3-Point Hitch Controlling height of implement
/ Controlling height of implement #1
vjcoppola
Member
Forestville, NY
Mahindra 5010 Gear, Ford 2000 prior
I bought a new 5010 gear with cab a couple months ago and find that, compared to my old Ford, it is difficult to set the height of an implement on the three point hitch. With the Ford I can carefully move the quandrant controll and set the height exactly where I want it. On the Mahindra though it's up or down. Is this normal? Does anyone know how this might be corrected?
/ Controlling height of implement #2
The position control lever only moves to the extremes? :confused: So if you have the lever half way, the hitch just does not move? :confused2: Obvious that something is wrong, that is not how the 3pt hitch is meant to work. I have operated the same tractor once off and on for a day, the hitch on it was fine.
/ Controlling height of implement #3
If you have a speed control knob try adjusting it so the implement raises and lowers more slowly. From there you can set the lower stop easier.
/ Controlling height of implement #4
That's definitely not right. I have a 5010 HST and have no problem raising/lowering the 3PH to any position from fully up to fully down.
/ Controlling height of implement #5
Do you have two levers??? One is draft control
and if draft control is on it will act that way.
larry
I tried using the knob that adjsts how fast the hitch falls. It's a little better but this knob does not control how fast the implement rises so I still do not get the fine degree of adjustment that I'm used to. It seems that it needs a flow control that works in both directions.
There is no draft control lever.
CAT 225BLC Excavator (A61166)
CAT 225BLC...
2013 Ford Escape SUV (A61569)
2013 Ford Escape...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
Chevrolet 2500 Flat bed (A63118)
Chevrolet 2500...
13042tx (A55973)
13042tx (A55973)
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
