My tractor's butts to big
   / My tractor's butts to big #1
Dingo Man
Maine
12' Kioti DK40SE HST
As many of you may know I just got my first tractor delivered the other day in a DK40HSTSE. I had mentioned in another thread that the tractor came with the rears in the wide position with R4's. I am not complaining because I have hilly land and I like the wide stance. But I bought a 72" tiller figuring on my tractor only being 63.9" as stated on Kioti's website. So now my rears at 74" wide. Once I attatch my tiller can I push the lower arms and tiller to one side or the other in order to get the tiller on the outside of one of the rear tires?
   / My tractor's butts to big #2
You should be able to get a few inches by adjusting the sway bars to one side. The 63.9 is probably for AG's which have a narrower wheel and tire.
James K0UA
   / My tractor's butts to big #3
you can bring those tires in by adjusting your wheels . Check your owners manual , but if they are loaded with fluid , make shure you have help ! and enjoy your new tractor .
DK40 SE SS
   / My tractor's butts to big #4
adjusting your sway bars should let you take out one tire track
No off set option on the tiller. My tires are loaded so i really did not want to fool with it but I will think about it. Thanks.
   / My tractor's butts to big #7
DK40 SE SS
There is no wheel width adjustment on wheels built for R-4's; the rims are welded to the wheel centers
   / My tractor's butts to big #8
yep was going to say the same thing, no adjustment on the wheels on my new Kioti or the Kubota I traded off. Both have solid wheels with R4's
James K0UA
   / My tractor's butts to big #9
Koua is right, pull the pins on the sway bar(the one's on their own catch chain), shove the tiller to one side and put the pins back in. That should cover a track with room to spare.
   / My tractor's butts to big #10
just be careful and not bind the shaft when you move to 1 side several tillers i have seen they don't have alot of room for the yoke to flex woods has a tiller that will adjust to either side
2017 Freightliner Derrick Digger (A55973)
2017 Freightliner...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2011 BMW 750Li Sedan (A55973)
2011 BMW 750Li...
2025 GPS Trailers (A56858)
2025 GPS Trailers...
1957 Chevrolet Bel Air - 2-Door Hardtop, Period-Correct Engine (A56435)
1957 Chevrolet Bel...
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
