new X728 !!
/ new X728 !! #1
glgeek
minnesota
X728
pretty exciting !
geek
/ new X728 !! #2
very exciting. Very nice too! what kind of work are you planning on doing with it and what attachments do you anticpate on purchasing in the future
/ new X728 !! #3
just curious, what all do you plan to do with your new toy? Looks like you are about to enjoy some seat time soon.
SI2305
/ new X728 !!
Yes, it is exciting.
Been 17 years since my last new tractor.
I have a few neighborhood driveways I do in the winter. I love blowing snow.
We also have about 2 acres of windfall from last summer I have to clear. Was a strange year. So much water in the ground the trees just fell over. And this year we are looking at a drought. Hardly any moisture this year.
There is an 820A tiller in my garage to be swapped out for a rear mount.
geek
/ new X728 !! #5
Congrats! Looks nice, especially with that snowblower!!
/ new X728 !! #6
You will really like that mower and the 3PH attachments work great too.
Congratulations.
/ new X728 !! #7
[SIZE=3[/quote]
i see a cab in your future!
i have the soft side cab, and even without the heater it's great
to not have the wind in your face.
/ new X728 !!
just wondering . . .
just to the left of the hours in the hour meter display there is sometimes a blinking icon.
i have read the owner's manual but could not find it.
what does it mean?
/ new X728 !! #9
what does it mean?
Congrats of your new green toy. :thumbsup: Don't know if this is relevant but on my X500 the icon on the left side of the instrument panel is the oil pressure indicator.
/ new X728 !!
yes, thank you. i see that one.
what i am wondering about is actually inside of the LCD hour meter display just to the left of the hours numbers.
thanks again
geek
/ new X728 !! #11
In my manual it says "The hour meter is counting time if the decimal point is blinking." This is like the blind leading the blind since I just bought the X500 yesterday. :laughing:
/ new X728 !! #12
thanks again
geek
Does it look like an hour glass Icon?
/ new X728 !! #14
Being a new owner of a x728 same set up other then an i have the 7 iron deck. I am having difficulty attaching the rear pto to the mower pto. I had to take it to dealer last time. Now i have been struggling for over an hour. it does not want to go on no matter what i do. an tricks. I have put the **** thing on ramps and tried to tackle from the back. not happening i cant seem to get this on
/ new X728 !! #15
Welcome to TBN scott,
I assume everything is clean and lightly greased on the splines. The first thing I check is to make sure the shaft telescopes smoothly. Then try to push the coupler on a little moving the belt to rotate the shaft to align the splines, once aligned I pull the collar back and push it on until the collar locks back in place. So far I haven't had to do any thing special such as jacking it up or reaching from behind the tractor.
/ new X728 !! #16
It can be kind of a pain on my x748 also. I do what Steve said, except I put the PTO selector on "rear" so the mid PTO free wheels...This makes a HUGE difference, it just slips right on. I don't know if you have the rear PTO option or not.
/ new X728 !! #17
Congrats on new x728. With the 1026r and 60" drive over deck ,did not get auto conn MMM . I had put some light grease on the collar, on the splines of shaft and gear and was still having problem ,oh had the PTO set to the rear.
Finally after 15-30 min of getting madder and madder decided to try something else , sprayed some WD40 on splines ,slides on with no trouble . Have been spraying WD40 now every time ,works first time every time. Light grease so far hasn't helped , maybe with more usage it will get easy, or order the auto connect like I did last week.
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2022 Case 5550 Trident Spreader LOW HOUR (A63118)
2022 Case 5550...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
