Cutting edge for loader bucket..
/ Cutting edge for loader bucket.. #1
fbiwrench
Member
Houston TX/ Michigan
Bobcat CT230
Does anyone have a replaceable cutting edge, (not tooth bar), on their loader bucket? I see holes along the edge of my bucket and I assume there must be a replaceable cutting edge. Does anyone have one and if so what should I expect to pay for one?
/ Cutting edge for loader bucket.. #2
Yes I bought one for my CT445.
Bolt-on 74" cutting edge, $229 when I purchased the tractor (May 2011)
/ Cutting edge for loader bucket.. #3
You can also weld on cutting edges.
Makes it easier to find the thickness and width you want.
The stuff is not cheap!:)
/ Cutting edge for loader bucket.. #4
I used a cutting edge off a fisher plow. Welded it to the original. It will last a long time and it added a lot of strength to the bucket
/ Cutting edge for loader bucket.. #5
I bought one with my 72" HD Roundback bucket on a Kubota and I think the cost was $250 and I took it off for a tooth bar and it sits in the corner of the garage. Brady Barlow told me I didn't need it but I wouldn't listen.:eek:
That sounds good, really would save on the bucket when scraping snow from paved driveway. Something else to put on the got to get list.
/ Cutting edge for loader bucket.. #7
I would not be with out a cutting edge. My tractor was slightly used, 160 /190 hours on it.
Bucket edge was already showing a lot of wear. I use it pretty hard, lots of rock & gravel and edge would have been gone in another 200 hours. Good chance the bucket would have been bent as well.
In keeping things simple a hole was burned through the bucket & hard edge to bolt a trailer on. Easy to install or remove.
/ Cutting edge for loader bucket.. #8
I purchased the same one for the same price about two weeks ago.
/ Cutting edge for loader bucket.. #10
I have one, I got it from my dealer.
I do not remember for sure but I think it was in the $180 range.
Sure helps protect the bucket!
:thumbsup:
/ Cutting edge for loader bucket.. #11
Steel supplier here carries a high carbon cutting edge that they sell by the foot and punch the holes where you want them.I would like to say $2 an inch.
/ Cutting edge for loader bucket.. #12
You show michigan in your sig, MIE has them for Kioti for $150. I have 20+ hours on my bucket prob more like 30 in the dirt and the edge showes very little wear if any. CJ
/ Cutting edge for loader bucket.. #15
i have a 2500a tractor with a 7 ft bucket.i got a grader blade,that was being replaced on the grader.the holes lined up perfectly,just bolted up.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2016 FORD F-550 SUPER DUTY DUALLY CAB-N-CHASSIS (A60736)
2016 FORD F-550...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
