Quick hitch bushings
/ Quick hitch bushings #1
catdozer
john deere
After waiting for bushings (category 1-3) I canceled my order took some 1 1/2 round stock, turned down to 1 7/16 and drilled the 7/8 hole and now I got bushings that are 3 1/4 long for a total of about $3 for electricity. I can either use a roll pin for pin hitch or use them on a Clevis type hitch.
/ Quick hitch bushings #2
Nice to have the equipment to make your own :thumbsup:
/ Quick hitch bushings #3
I know this is an older thread, but what kind of steel did you use for the bushings? Anything special or just mild steel?
It was just plain mild steel. Have not had any problems with them at all! Pretty simple and quick to make out of round stock
/ Quick hitch bushings #5
Thanks dozer....
Did you paint them with anything? Or just let them rust?
/ Quick hitch bushings #6
"for a total of about $3 for electricity."
And several thousands of dollars in equipment. lol
Thanks dozer.... Did you paint them with anything? Or just let them rust?
Nope just coated them with a little grease. Just never got around to paint them and there fine
"for a total of about $3 for electricity." And several thousands of dollars in equipment. lol
It's amazing what I save in turning down my own parts for all the heavy equipment
/ Quick hitch bushings #8
Thanks Dozer,
I'm going to try that today.
It would be different if you didn't already OWN the thousands of dollars in equipment.....it's not like you went out and bought it all just to turn a few 8 dollar pins :laughing:
/ Quick hitch bushings #9
My time is better spent on other things when those bushings are readily available. I get them from a Land Pride dealer. there are 2 IDs for the 7/8 and 3/4 pins. The 1-3 adapter are a little loose fit on the hooks. They come in various lengths as displayed in the LP manual for their QH (available free on their web site). I get several long ones and cut to length for the odd ball ones. I have 10 implements and have bushings and pins for all. never have to go looking for them. naturally I have spares as the hired hand tends to lose then in the dirt somehow.
Ron
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2007 FRAC TANK 500BBL WHEELED (A60736)
2007 FRAC TANK...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
14in Digging Tooth Bucket Excavator Attachment (A60352)
14in Digging Tooth...
