Issue with loader on B2320
/ Issue with loader on B2320 #1
TigerfaninAR
Gold Member
Central Arkansas
Kubota B2320 FEL, MMM
Put the loader on tonight to use the ratchet rake like I've done 50 times. Worked it for about an hour and when I curled the bucket up to get rake out of the way and lower the bucket all the way down to park, the bucket hits an abrupt stop about a foot or two off the ground while lowering it down. Guess I didn't notice while using the ratchet rake because the bucket is never lowered that low while using the rake. Very light easy work tonight just finishing out some topsoil that I spread a few days ago. Never hit anything that jerked or stopped the tractor.
You can raise and lower, curl like usual until you lower it to that same spot. Feels like you've hit bottom but you are a foot or two off the ground.
I looked as best I could but was getting dark so will tackle it tomorrow. Besides taking off and reinstalling any other thoughts?
/ Issue with loader on B2320 #2
I would check the quick connects, undo them and re-seat them.
Also, check to make sure the three point hitch is in neutral. I read on here that sometimes they are just enough in the raise position to divert flow from the FEL, if that makes any sense.
Let's hope it is as simple as one of those points.
/ Issue with loader on B2320 #3
I agree.
/ Issue with loader on B2320 #4
3PH in neutral? How the heck do you place 3PH in neutral? Do you mean make sure it's not raised all the way up in case it's set to high causing relief valve to open? The 3PH is either up, down or somewhere in the middle.
/ Issue with loader on B2320 #5
Meaning.... Make sure the lever isn't stuck in either the up or down position, as it is want to do sometimes. I believe it to be the plastic, friction condom on the lever shaft that causes it to get "stuck" once in a while.
The 3 pt works against the FEL. When I'm clearing snow, I'm working the FEL joystick while also working the 3 pt lever for the back blade. Sometimes, if I do not center the 3 pt lever, (neutral) the FEL cannot respond.
/ Issue with loader on B2320 #6
The 3ph lever will stay forward (3ph dropped) on mine if I push it forward and don't pull it back to the center (neutral) position. I'm convinced that is what they mean.
Problem solved.
3 pt hitch was fine and had no bearing on loader going all the way down.
Curled bucket up just enough to remove pins and reinstall-- had no change.
Then I took the loader off completely except for unhooking the hoses. When reattaching I had to back the tractor up a bit for it to slide into position perfectly. That was it. Guess I jammed it up a bit. My 9 year old was with me and probably watching/listening to him and not paying as much attention as needed.
Appreciate the help, always good when you have that sinking feeling and its not correct.
/ Issue with loader on B2320 #8
Yeah, that is correct, and I believe this is an intended sort of "float". Since the 3-pt never has down pressure, leaving the lever in this down position would also eliminate up-pressure, and theoretically let it float either way. I discovered this by accident when operating a box blade -- it comes in quite handy in that scenario.
/ Issue with loader on B2320 #9
I'm confused, I'm just not understanding what you guys are explaining. I don't understand how a 3ph is in neutral. If my lever is down, then my implement will be on the ground. Chances are your really not going to be using the FEL while a implement is dragging the ground. If the lever is up, then implement is raised. Somewhere in the middle then the implement is somewhere in the middle. How can it be in neutral? I can see the 3pt affecting the loader if the raise adjustment is set to high causing it to go into relief thus affecting FEL operation.
I'm trying to understand this because at times I think my FEL is weak and I want to make sure my 3pt is not affecting it.
/ Issue with loader on B2320 #10
If the 3PT lever is stuck in the raise position it is calling for pressure and can hinder loader function. If it is in the middle(neutral) position or the down position it is not calling for pressure and should not affect loader control. The 3PH as I understand it is in the power beyond series circuit which by default is first come first serve. With position control you can choose where your implement will be with the range of the lever. 1/4" inching control has a neutral position. I apologize for any confusion my previous incorrect post has caused.
/ Issue with loader on B2320 #11
If the 3PT lever is stuck in the raise position it is calling for pressure and can hinder loader function. If it is in the middle(neutral) position or the down position it is not calling for pressure and should not affect loader control. The 3PH as I understand it is in the power beyond series circuit which by default is first come first serve. With position control you can choose where your implement will be and then put it in the neutral position to hold it there. THAT is the neutral position function.
That helps, I guess its basically how I was interpreting it, that if the 3pt is set to raise to high and its still calling for pressure then it can affect loader performance. Another member had this issue with his M7040 because his 3pt was still calling for pressure even though it reached the utmost raised position.
/ Issue with loader on B2320 #12
Ahh, you have position control right? I'm trying to remember how the 1/4 inch valving was on my B3200. I think the lever would return to center after raising or lowering. I can now understand this being "neutral". I had position control stuck in my mind. Couldn't see how position control could have neutral :laughing:
/ Issue with loader on B2320 #13
You are correct, position control does not have a neutral, it is infinitely adjustable within it's range of motion. Can you tell I use my B7800 more than the L4350?:laughing: What can happen and it did to me was that the upper stop on the position control was not set correctly and when the hitch was in the top position it was still wanting more hydraulically. Perhaps this may be the problem. After I adjusted mine that problem went away.
/ Issue with loader on B2320 #14
The 3 pt lever can "stick" in the up or the down position. I wish it "self centered" better, but it often does not. Simply put, it sticks sometimes. When it does, it pre-empts, if that is the word, the power, leaving inadequate flow to the FEL or at least bothering it considerably.
It's all just the "nature of the beast". You get used to and recognize immediately what's going on. Use the 3 pt in conjunction with the FEL, as in moving snow, and you find this happens often enough. You instinctively check the 3 pt lever, center it, and go right on with your work. No big deal, once you realize what's going on.
I got another one for you guys. How many of you have been looking back at what you're doing and your knee accidentally forces the FEL joystick at your hip? Next thing you hear is your FEL dragging the ground. :eek: I hate when I do that.
/ Issue with loader on B2320 #15
On my 2920, there is a linkage attached to the 3-point that presses the control lever back to center if you raise to max height. So, you can never get in a situation where it sticks in the up position, which would be bad (and use up hydraulic pressure). Maybe you can adjust the linkage to prevent yours from sticking in the up position.
There is no centering linkage for the down position, but it's not really an issue there because it's not affecting hydraulic pressure. Thus, if you leave the lever all the way down, whatever is on the 3-point can float under its own weight, since it is not being opposed by hydraulic pressure in either direction.
/ Issue with loader on B2320 #16
Good to know! The "sticking" is mostly caused by the rubber sheath, me thinks. So darn busy this time of year, I haven't taken the time to fool with it, but I will.
/ Issue with loader on B2320 #17
Ahhh...I'm flipping through this thread to see why the OP's bucket is stuck and learn why my loader seems a bit weak at times....my 3ph may be up and calling for fluid.
Dang, I love this forum!
/ Issue with loader on B2320 #18
I have an issue on my2320 3pt,,, It costantly leaks down,, will not hold position??It has been to dealer, and they diddn't fix problem,, It has 144 hrs,,Rhinehart Rome Ga. said there is nothing wrong with it,, There is no detent postion,,either up/down... no hold at any postion of lever ?? Any one else with this problem >>>
/ Issue with loader on B2320 #19
Welcome to TBN.
It would be much better if you started your own thread with this issue. It would get more attention than being tagged onto the end of this one.
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
