At Home In The Woods
/ At Home In The Woods
So Obed, how was your Easter omelette?
Tororider,
I'm afraid I would pay dearly for that omelette.
The turkey is sitting on the nest now. She's in the nest everytime I take a look. She knows we are around and hasn't abandoned the nest. I hear it takes 28 days to hatch turkeys. I guess my back yard may not get mowed again for the next month.
Obed
Saturday I tried to start our push mower that hasn't been used in 2 1/2 years. I couldn't keep it running. I normally run the engine out of gas at the end of the cutting season. However, when I looked in the gas tank Saturday there was a little gas in the gas tank when I looked at it Saturday. I might not have run the engine out of gas 2 1/2 years ago although that would surprise me.
Thus, I drained the gas tank. Then I put fresh gas in the tank, took off the air filter, and sprayed carb cleaner in the carburator and tried to start the mower. The engine would run roughly, speed up, slow down, speed up, slow down, etc. and die within about 30 seconds give or take. I tried this proceedure several times without any improvement. I guess my on-site small engine mechanic will have to take a look at it.
I then raked some grass clippings off the front yard to keep from killing the grass. My little girl played in the yard and in the woods beside the yard while I raked. I really enjoy having her around when I'm working outside. It's need to see how much she likes being outside.
Next I mowed with the riding mower the 2 foot high grass at the entrance to the property at the street.
/ At Home In The Woods #3,984
Obed,
Try some SeaFoam Sea Foam Sales Company in the gas tank. It works wonders. Put some in the tank, crank the engine and let it run for a 30 seconds or so, and then cut it off and let the SeaFoam soak. It will dissolve the deposits in the carb. Mix it pretty strong.
It's kinda expensive, but cheaper than the time it will take removing and rebuilding the carb. I used some in a Pacer irrigation pump that I had left sitting for about a year with gas in it. It worked great! I have also used it in boat motors.
You can buy it at Walmart, Advance, OReilly's etc....
Chris
/ At Home In The Woods #3,985
Obed,
Your wife sparked me to try something I had not done before which was rebuild my tillers carb. For me I am mechanically inclined, but scared that if I get jammed up I won't get out of it. It was easy, took a half hour and now purs like a kitten for a 40 year old engine.
Thank her for me.
Carl
/ At Home In The Woods #3,986
Obed, I am not sure I will be able to explain this well but I will give it a shot. If you take the carb bowl off the piece that hangs down that would be inside the bowl has a very small hole vertically in it. If you can get a small wire, like off of a wire brush into that hole and run it in there several times you may be able to clear any blockage. On the flip side, I have never heard of that foam and that may be easier to do.
/ At Home In The Woods #3,987
Try SeaFoam at first, and then run it at least once a year at high dose if you dont run it all year at the recomemded level. But if not pull the carb and then blow it out and reassemble, it will get you going. There is something either hung in the inlet needle or the float is sticking or your main jet is partial blocked.
/ At Home In The Woods #3,988
Also while you're at it, WD40 all the carb linkages and make sure they're moving freely.
I second the Seafoam idea; I use it in everything from motorcycles and smaller.
We picked up some Seafoam today. Hope it works.
/ At Home In The Woods #3,990
I use stabil in all my small engines to prevent this sort of thing. That said I have slipped at my duties here of late and I tried the seafoam. I can rebuild the carbs and such but the seafoam is much easier. I am all about easy. :D
Father in laws generator was not running without leaving the choke about half on. Put some of the SF in, run it a bit and then let it set a few days. Took care of the problem. :thumbsup:
My wife has planted the following in her garden:
Cabbage, 5 kinds of squash, broccoli, snap green beans, purple hull peas, crowder peas, lima beans, bell peppers, cantalope, watermelon, lettuce, tomatoes, okra, egg plant, cucumbers, potatoes, carrots, radishes.
I helped plant the potatoes, plowed and tilled the garden. My wife has done the rest.
I used my neighbor's disc to prep this area near the entrance. My wife planted wildflowers there.
We have started working on the back porch and deck - finally.
When we built the house, we had the framers frame up the floor joists and build the porch roof. We were going to have them install the decking and railing. However, we quickly saw the framers were not "detailed" enough to do the whole porch job. For example, we intend to put in removable screens so we asked the framers to space the porch columns equally. They did so - that the space between columns was equal "within an inch". Having up to an inch difference in each of the spaced where removable screens would be installed wouldn't have worked. So we just had the framers frame up the porch and deck flooring and build the roof. We are going to finish the decking, railing, and screens ourselves.
We will use Trex decking. We will do railing using horizontal wire "railing" similar to how MotorSeven built his porch in his log house thread. I'm very much looking forward to having a back porch and deck.
Some of the pressure treated floor joists have warped significantly. When we laid some decking boards across them it became apparent that the unevenness of the joist framing was a problem. My wife read that you should plan off the tops of the uneven joists before installing the decking. However, we don't have a planer. At first I decided to just replace one of the joists that was the most badly warped. However, trying to pull the nails out of the toe-nailed joist and joist hangers turned out to be too much work. I then marked a straight line on the joist with a chalk line. Next I put the circular saw sideways against the joist and ripped the joist right in place. That technique worked amazingly well and did not take that much time to do. I did the same thing to a second joist. We'll check the remaining joists and do the same thing to get the decking reasonably flat.
I added a new floor joist close to the rim joist and added some blocking in preparation for installing a picture frame around the decking.
I believe I'm going to enjoy the porch and deck project. I don't have any pressing deadlines so I can tinker with it on my own schedule.
/ At Home In The Woods #3,994
Just a few years back here in NW Georgia we had 2 nights in a row of 22 F. Lost 70 tomato plants. It was mid May.
/ At Home In The Woods #3,995
Obed, that's a nice garden spot. I think you may have to fence it to keep out some critters, but you may have some time before they discover it and drop in nightly for a midnight snack. Hopefully, your soil is rich and will grow a very nice garden. I think your tree lines are far enough away to allow enough sunlight for things like tomatoes that need over 8 hours of sunlight per day. I hope evereything turns out perfectly and we can seen some photos later as the garden comes along. I salute your wife because gardening is hard work, but home grown veggies make it all worth the effort. You won't save a nickel over the grocery store, but your stuff will taste 10 times better.:thumbsup:
/ At Home In The Woods #3,996
Obed, the novelty of the turkey will wear off. We've replaced screens on our sliding screen doors and one window due to aggressive turkeys. They seem to enjoy attacking their reflection in the windows.
New%20lot
[/URL][/IMG]
/ At Home In The Woods #3,997
Obed and wife - The forest critters thank-you and can't wait to enjoy the fruits of your labor. :)
/ At Home In The Woods #3,998
Obed...enjoy your garden....and as others have said, unfortunately all the critters will too...We tried for years to have a nice garden...fences did not keep them out and what we got was great ..but like Jim said ...you will not save a penny compared to local farmers markets or the produce section of the store...but have fun...our first year or two it was not so bad but then it is like the word went out and the squirrels, deer, coons, crows etc. all got together and taught us a lesson...LOL
/ At Home In The Woods #3,999
Personal experience - Last year I planted corn, cucumbers and tomato plants. I made my own electrical fence to try and discourage critters but the tomatoes were chewed on while still green. The cucumbers had bite marks on them. The corn stalks got knocked down and cobs eaten just before they were ready to be harvested. I know the fence worked for awhile but they were persistent in their pursuit of a free meal at my expense.
The outcome is no more garden. Deck planters will hopefully dicourage bandits and farmers market/wolesale produce store will be my source for fresh veggies from now on.
I didn't have this problem for years but did see a big old racoon and ground hogs in the backyard where garden was located. Also have squirrels, chipmunks, crows and skunks around. Tried using Hav-a-hart trap which resulted in catching a kitten one time and a skunk another time. Switched to leg hold trap and caught ground hog and a skunk. Best medicine in my younger days was the compound bow for ground hogs but they wised up and run for their lives when they see me now.
Critters win - I give up.:(
Freightliner Columbia (A63118)
Freightliner...
2007 International 4300 Altec DM47 TR 47ft Insulated Digger Derrick Truck (A60352)
2007 International...
2461 (A58376)
2461 (A58376)
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
