Buying Advice Dealers Not Ordering 2011 tractors
   / Dealers Not Ordering 2011 tractors #71
you may very well be selling LS short on this. NH designs the tractors that LS is building, correct?
   / Dealers Not Ordering 2011 tractors #73
Out of curiosity what is the difference between a 3045 and a NH workmaster 45? Why one over the other?
Aren't these really entirely diffferent class of tractors? I picture the Workmaster 45 as being a no-frills straddle platform ag type utility with limited options, eg. no cab, no hydro, only R1 28" tires, 8X8 trans, etc. The Workmaster is built heavier with inboard planetary rear axles and the front wheels are adjustable, even with 4WD, can take Cat I or Cat II, etc.
The 3045 on the other hand is a CUT with available cab, hydro or 12X12 and many other options. But tires are only 24" max, less ground clearance, no planetary rear axle, can't adjust front rims on 4WD, only Cat I, and much lighter tractor, and price starts several $K higher even in 2WD and can be run up much higher with options.
I might be wrong on a few points but to me they're quite different and not designed for the same market. Maybe one of the dealers can fill in other major differences.
   / Dealers Not Ordering 2011 tractors #74
Aren't these really entirely diffferent class of tractors? I picture the Workmaster 45 as being a no-frills ag type utility with limited options, eg. no cab, no hydro, only R1 28" tires, 8X8 trans, etc. The Workmaster is built heavier with inboard planetary rear axles and the front wheels are adjustable, even with 4WD, can take Cat I or Cat II, etc.
The 3045 on the other hand is a CUT with available cab, hydro or 12X12 and many other options. But tires are only 24" max, less ground clearance, no planetary rear axle, can't adjust front rims on 4WD, only Cat I, and much lighter tractor, and price starts several more even in 2WD and can be run up much higher with options.
you are exactly right. two different tractors. the 3045 is still in the compact class of tractors. they have a lot of different options for them too. tranny options, cabs, etc..........the Work MAster 45 is a little bigger for one and it is a lot simplier. i refer to them as "like an old school farm tractor" real simple, easy to operate no frills, other than the shutte shift and it come with one rear hydraulic remote.....
Well I Guess I Will End This Thread ,Did Not find A N.O.S.Boomer 3040,So Started Looking At The Work master 55-4x4 And When I Asked how Do Ya Shift It He Could or Would not Tell Me How.Just Come Up A Drive 1,Pretty Dumb, Just Didn't Want to Tell Ya Got To Double Clutch It,What A Waist for New Holland Make A Great Tractor And A **** Box for A Tranny,I give Up Call CNH For Info Don't Have Any.Making The boomers 30-40-50- for A Small farmer,Did Ya Ever See A Small We Are Big boys.In The U.S.A.Then ya Got Dealers Selling Mahindras,Owell
   / Dealers Not Ordering 2011 tractors #76
I would say it's at least time to start a new thread... I think at this point halfway through 2012 it's not surprising that dealers are not ordering 2011 tractors...
CATERPILLAR 315FL CR EXCAVATOR (A51242)
CATERPILLAR 315FL...
LANCER MODEL HL125 - 4' TILLER (A51243)
LANCER MODEL HL125...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
CATERPILLAR 819 PADFOOT LANDFILL COMPACTOR (A51242)
CATERPILLAR 819...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
2012 John Deere 7230R (A52128)
2012 John Deere...
