Cutting edge for loader bucket..
/ Cutting edge for loader bucket.. #1
fbiwrench
Member
Houston TX/ Michigan
Bobcat CT230
Does anyone have a replaceable cutting edge, (not tooth bar), on their loader bucket? I see holes along the edge of my bucket and I assume there must be a replaceable cutting edge. Does anyone have one and if so what should I expect to pay for one?
/ Cutting edge for loader bucket.. #2
Yes I bought one for my CT445.
Bolt-on 74" cutting edge, $229 when I purchased the tractor (May 2011)
/ Cutting edge for loader bucket.. #3
You can also weld on cutting edges.
Makes it easier to find the thickness and width you want.
The stuff is not cheap!:)
/ Cutting edge for loader bucket.. #4
I used a cutting edge off a fisher plow. Welded it to the original. It will last a long time and it added a lot of strength to the bucket
/ Cutting edge for loader bucket.. #5
I bought one with my 72" HD Roundback bucket on a Kubota and I think the cost was $250 and I took it off for a tooth bar and it sits in the corner of the garage. Brady Barlow told me I didn't need it but I wouldn't listen.:eek:
That sounds good, really would save on the bucket when scraping snow from paved driveway. Something else to put on the got to get list.
/ Cutting edge for loader bucket.. #7
I would not be with out a cutting edge. My tractor was slightly used, 160 /190 hours on it.
Bucket edge was already showing a lot of wear. I use it pretty hard, lots of rock & gravel and edge would have been gone in another 200 hours. Good chance the bucket would have been bent as well.
In keeping things simple a hole was burned through the bucket & hard edge to bolt a trailer on. Easy to install or remove.
/ Cutting edge for loader bucket.. #8
I purchased the same one for the same price about two weeks ago.
/ Cutting edge for loader bucket.. #10
I have one, I got it from my dealer.
I do not remember for sure but I think it was in the $180 range.
Sure helps protect the bucket!
:thumbsup:
/ Cutting edge for loader bucket.. #11
Steel supplier here carries a high carbon cutting edge that they sell by the foot and punch the holes where you want them.I would like to say $2 an inch.
/ Cutting edge for loader bucket.. #12
You show michigan in your sig, MIE has them for Kioti for $150. I have 20+ hours on my bucket prob more like 30 in the dirt and the edge showes very little wear if any. CJ
/ Cutting edge for loader bucket.. #15
i have a 2500a tractor with a 7 ft bucket.i got a grader blade,that was being replaced on the grader.the holes lined up perfectly,just bolted up.
2014 Kubota RTV X900 4x4 Diesel Utility Cart (A61567)
2014 Kubota RTV...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A60352)
2019 John Deere...
2013 Chevrolet Traverse SUV (A61569)
2013 Chevrolet...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
2017 Nissan Pathfinder SUV (A61569)
2017 Nissan...
