husqvarna 350 muffler
/ husqvarna 350 muffler #1
namesray
nc PA.
kubota rtv900: kubota mx5200
blocking up firewood today with my husqvarna 350 and the muffler finally fell off. i have been fighting with it for about a year now. it started with the muffler bolts backing out. i tried lock tite (the high heat type) and that didn't work. finally i tacked welded the bolts fast. this was working until i started to notice the whole muffler wiggling when operating. finally fell off tonight. now don't get me wrong, i love husqvarna saws and this saw has been a great saw. i have had it for about 3 years now and have cut well over 400 face cord of fire wood with it. that's wedge/fell, delimb, and block up. a lot of cuts/use. it doesn't owe me anything.
to my question. anybody out there think i should get the muffler replaced? i lean towards doing this, but my biggest fear is that from all the use, the bolt holes in the engine that the muffler attaches to are ovaled/wore out and even the fix would start working loose and i would just have a headache on my hands. what do you think? is there a good way to fix ovaled out holes? the saw still runs good. and i have a good heavy duty bar on it with quite a few custom length chains i just bought. maybe the bar/chains fit on a new one? just wondering what other's thoughts are. thanks in advance.
just wanted to clearify myself a little. i was in a hurry the first post. the muffler bolts into the engine, and i think that might be alumimum? the whole muffler was shaking, but the muffler bolts were still tight, so the threads into the engine must be stripped/ovaled out. just buying a new muffler with new bolts is not going to work. i would like to have my dealer fix it instead of buying a new chainsaw, but worry it will just keep working loose since the muffler bolt threads in the engine are damaged. should i just buy a new chainsaw and retire this one? or is there a good fix to the damaged thread holes? chainsaw gets very heavy use.
/ husqvarna 350 muffler #3
I had the same problem with my 350. I came to learn the 350 is noted for this problem. My suggestion would be to put Heli-coils in both holes then drill small holes in the bolt heads and run wire through the holes. My saw had worn the holes so large I could not fix them and I sold the saw for parts. Too bad, it was a great saw except for this problem.
/ husqvarna 350 muffler #4
I think I may have seen this 350 of yours on craigslist in Ohio?
I actually cant stand the plastic crankcase even though I like the bolt on cylinders it has. I just stay away from them even when offered for $100 like new.
Seen to many melted through oil tanks.
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
VOLVO ROLLER (A65053)
2012 DODGE 2500 RAM (A65643)
2012 DODGE 2500...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
(2) Electric Motors (A64127)
(2) Electric...
275 Gallon Chemical Container (A64127)
275 Gallon...
