wont be as effective on a smaller machine like you have. For starters, not enough weight to effectivly dig/push under the root ball. Plus, the buckets are much longer, so that will reduce the amount of force you can generate with your lift and curl.
Have you considered renting a mini-excavator for a day or two?? Probabally cost less than a stump bucket and would be MUCH more effective. Get them out of the ground and worry about clean-up later with your B. At only a 2-4" tree, I cant see it taking more than a minute or two for each tree. If they arent too far from each other, I would think you could do it in a day with a mini-ex. Two days at the most.
/ tooth or stump bkt #5
Before spending money I'd do like someone else suggested and try knocking them over with the bucket then get under the root ball. I have a similar sized tractor and have taken out dozens and dozens of 2-4 inch trees. Average tree probably takes a couple minutes. Plus you don't have to get off tractor. Works slick! At least try this method if you haven't already. I can take out trees way easier this way then with a chain.
I would try this before you cut them down, you need to hit the tree pretty high up, sometimes I go like 6 feet up.
/ tooth or stump bkt #6
That is the way I do it!
Part of the problem is they will push over but, the root ball doesnt pop up to give you something for the bucket to get a hold of. It rained here yesterday a good bit and I hope I can get over there this weekend and try it with the ground wet.
Thanks
/ tooth or stump bkt #8
Thanks
As you alluded to in the beginning, maybe a different style bucket.
/ tooth or stump bkt #9
Thanks
A tooth bar on your bucket is really helpful for getting under them and popping them out and also gives you a little more holding capacity for throwing the trees on your bucket and moving them to the burn pile - it has many other uses as well.
/ tooth or stump bkt #10
I have a toothbar on my bucket and the problem I have taking up even tiny trees is that the bucket is to wide making it difficult to get under the roots. You could take a chance and spend the money for a root bucket or tree spade but I don't how well those work on a CUT. With 300 - 400 trees I would think about renting an excavator... But that could get costly too with so many trees. This one is kinda pricey but there are similar less expensive ones out there. Again, I don't know how well these things work on a tractor.
[ame=http://www.youtube.com/watch?v=JYfHQ-U1wgU&feature=related]SkidSteer Tree Spade, FFC 36" Tree Spade - YouTube[/ame]
/ tooth or stump bkt #11
I bought the grapple bottom below, which has long tines you can jam into the ground below the roots, & then try to lift (usually doesn't work), or instead pry:
Set the grapple bottom at about a 45-deg downward angle, push the tines under the roots ... if possible push down to the point where the front of your tractor is off the ground, so you can use its weight to help pry ... then curl the bucket. The weight of your tractor should push down on the back of the grapple bottom & curling your bucket will allow the tractor weight to pry up under the roots.
I got the 72" wide model, but if I had it to do over, I'd get the 60" model. And usually even the 48" would work, but I also use it to haul debris around, where wider is better.
/ tooth or stump bkt #12
LB
A few years ago I bought a toothbar 72" and a stump bkt. from Markem for my 6000lb machine. The tooth bar Is a very good investment for The $.At the time I had 5 arces of thorny crabapples to clear. I found it better to cut the bigger trees 4-6" dia.and doz/ push the roots .Sometimes I had to scratch um up with a bh. I had thought a stump bucket would be useful too... but as it turns out no so much for this task. I've found that my stump bucket is excellent at trenching a ditch ,trans planting single bushes & small trees . furrowing etc. but not land clearing. I've used pallet forks especially the ones Brick/masonary companies use and do what Beppington said.
Most recently I've built a grapple for my toothbarred bucket on the front and built a box blade/ ratchet rake combination on the TPH . This is what I'm currently using to clear ground ....
Ak9
/ tooth or stump bkt #13
Dustin, I don't know for sure, but, just guessing, I probably don't have enough tractor to operate the woods. Thanks for the info though.
New/Unused 72in No Till Seed Drill (A61166)
New/Unused 72in No...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2019 John Deere X380 Lawn Mower (A63116)
2019 John Deere...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
Clark C500-YS80 Forklift (A61166)
Clark C500-YS80...
