Buying Advice Kubota bx25 vs mahindra max 25
/ Kubota bx25 vs mahindra max 25 #121
I suppose if there is a pin with no bushing, sort of obviates the need for any zerk anyway.
/ Kubota bx25 vs mahindra max 25 #122
/ Kubota bx25 vs mahindra max 25 #123
I'm specifically referring to the application where a pin is supported only by a thin (3/16" for example) piece of material. Sure grease will help here too, but with a bushing, you have a much more effective surface area to hold grease. w/o a bushing, grease won't have much chance of staying put.
/ Kubota bx25 vs mahindra max 25 #124
Pins are fixed and do not need grease between it and the housing bushing. The pivot area does and this is the cylinder rod end and the loader arm bushing. The pin bushing gives a larger surface area to absorb the forces incurred when using the bucket/loader. Not having a bushing there invites premature wear. Mahindra may have seen it unnecessary because they have a 3 point pin mount and concentrate that force on one side of the loader bracket. Probably a cost cutting measure, how I am not sure, seems to be a more costly pin to make.
/ Kubota bx25 vs mahindra max 25 #125
You get one point for using a cool word, "obviates". But the pin does not rotate in the bucket, so it only needs to be able to stay in place, hence no need for replaceable bushings or grease between the pin and the bucket. The cylinder rod end rotates around the fixed pin and that is where we need grease.
On the ML205 for the Max 28, the pin is drilled, then cross drilled, so there is a zerk in the end of the pin making it super easy to grease. On the ML202, the rod ends are drilled, which is more traditional. I prefer the ML205 sort of pin as it allows really quick greasing without raising or lowering the bucket trying to get a straight shot at a zerk as you have to do on most loaders.
/ Kubota bx25 vs mahindra max 25 #126
OK, I see what you're saying- the pin I was looking at don't rotate in the plate. Thanks for clarifying this for me!
/ Kubota bx25 vs mahindra max 25 #127
I have been leaning towards the Mahindra but only because of price. Cash price OTD for a Kubota B2620 with FEL and 50" land pride tiller is $2724.00 Thanks
The way everyone talks, I figured there would be more of a price spread than that
The Max 25 has 15 inch rear tires for turf and industrial, you posted the ag tire size. The 9.5 and 8.3 is the tire width.
But I do agree that the Max 25 specs closer to the B series Kubota.
The MAX25 AG tires ARE on 16" rims....just like the B.
Kubota doesnt list rim size for R4's or turfs. (anyone out there know). But even so, the max only drops to a 15" rim on the R4 and turfs. Certainly not like the 12" rears like the BX.
/ Kubota bx25 vs mahindra max 25 #128
Seems like $2724 is a pretty big spread when the quality of the items are very arguably similar. In a "blind taste test" I think many people might chose the Mahindra over the Kubota, so you really can't expect it to be much less. Mitsubishi and Kubota both have to deal with a fairly expensive labor force and a very poor dollar to yen exchange.
You can argue a more mature and plentiful dealer base for Kubota and that has value. You can argue a history of good resale and market pentration by Kubota, and that has value as well. But if you go to just the tractors, and assuming you have a decent Mahindra dealer in your area, prices should be very similar. And our dealer base is growing nicely and many of our newer dealers are experienced dealers that sell a major brand as well as Mahindra. So we are growing up in that way as well.
But as I scold you a little for looking through orange colored glasses, I'll concede I am biased as well! :confused2:
/ Kubota bx25 vs mahindra max 25 #130
I thought Mahindras were built in India Dave??
/ Kubota bx25 vs mahindra max 25 #131
All 15/16 series and Max models are built in Japan. I've been to the plant as a guest of Mitsubishi and Mahindra with a group of dealers a couple years ago. Fun trip.
/ Kubota bx25 vs mahindra max 25 #132
Yeah, well they did the pins that way on my 7520 and they will break at the cross drilling weakness. Not a good choice for cyl rod end pins. The force is too intense at the midpoint on the pin.
larry
/ Kubota bx25 vs mahindra max 25 #133
larry
Never seen that happen, but a drilled pin would be weaker if not sized correctly. I have seen large backhoe pins drilled like this also. Did you break more than one? We've not seen any break.
/ Kubota bx25 vs mahindra max 25 #134
Actually, they do.......and I quoted them. 16 inch for all..........the Mahindra has the 2 different sizes: 16 for ags/15 for industrial and turfs.
And I further would like to concede that LD1 is correct:
Mahindra is falsley advertising their product, and as such.........I will be one of the foremost proponents of 'truth in advertising'
So before you dealers get your bowels in an uproar............advertise your product correctly..........understood? ( and if you have a problem with me telling the truth......take it up with YOUR manufacturer)
The Max series is a CUT tractor......NOT a subcut as advertised!!!!
/ Kubota bx25 vs mahindra max 25 #136
Well said and thank you:thumbsup:
/ Kubota bx25 vs mahindra max 25 #137
Don where might one find the definition of a SCUT?
One place might be in the specifications from other manufacturers.
Compare the specs of the Max 22, and the Max 25 to the Kubota B2630( as LD1 suggested).
Then just for kicks, compare Mahindra's 1816 and 2216 to all the above tractors. That will really be an eye opener.
Mahindra doesn't make a subcompact tractor.
/ Kubota bx25 vs mahindra max 25 #139
Could be its slightly different on the 7520/ ML275 SK combo. The narrow eye on the rod end bears directly on the center of the 1-1/8" pin. The pin is cross drilled in the center and lightly grooved circumferentially:eek: to let grease spread. - A perfect stress riser. - I use it pretty hard. It broke at about 900hrs. I replaced both sides with solid pins and set up greasing thru the rod eye.
larry
/ Kubota bx25 vs mahindra max 25 #140
larry
The narrow eye on the rod end is the key I bet, the load needed to be spread out wide I'd think, toward where the pin was supported on it's ends.
