Deere 110 with BB1284 box blade, not working properly?
   / Deere 110 with BB1284 box blade, not working properly?
s219 said:
I bet you're still coming out ahead with your used one though. Heck, if you bought new and put some years/hours on it, you'd be in the same boat, plus you would have swallowed all the depreciation!
Your probably right, there's just nothing like a brand new machine, but by no means am I complaining. I just cant stand thins wait any longer!
   / Deere 110 with BB1284 box blade, not working properly? #132
Martian,
Glad to hear that the problem has been identified and fixed. Did they rebuild the diverter valve or just replace it?
I wouldn't think that rebuilding the valve would be that expensive - but, the labor to pull everything apart and put everything back together; lines, etc. would be!
Be home this week?
AKfish
Martian,
Be home this week?
AKfish
They are replacing, not rebuilding. I posted the same thing on GTT and the same question was brought up, and resulted in the same answer you gave. Might be cheaper for us to rebuild, but after shop hours and the reliability now being on the shop to produce a 'like new' part, they'd rather replace.
Should be home this week, if they can get the part in and replaced. As you probably know as well as I do by now, they don't move super fast as they have had the tractor more than I have at this point!
Hopefully it will be home shortly and can finally get some use out of it:thumbsup:
   / Deere 110 with BB1284 box blade, not working properly? #134
Martian, be sure to get the faulty valve back from them.
I'm asking about that tomorrow, Ken (Kennyd now on GTT) called dibs on it though:thumbsup:
   / Deere 110 with BB1284 box blade, not working properly? #136
Bet there is NOT a faulty valve to get back, Just a bunch of parts if they rebuilt the valve.
What is GTT?
What is GTT?
They did order a new valve, so there should be something, maybe I'm wrong. I'll find out tomorrow for sure.
GTT is Green Tractor Talk, formerly Deere Talk.
   / Deere 110 with BB1284 box blade, not working properly? #138
What is GTT?
There should be a valve returned.. It's just a machined, mono-block of aluminum with O-ringed inserts.
Hard to say what's wrong with it. Be interested to know.. maybe some foreign material, O-ring ka-blooey. Worse thing would be a chunk of harder metal lodged in there and scoring or gouging the mono-block.
If the gouge was bad enough - block might just be a desk ornament! :)
AKfish
   / Deere 110 with BB1284 box blade, not working properly? #139
Martian, I get the vibe your dealer isn't the sharpest knife in the drawer. There is so little to the valve assembly(as AK suggested) that it would definatly be cheaper to repair it. However, I would have likely replaced it with a new one if I wasn't able to repair/replace it myself. Without a doubt get the old one back.
Matt
   / Deere 110 with BB1284 box blade, not working properly? #140
I too thought just a rebuild was in order, but did not know it was made of aluminum. I would have thought it would be cast iron. I also thought hunks of O-Ring causing the trouble and most of the cost quoted was labor charge to R & R, then rebuild. I'll have to check the valve price on JDparts. Quote seems to low for a new valve installed.
Let us know what failed and pictures if possible. Hard to believe on such a low hour machine.
I never did buy the "electrical wire/connector" diagnoisis.
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
John Deere 960 Culitivator (A50514)
John Deere 960...
1984 GROVE AP-308 CRANE (A51222)
1984 GROVE AP-308...
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
